Last Minute Ignition/Alternator wiring - JeepForum.com
post #1 of 10 Old 10-07-2013, 08:29 PM Thread Starter
WolfcreekCJ
1977 CJ7
I have been using a wiring diagram to upgrade my 1977 prestolite to an 82 Duraspark using parts from a donor jeep. I'm fairly confident with this swap as drawn. I run into a problem when I also want to upgrade my alternator to the Delco that also came with the donor. The factory diagrams for each vehicle don't Jibe so its hard to trace. Namely the brown resistor wire from the delco ends at a terminal block on the factory diagram. The Motorola Alternator wiring remains intact with its external voltage regulator. The Diagram for the duraspark upgrade uses this voltage regulator. Am I to understand that the delco alternator is internally regulated? If so , Do I need to lose the original voltage regulator and the accompanied wiring? If so , my ignition swap diagram goes to S**t. I Have searched in vain for the JeepHammer/Junkyardgenius alternator swap diagrams that spell this out. I understand that I could use a resistor /diode in place of the resistor wire. Part#? or what to ask the parts man for. Its Late here, Maybe some of you guys out west can answer this or point me in some direction/link.
All it takes is time and money
WolfcreekCJ is offline
post #2 of 10 Old 10-07-2013, 08:49 PM Thread Starter
WolfcreekCJ
1977 CJ7
Here is a poor attempt to ask an seemingly easy question. The Alternator is a "One poster " OE from the 82 I THINK. Im having trouble with posting a picture because the file is too large and its too late in the evening and my eyes are too bleary to figure it out.
post #3 of 10 Old 10-08-2013, 07:47 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Wolf,
It appears The Hammer's "Junkyard Genius" website, with all his handy diagrams, no longer exists. Bummer.
I'll take a stab at your question, but be forewarned, electrical is NOT my forte'. Hopefully John Strenk will chime in....
The Delco alternator is internally regulated, so the old external regulator and related wiring goes away. Below is the best diagram I could find of the Delco wiring. Note, this diagram shows the #2 sensing wire looping back to the battery terminal on the alternator. This article indicates that this configuration is OK, but not ideal. Instead, they suggest to run the sensing wire from #2 to the + terminal post on the solenoid.
Hope this helps,
Matt
Matt1981CJ7 is online now
post #4 of 10 Old 10-08-2013, 08:08 AM Thread Starter
WolfcreekCJ
1977 CJ7
Thanks Matt, This Helps . Off to work , but at least I can buy the diode now . With the external voltage regulator gone, I just need to hook up the resistor wire correctly. sorry for the wordy post it was late and I was frustrated.
post #5 of 10 Old 10-08-2013, 08:21 AM
Matt1981CJ7
1981 CJ7
You might want to pick up a fusible link, as well.
Matt
post #6 of 10 Old 10-08-2013, 07:30 PM Thread Starter
WolfcreekCJ
1977 CJ7
I have hooked up the wiring as per accompanied drawing. While fooling with some dash wires and headlights etc. the key was left in the run position and the resistor pot became Extremely hot. I s this normal? Would some Wiring Guru please check this diagram to see where the mistakes lie , if any. My jeep is wired exactly as shown here. The alternator has not been wired to a dedicated ground. Is this absolutely necessary or just a good idea. I am a day or so from trying to fire this POS and am concerned about that resistor pot burning up or frying the ignition box or something else. Thanks for taking the time to look.
post #7 of 10 Old 10-08-2013, 07:55 PM
John Strenk
John Strenk's Avatar
1976 CJ5
The ballast resistor getting really hot when the ignition is ON but the engine is not running is "normal" .
What you don't realize is that the ignition module is also overheating.. This is what kills the ignition module.
The alternator needs some way of grounding either through a dedicated ground or through several layers of rust and paint.
John Strenk is offline
post #8 of 10 Old 10-09-2013, 05:41 AM Thread Starter
WolfcreekCJ
1977 CJ7
Thank you Mr. Strenk. Someday this kind of stuff may be "old hat" for me but for now its a bit dicey. Amazing how a mismatched collection of old parts gets under my skin.
post #9 of 10 Old 02-12-2016, 04:44 PM
wally6151
Motocraft alternator wire
Your diagram does not say if you are using a Motorcraft alternator or not. if you are using a 70's Motorcraft alternator, the odd extra wire with the female blade connector was use for the choke thermal motor on the carburetor to open the choke up only when the engine is running, and provided 12 volts ac power to a indicator light to show the remote engine is operating properly.
wally6151 is offline
post #10 of 10 Old 02-13-2016, 06:32 AM
Matt1981CJ7
1981 CJ7
You are about 2-1/2 years to late to this party, Wally.
Matt
