LED lights - JeepForum.com
post #1 of 20 Old 12-02-2013, 01:59 PM Thread Starter
GTNMUDY
LED lights
Anyone using 1157 LED light for the tail lights?
If so what brand are you using.
Looking for a brighter tail/turn light.
Larry
If it breaks once, shame on it. If it breaks again, shame on me.
Fix it right or better the first time.
GTNMUDY is offline
post #2 of 20 Old 12-02-2013, 03:28 PM
Spieg8
1984 CJ8
I tried a set from Pep Boys (don't remember the manufacturer and noticed Pep Boys no longer carries them). 1157 replacement LEDs were not a good option for me. I ran into 2 issues.
1) Because of the way the Jeep turn signals work, I was unable to get the bulbs to function as both running light and blinking turn signals. They would either light up as running lights but not blink, or if I reveresed the polarity they would blink to signal a turn but would not light up as a running light (and before someone says it... Yes I installed an LED capable flasher module).
2) Even if they did function properly, LEDs are so bright you don't want to use a white light in a color housing (red taillight filter would glow pink in stead of red). If I installed red LEDs, then my license plat lighting (clear window in the bottom of the driver side brake light housing) would cast a red light on the license plate (not legal and the police are happy to tell you so).
If you really want LED lights, I would recommend you buy the complete housing designed for LED;
Spieg8 is offline
post #3 of 20 Old 12-02-2013, 06:02 PM
vinnyabs
1983 CJ7
I use HMMVW tail lights that use a 1156 bulb for brake turn. I grabbed a red led build for brightness aka safety and it is no brighter than my incandescent. Name:  image-779945630.jpg
Size:  422.5 KB The first is running light with incandescent. The second is brake with led. Definitely brighter but I promise no more than incandescent.
Reverse the pics with the comment. The website flipped their order
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #4 of 20 Old 12-02-2013, 06:17 PM
KMD
1976 CJ7
Previous owner did a flush mounted Grote so I got the LED version. It's not bad but I like the hummer lights better.
KMD is offline
post #5 of 20 Old 12-02-2013, 06:34 PM Thread Starter
GTNMUDY
WOW, not much of an improvement.
I still have the stock tail light assembly on my 84 CJ.
Yours are flush mounted and I wonder if the stock tail light assembly would be different.
Larry
Vinnyabs, what did you do with the gas cap???
Or do you pop the light up and fill the tank
GTNMUDY is offline
post #6 of 20 Old 12-02-2013, 06:57 PM
lucdog
1980 CJ5
Me thinks one way to get a brighter tail light is to use aluminum duct tape inside the light itself. I got this idea from another member here on JF, (thanks COIZ)!!
This tape isn't your run of the mill cheap stuff. Just do a little measuring, and stick it to the plastic on the inside. Do the back up light also.
http://m.homedepot.com/h_d1/N-5yc1vZ...atalogId=10053
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 20 Old 12-02-2013, 07:02 PM Thread Starter
GTNMUDY
Thought of that also, but I think my taillights already have a metal reflector inside (at least I think) havent had them apart in 20 yrs.
Thanks for the tip maybe someone else can use it...
Larry
GTNMUDY is offline
post #8 of 20 Old 12-02-2013, 07:58 PM
CJ7ROB
Got these pretty cheap on ebay. Pretty bright.
CJ7ROB is offline
post #9 of 20 Old 12-02-2013, 08:34 PM Thread Starter
GTNMUDY
Update
Well, I went out and took the lens off the tail light and no reflector. What I did find was dirt!
How the heck can all that dirt get inside the tail light.
Anyway I cleaned it out and then had 2 choices. I did have aluminum tape and also some chrome paint.
I tried a compairson of tape and paint. Look at the bottom of a coffee can with chrome paint and a strip of aluminum tape.
Trying to tape the inside of the tail light looked like it would be a long job, so I painted it.
I did the drivers side only with the paint and left the right side alone.
Took some pictures to see if I could see a improvement.
in the last pic the small white dots are snow flakes, but I really cant see much improvement....
Larry
GTNMUDY is offline
post #10 of 20 Old 12-02-2013, 09:35 PM
james04si
james04si's Avatar
1977 CJ5
Is that actual aluminum duct tape that you have to remove the backing for it to stick or the cloth/PVC duck tape? There is a difference in reflectivity and it may just be because I'm on my phone but that looks like duck tape not aluminum duct tape in the picture.
james04si is offline
post #11 of 20 Old 12-02-2013, 10:01 PM
Spieg8
1984 CJ8
Really hard to tell from a photo. From personal experience I think the tape will be much more reflective than paint.
Spieg8 is offline
post #12 of 20 Old 12-02-2013, 10:24 PM
lucdog
1980 CJ5
It's actual aluminum tape ( at least what I'm using) and the backing has to be removed. I haven't bought the brand seen in the picture. I posted it to give a general idea.
I would also say the tape is better than paint.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #13 of 20 Old 12-02-2013, 10:50 PM
james04si
james04si's Avatar
1977 CJ5
I was referring to the other persons photo. I haven't used any for tail lights but bought some for its actual intended purpose of ducts. I agree that aluminum duct tape is much more reflective than silver paint.
post #14 of 20 Old 12-02-2013, 11:08 PM
seabass1858
1983 CJ7
i was thinking about using some for my front parking lamps. I had to replace my lenses, due to cracked, for inspection and behind the lenses was rust so i was thinking about some navel jelly to the rust and aluminium duct tape after that
seabass1858 is offline
post #15 of 20 Old 12-03-2013, 12:30 AM
vinnyabs
1983 CJ7
Gas filler is moved to passenger side straight from tank. Used a tj bezel Name:  image-1401473865.jpg
vinnyabs is offline
