Leaf Spring ID - JeepForum.com
post #1 of 5 Old 01-03-2014, 10:49 PM Thread Starter
bptactical
Leaf Spring ID
Any accurate way to tell if my springs (79 CJ7, 304, TH400) are aftermarket or factory?
They are 2.5" wide.
The reason I wonder is they have a pretty decent arch and if they are stock they sure have held up well.
Is it common for aftermarket companies to stamp them/mark them in some way?
They have been rattle canned over.
The PO thought they had been replaced right before he got it and he only put about 5K miles on it when he owned it.
bptactical is offline
post #2 of 5 Old 01-03-2014, 11:36 PM
only in a jeep cj
If they are 2.5" wide up front, then they are not the original.
The later CJ springs ARE stamped with numbers that indicate soft/standard/Heavy Duty in soft and hardtop/4 and 6 cyl engines CJ-7/and Scrambler.....so yes, a lot of combinations.
The springs from the late 70s/early 80s are numbered as well, but I don't know how to decode those.
The OEM springs are stamped into the metal of the smallest leaf next to the center pin.
Aftermarket springs usually have painted numbers on the topside of the longest or main leaf.
If you post a picture of the spring pack binder, I can tell you a good probability if its OEM or not.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 5 Old 01-05-2014, 11:55 AM Thread Starter
bptactical
Correction- rears are 2.5", fronts are 2.0"
post #4 of 5 Old 01-05-2014, 06:17 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
If they have marks from a metal break, they are Rough Country.....
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #5 of 5 Old 01-06-2014, 12:44 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by bptactical View Post
...They have been rattle canned over...
I'm no expert, but if the original painted markings or labels are no longer visible, you might be able to narrow it down by looking at some of the other features of the springs:
  • Are the ends 'military wrap' or not?
  • What kinds of brackets are used to hold the spring pack together?
  • Are there any plastic/teflon pads/plates between the leaves?
  • Are the leaves tapered toward the ends?
  • Are the bushings original? If so, what color are they?
Providing some clear, detailed, close-up and wide photos might be useful here.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
