Leak free differential cover gasket - JeepForum.com
 3Likes
post #1 of 19 Old 08-17-2017, 12:14 PM Thread Starter
cj7ole
What is the best combo of gasket/sealant for a leak free AMC 20 differential cover? Kentrol stainless cover. I'm tired of it marking its territory. Changed the fluid last fall, used a cork seal and black RTV, now have a very slow drip, a few drips per day.
'84 CJ7, '07 5.3 LMG Chevy, D300, 4L60e, 33's, 4.10, rear Detroit Locker, FG Tub, HOK Tangelo Pearl
Build: http://www.jeepforum.com/forum/f22/ole-jays-cj7-5-3-chevy-swap-1287392/
cj7ole is offline
post #2 of 19 Old 08-17-2017, 12:30 PM
82Laredo-7
I don't use a gasket, just a nice bead of grey rtv, let it sit for 5 minutes or so, then put the cover on.
82 CJ7 Laredo 4.2L w/T5, Weber 38, 3:30's w/32's
82Laredo-7 is online now
post #3 of 19 Old 08-17-2017, 12:42 PM
Blob
Lubelocker - hands down IMHO. No fuss, no muss (or mess), and no leaks.
Blob is offline
post #4 of 19 Old 08-17-2017, 01:25 PM
80cj
80cj's Avatar
1980 CJ5
I use a cork gasket and glue it to the housing with Permatex Aviation form a gasket. Been leak free for about 10 years.
keith460 and ShiJon like this.
80cj is offline
post #5 of 19 Old 08-17-2017, 01:26 PM
fromme
fromme's Avatar
1977 CJ7
If that cover has a very smooth and slick mating surface, scuff it up before resealing.
ShiJon likes this.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #6 of 19 Old 08-17-2017, 01:59 PM
gunsanddaisys
1979 CJ7
Know your torque values. Cork gaskets have no issues if both surfaces are flat and the proper torque values are used. They typically need no more than 9 ft lbs, though I don't know the exact value for a different cover. Too much torque lifts the gasket between fasteners and causes leaks.
gunsanddaisys is offline
post #7 of 19 Old 08-17-2017, 03:44 PM
skizriz
1978 CJ7
Money well spent. Especially if you are in to them often, as I am.
skizriz is offline
post #8 of 19 Old 08-17-2017, 04:08 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Did they change through the years?
I think mine just had a rubber ring like an o ring.
No leaks.
John Strenk is offline
post #9 of 19 Old 08-17-2017, 07:28 PM Thread Starter
cj7ole
Both the cork and rubber are available cheap (under $5) through most parts guys. The LubeLocker is in another whole world at $22. Hope it is worth it, I just ordered one. And bolt torque appears to be 20 ft-lbs. Thanks everyone for your input.
cj7ole is offline
post #10 of 19 Old 08-17-2017, 07:47 PM
CSP
Double check that the torque value isn't 20 inch-lbs.
CSP is offline
post #11 of 19 Old 08-17-2017, 07:47 PM
80cj
80cj's Avatar
1980 CJ5
No leaks.
Yup, same as mine. Rubberized cork ring,
80cj is offline
post #12 of 19 Old 08-17-2017, 10:13 PM
only in a jeep cj
LubeLockers here as well
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #13 of 19 Old 08-18-2017, 06:17 AM
keith460
Jeep. There's Only One
keith460's Avatar
Same as me, and is always leak free.
1984 CJ-7 Renegade
keith460 is offline
post #14 of 19 Old 08-18-2017, 07:45 AM
KevinCJ7Jeep
Give Permatex the right stuff a try.
KevinCJ7Jeep is online now
post #15 of 19 Old 08-21-2017, 11:55 AM Thread Starter
cj7ole
Just finished it. Drained and saved the almost-new fluid. Cleaned the diff surfaces with napha to degrease. Blasted the stainless cover with brake cleaner to degrease. Flattened the cover gasket surface on my 6"x48" stationary belt sander followed by 180 grit on a flat piece of hardwood. Used a screwdriver and putty knife to scrape old goop off the diff. Then flattened it (it was rusty) with the 180 grit-on-a-stick. Hit with with a small flap wheel on my drill. I noticed that the inner row of rubber on the LubeLocker didn't hit the surface, it overlapped the recess that the old cork gasket sat in and I could see daylight at the bolt holes. Not good, so I got a new FelPro cork gasket to fill that area and held it in place with Permatex anaerobic gasket maker. Then I installed the LubeLocker dry and torqued it to 20 ft-lbs in two steps. Filled it with a new quart of Valvoline Synthetic 75W-90 GL5 lube followed by 1.4 quarts of the saved and filtered lube. (Paint filter, 190 micron). If that doesn't fix the drip, I don't know what will.
cj7ole is offline
