leafs and coils - JeepForum.com
post #1 of 2 Old 05-29-2002, 12:07 PM Thread Starter
NC74CJ
NC74CJ's Avatar
Post leafs and coils
Ever since I bought my 74 CJ5 a couple years ago it has had both coil and leaf springs front and rear. Im sure this isnt the factory setup, but would there be any advantage or disadvantage for me to keep it like this?
Bill
A stroke bolder, a pinch better.
NC74CJ is offline
post #2 of 2 Old 05-30-2002, 06:20 AM
Bulletproofcj7
Post
Sounds like someone put an after market set of coil helper springs in, probably in an attempt to give some lift back to tired leaf springs. do they bolt to the axle housing with U-bolts and hit the frame at the bump stops?
They may interfere with articulation if you wheel it hard. Park the jeep on a level surface and measure the bumper height, pull out the helper springs and measure again, see if they make a difference.( i would get rid of them all together) They may also make the ride stiffer.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
Which add-a-leafs to get Jeepguy91 Jeep CJ Forum 1 08-27-2009 07:26 PM
yj leafs danbap Jeep CJ Forum 9 10-22-2008 10:39 PM
# of leafs? toddrod97 Jeep CJ Forum 1 07-28-2007 12:15 PM
leafs and such akuma Jeep CJ Forum 11 08-03-2004 12:22 PM
YJ leafs on a CJ5 domer1 Jeep CJ Forum 4 03-09-2004 12:28 PM
