Leaking Valve Cover Need to Fix - Page 2 - JeepForum.com
post #16 of 20 Old 08-16-2013, 10:25 AM
Gasman303
1979 CJ7
When I installed mine on 4.2l I had to trim a little of the gasket with exacto knife to get it to fit within the lip of the valve cover, if not the gasket would have squished and left some gap under it! I don't believe all newer gaskets fit like they're suppose to, therefore leaking issues Occur?! Felpro cork gasket
Gasman303 is offline
post #17 of 20 Old 08-21-2013, 09:20 AM Thread Starter
jbrosnan
Well I purchased the 4.2L valve cover. I checked the fit, all was good, then I cleaned up everything and put RTV and Gasket on and installed cover. All went well except the 5/16" X 1/2" long allen head bolts were not long enough to thread up in the holes on the drivers side. So I snugged all the other bolts up and let the RTV cure, I am getting longer bolts for the driver side today. Question do you think the cover will leak since I was not able to snug the drivers side up while the RTV was curing? SHould I try it or go ahead and redo? If I cant get 3/4" long bolts do you think 1" will be ok with washers stacked up?
jbrosnan is offline
post #18 of 20 Old 08-21-2013, 10:04 AM
walkerhoundvm
1981 CJ8
Only thing you can do is try it and see You might just cut a little off a 1", instead of using washers. Make sure you've got something to test the threads, then plug and torque!
walkerhoundvm is offline
post #19 of 20 Old 08-21-2013, 11:36 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Put a nut on first, cut the bolt and unthread nut.
The nut should straighten out the threads....
2Xtreme is offline
post #20 of 20 Old 08-21-2013, 12:04 PM
walkerhoundvm
1981 CJ8
Life hack #143
