Leaking fuel pump inlet hose - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Leaking fuel pump inlet hose
The Original 3/8" Ruffstuff Diff Cover!Save 17.76% for the 4th of july with ruffstuff specialtiesUCF Independence Day Savings... Save 15% today!
Unread 06-29-2015, 08:20 PM   #1
richeyb
1979 CJ5
79 jeep cj5 V8 hose going intO the fuel pump has become mushing and. Started leaking. The rubber hose runs about 4 ft to the fire wall and connects to a metal fuel tube...a crimp connection is used to connect to the tube. I would like to remove the crimp clamp and just put in a new 4 ft section.
What's best way to disconnect the crimp connection. It's down a couple feet along the fire wall.
Thr return vent line also appears to be worn.... Is the vent under pressure? Can it leak or should I replace both hoses?
Any help is appreciated!
bRichey
richeyb is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 05:13 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Just cut and pry the old hose clamp off and replace it with a new one.
Any suspected leaking or deteriorating fuel lines should be replaced, both supply and return.
Be sure to get the fuel-injected rated hose. It holds up to e-blended fuels better.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 07:58 PM   #3
richeyb
1979 CJ5
Matt
Matt. thank you, I gibe it a try!
Richeyb
