Leaking oil from front oil pan..? - JeepForum.com
post #1 of 11 Old 01-05-2010, 05:02 PM Thread Starter
Bobby9821
1980 CJ7
My AMC 360 is leaking oil from the front of the oil pan. I have already changed my pan gasket and my oil pump gasket. It still leaks. Any suggestions? please help. thanks. ~Bobby
Bobby9821 is offline
post #2 of 11 Old 01-05-2010, 05:34 PM
mcktiger
front seal on the crank. behind the balancer.get some brake cleaner wipe down real good than start it up and let it warm up and crawl under and see if you can tell where its coming from.
2006 tj rubicon
mcktiger is offline
post #3 of 11 Old 01-05-2010, 06:21 PM Thread Starter
Bobby9821
1980 CJ7
I see it dripping from the front seal. I changed the gasket once. Could it be more than just the gasket?
post #4 of 11 Old 01-05-2010, 07:25 PM
mcktiger
the seal goes in the timing cover. it also could be where the rubber part on the front where it meets the cork on the pan. i always put a dab of gasket sealer on the corners along with under and on top of the rubber. but if its the seal than you need to pull the balancer off and get a new crank seal. if the oil is above the pan that would tell me its the crank seal.
2006 tj rubicon
mcktiger is offline
post #5 of 11 Old 01-05-2010, 11:50 PM Thread Starter
Bobby9821
1980 CJ7
k, thank you
post #6 of 11 Old 01-16-2010, 07:50 PM Thread Starter
Bobby9821
1980 CJ7
Can anyone tell me how to change the crank seal?
post #7 of 11 Old 01-16-2010, 09:51 PM
wrongway92407
wrongway92407's Avatar
To start drain and remove the radiator, remove the belts, the crank pulley, and then the balancer. You will need a tool to pull the balancer, there is a bolt in the center that you have to remove. After the balancer is removed you can then remove the seal, it's best that you use a tool for this also. after you have removed the old seal clean the area, and you are ready to install the new seal. There is a tool for this. I have used a large socket in a pinch but you run the risk of getting the seal in crooked. This is a shortened version on how to do this, it's not that hard, just take your time. Install is the reverse, torque the bolt on the balancer to I think 80 psi (someone correct me if I'm wrong)You can rent some of the tools at Auto Zone, or you can buy inexpensive tools at Harbor Freight. Search the forum I believe that there is a link to the factory manual.
Wrongway
My fleet:
86 CJ7 5.7 vortec. 4L60,D44's,OBA,Air tank bumpers w/D rings detroits,4.88,35" bfg, mt's 9500ti warn
86 CJ7 2.5 detroits, OBA 4.56, air tank bumpers, w/D rings,9500I warn 31x10.5x15, Trxus
86 CJ7 bone stock, w/factory 44 never seen the dirt soon to be for sale
87 Wrangler also never seen the dirt.
wrongway92407 is offline
post #8 of 11 Old 01-17-2010, 06:56 AM
mcktiger
90lbs for the balancer. so im asuming that seal was leaking after closer look. it rally not to bad to change wrongway gave oyu the right info. good luck.
2006 tj rubicon
mcktiger is offline
post #9 of 11 Old 01-17-2010, 07:12 AM
Mike Romain
When putting in a new front seal in the timing cover, I like to set the seal in place, then pre fit the harmonic balancer so the seal centers nicely on it and start tightening up the cover. I get 3 or 4 opposing bolts pretty tight, then I remove the balancer again to get the bolts under it and finish the cover tightening with a final run around torque.
I have seen more than a few front seals 'fail' because the play in the bolt holes of the timing cover will allow the seal to be 'just' off center enough to leak.
Mike
Mike Romain is offline
post #10 of 11 Old 02-28-2015, 04:42 PM
BlackSkull1979
just curious, yes probably an obvious question, but im new and need to know. Can you place the seal in backwards? i think i may have.. and i can't remember how i took it out weeks ago, my manual does'n't specify if i put it in with the "covered Ring hole" side towards the balancer or the Open end(no cover with hole) towards the balancer..
any help?
BlackSkull1979 is offline
post #11 of 11 Old 03-01-2015, 03:53 AM
Mike Romain
any help?
Covered part out.
Mike
spicer 20 front output shaft leaking. . .how to fix mcurcio1989 Jeep CJ Forum 7 11-05-2009 01:28 PM
CJ5 front axle seal leaking clerihew82 Jeep CJ Forum 3 12-29-2008 05:34 PM
Front output shaft on Xfer case leaking ClarkGriswold Jeep CJ Forum 4 02-26-2007 09:19 PM
T5 Trans - Leaking Front Seal Hibbitz Jeep CJ Forum 5 07-07-2006 06:39 PM
T5 Leaking front seal from overfill? BUGS Jeep CJ Forum 12 03-22-2006 07:17 PM
