leaks - JeepForum.com
post #1 of 9 Old 04-14-2007, 07:44 PM Thread Starter
1976cj7
leaks
it seems everytime i stop a leak, another one starts just replaced all hoses, now i have a leak somewhere? it's dripping from the motar mount but i can't see where from. it's a slow leak at least, i guess only good thing is that it's not an oil leak.
1976cj7 is offline
post #2 of 9 Old 04-14-2007, 07:49 PM
Fuzz21
Fuzz21's Avatar
Welcome to the jeep life! I know how you feel my driveway was spot free for a while and then as soon as i said to someone mine doesn't leak POW! little drips everywhere.
1985 CJ-7, 258 w/a weber carb and HEI, 2.5"lift w/32" tires, 1/2"shackle lift, Dana 300, T-5, AMC 20 w/one piece axels, and Dana 30, YJ tub swap w/CJ tailgate, chevy blower motor upgrade, homeade body sliders, flush mount LED taillights......much more to come!!
"And on the eigth day, Man created BEER!"
Fuzz21 is offline
post #3 of 9 Old 04-14-2007, 08:45 PM
Fropleyqk
Fropleyqk's Avatar
If its not an oil leak... do you have power steering? I had a problem where I over filled my P/S resevoir and it leaked out from the cap under pressure and dripped from the mount.
Fropleyqk is offline
post #4 of 9 Old 04-15-2007, 06:38 PM Thread Starter
1976cj7
no, but i wish i did, no power brakes either.
1976cj7 is offline
post #5 of 9 Old 04-15-2007, 07:01 PM
slacker92104
slacker92104's Avatar
Figure out what kind of fluid it is?
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #6 of 9 Old 04-15-2007, 07:35 PM Thread Starter
1976cj7
sorry it's radiator fluid.
1976cj7 is offline
post #7 of 9 Old 04-15-2007, 08:09 PM
high51977
check your frost plugs. if they are original one has probably rusted through
Play by the rules you're gonna miss all the fun
high51977 is offline
post #8 of 9 Old 04-15-2007, 08:20 PM Thread Starter
1976cj7
will do, thanks one quick question did you mean front plugs??? you said frost plugs. i am not a mechanic this a learning thing for me
1976cj7 is offline
post #9 of 9 Old 04-15-2007, 08:24 PM
00TJ
i think they're call FREEZE plugs
2000 Tj 4" Full Traction, BL, MML Bilstein shocks 35 12.5 X-terrains D30/S35 w/4.88's Highrock bumper
1982 CJ7 SBC 350 Full Resto(under construction)
1946 CJ2A Full Resto(under constrution)
00TJ is offline
Help with leaks? newjeepowner Jeep CJ Forum 4 04-04-2009 02:50 PM
CJ7: Oil leaks, vacuum leaks and suspension squeaks ghengis86 Jeep CJ Forum 0 04-17-2008 09:30 PM
leaks M79 Jeep CJ Forum 3 07-06-2007 09:57 AM
Leaks 1976cj7 Jeep CJ Forum 3 03-17-2007 06:32 PM
CJ Oil Leaks h2obuff Jeep CJ Forum 10 10-25-2005 08:55 AM
