Leaf Spring Replacement - JeepForum.com
post #1 of 32 Old 02-26-2010, 11:08 AM Thread Starter
nichboy
How can I tell if my rear leaf springs need to be replaced. (1972 cJ-5)
nichboy is offline
post #2 of 32 Old 02-26-2010, 11:17 AM
alex211
1995 XJ Cherokee
Are they broken or sagging?
95 xj bone stock for now
alex211 is offline
post #3 of 32 Old 02-26-2010, 12:03 PM Thread Starter
nichboy
I just bought this jeep, but looking at it from the side it appears the rear is alot lower than the front. I will try and post a pic. If I need to replace i need to order this weekend to get whitneys 20% off.
Thanks
nichboy is offline
post #4 of 32 Old 02-26-2010, 12:04 PM
alex211
1995 XJ Cherokee
If the rear is sagging then I would get some new springs, there may be couple broken leafs in the spring packs too.
alex211 is offline
post #5 of 32 Old 02-26-2010, 12:12 PM Thread Starter
nichboy
There doesn't appear to be any arch in the springs, they are just kinda flat.
Are those springs that difficult to replace. Thanks for the help
nichboy is offline
post #6 of 32 Old 02-26-2010, 12:16 PM
CjAl
1980 CJ7
do they mount on top of the axle or underneath?
CjAl is offline
post #7 of 32 Old 02-26-2010, 12:21 PM
alex211
1995 XJ Cherokee
Al CJs are spring under, the springs are fairly easy to replace. All you have to do is unbolt every thing and bolt the new ones in. Make sure you get some new U-bolts, bushings, and shackle bolts.
alex211 is offline
post #8 of 32 Old 02-26-2010, 12:27 PM
CjAl
1980 CJ7
I know they are spring under. But he mentioned they are flat so i'm thinking they are either WAY worn out or someone did a YJ spring over (since it's a flat spring) and it mabey just doesn't match up with the front ride height
CjAl is offline
post #9 of 32 Old 02-26-2010, 12:38 PM
godfather901
1979 CJ5
Cj Springs are 1" and something Yj springs are 2" and something (correct me if I'm wrong). Just measure the width of the springs and if they're 2"+ then it's ok if they are flat, opposite if they measure >2" (i.e. should not be flat). They do offer SUA YJ conversion kits so it's not a far fetched idea that you might have YJ springs.
1979 CJ5 304, 3spd USAF 32 Combat Comm "Anytime, Anywhere"
godfather901 is offline
post #10 of 32 Old 02-26-2010, 12:39 PM
alex211
1995 XJ Cherokee
Stock springs are 1 and 3/4 inches wide.
alex211 is offline
post #11 of 32 Old 02-26-2010, 12:41 PM Thread Starter
nichboy
They mount underneath the axle.
nichboy is offline
post #12 of 32 Old 02-26-2010, 01:05 PM
CjAl
1980 CJ7
then you need new springs. I've seen alot sag but i've never seen them totally flat
CjAl is offline
post #13 of 32 Old 02-26-2010, 01:28 PM
Scooter402
Then my rear springs must be waaaaay worn out...they have negative arch.
Scooter402 is offline
post #14 of 32 Old 02-26-2010, 01:39 PM
CjAl
1980 CJ7
ya you better fix that. need some 6"lift spring SOA on that mud racer. lol
CjAl is offline
post #15 of 32 Old 02-26-2010, 02:02 PM
Scooter402
Well, I've got some unknown springs that were pieced together from a waggy and something else, pretty sure they should ride okay. I know they have a decent arch to them, I'm actually going to go back to SUA on the rear, probably too on the front. I'm riding SOA right now front and rear, Chevy 4" springs on the front, stock CJ springs on the rear. These other springs I'm putting in have enough arch that it just might sit at the same height, probably about an inch or two lower in the rear. I'm not afraid of chopping the body up some. I'd actually prefer it to sit a little lower. It's fast enough and gets enough wheel speed that I'm not concerned with getting buried in the mud...it's a mud-skipper.
The front, on the other hand, I'm concerned about driveshaft clearance with the transmission pan, going to have to figure out what I'm going to do with steering, etc., when I go back to SUA...that, and it'll be a quite a trick figuring that one out on a Chevy front axle.
Leaf spring width for a 73 cj5 and spring over axle burtonboard180 Jeep CJ Forum 1 08-20-2009 08:11 AM
Leaf spring ID ragsdale Jeep CJ Forum 2 05-20-2009 06:16 AM
leaf spring help gatorpsd Jeep CJ Forum 4 02-06-2005 10:41 PM
has anyone used the yj leaf spring conversion for a cj and or axle over spring kits? rhino1 Jeep CJ Forum 0 08-11-2004 08:23 PM
leaf spring Q MillerHalrey76 Jeep CJ Forum 0 06-16-2004 08:17 PM
