Leaky windshield gasket - JeepForum.com
post #1 of 6 Old 01-09-2012, 05:42 AM Thread Starter
redrenegade1968
My 82 Cj-5 has a leaky windshield gasket that I have battled for a while. I replaced the gasket a couple of years ago, and even used a small bead of silicon in doing so. My jeep is garage kept, and the gasket still appears pliable and in good shape. Any ideas on why it may still leak in rain showers??? And what I can try to stop it?
redrenegade1968 is offline
post #2 of 6 Old 01-09-2012, 05:55 AM
twoleos617
where on the inside do you see the leak? is your windshield frame solid or rusted through in spots?
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #3 of 6 Old 01-09-2012, 05:56 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
A couple of things I can think of:
1. Did you silicon both the seal/metal and seal/glass areas?
2. Does the top of your frame have mounting holes for either a soft top, or bikini? When I recently removed my windshield frame, I realized the holes for my bikini channel were allowing water inside the frame, when I run the hardtop and have to remove the channel.
3. Are you sure it's not the cowl seal that's leaking? Mine had leaks at both the glass seal and cowl seal.
Here's a few shots of mine, before and after I painstakingly treated all the rust, and then metal glazed and sanded for paint.
Matt
Windshield5.jpg   Windshield2.jpg   Winshield6.jpg   Windshield3.jpg   Windshield6.jpg
Matt1981CJ7 is online now
post #4 of 6 Old 01-09-2012, 07:51 AM
noahlon
1968 CJ5
CJ's are equiped with an automatic foot washer!
noahlon is offline
post #5 of 6 Old 01-09-2012, 07:53 AM Thread Starter
redrenegade1968
The leak is directly above the radio, and it has shorted my radio out in the past. Actually, I think that the leak is in the cowl that I replaced. There was not any bad rust when I changed it out, and I THOUGHT I used enough silicon on it...
post #6 of 6 Old 01-09-2012, 12:08 PM
twoleos617
you sure its not a mechanical oil guage leaking and shorting your radio? ask me how i know!!
Mike D.
CJ Windshield Gasket mfern004 Jeep CJ Forum 0 02-28-2011 04:20 AM
Gasket between windshield leaks JohnGodwin30 Jeep CJ Forum 6 04-16-2010 08:15 PM
orig gasket or gasket sealer on differential cover DeadPhish Jeep CJ Forum 2 03-01-2009 08:06 PM
New CJ windshield frame - Wrangler gasket? cincyjeeprs Jeep CJ Forum 3 09-24-2008 11:52 AM
windshield gasket sizes certifiablejeep Jeep CJ Forum 2 04-06-2004 03:33 PM
