are leaf springs supposed to separate when the car is jacked? - JeepForum.com
post #1 of 4 Old 08-15-2013, 04:38 PM Thread Starter
fishtruck
1987 YJ Wrangler
Dumb question.....
The back end drivers side of my 1986 CJ is sagging a little. The springs are 1988 YJ springs (SOA lift with revolver shackles).
I just jacked it up, and noticed the leafs are all separating, with a gap of about 1/8 inch or more between each one.
Is there supposed to be a bracket or retainer to hold them together?
fishtruck is offline
post #2 of 4 Old 08-15-2013, 05:35 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
They usually have a clip or two about midway between the axle and the shackle... More to hold them in line rather than together. Mine have been broken/gone for years now... The ubolts around the axle keep them from getting to far out of line.
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #3 of 4 Old 08-15-2013, 08:46 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Originally Posted by fishtruck View Post
Dumb question.....
As long as the leaves don't get misaligned within the pack (which is why the clips exist,) it's not a problem. I've seen the leaves separate on a number of vehicles when jacking by the chassis, no problem.
Worst case? I've had to tap the leaves back in line with the main and find clips to apply, because they were missing.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #4 of 4 Old 08-16-2013, 10:46 AM
Renegade82
1982 CJ7
Yep, my new OME springs will seperate enough to stick my finger between when it just has the weight of the axle on it, no tires or shocks. I believe the softer riding springs will do this more than the stiffer ones do.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
