"Last of a Great Breed" Registry - Page 7 - JeepForum.com
 7Likes
post #91 of 224 Old 01-21-2013, 01:53 PM
RamblingCJ
Originally Posted by RWise
But some folks only posted 5 digits, so is it 006175, 106175, 206175, or ?01675,,,,,,,,,,,,
It was 006175, which is pretty low.
My confusion is that there were only ~ 26,000 CJ7s built for this year but the vin numbers posted here blow this threshold out of the water. From the earliest vin to the last vin posted numbers over 100,000, but supposedly it should not exceed 26,000.
My vin is 076XXX, so with only 26,000 being built, vin numbers should not be below 050XXX if mine was the very last and they should not exceed 101XXX if mine was the first.
RamblingCJ is offline
post #92 of 224 Old 01-23-2013, 10:43 AM
Davis77Cj
1977 CJ7
and with this confusion finally brought up i want to thank AMC for being so great at keeping their impeccable records of what was done... not. anyways the more you dig the cooler it gets due to the element of mystery.
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #93 of 224 Old 01-23-2013, 11:25 AM
RamblingCJ
Haha! Too true!
post #94 of 224 Old 01-23-2013, 02:25 PM
REDnBLUES
1977 CJ7
This might jelp explain the vin mystery...or not. Vin numbers are not usually consecutive though.
http://www.nisrinc.com/include/common/VIN.html
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #95 of 224 Old 02-28-2013, 03:38 PM
Mr. Boh
You are forgetting all the other Jeep models Jeep produced in 1986 like the Cherokee, Comanche, J10, J20, etc, which accounts for the ~145,000 vehicles Jeep produced that year. They are all part of the sequential VINs as well. Whats more, not all 26,000 CJs rolled off the line one after another. So the CJs VINs are going to be scattered. Best I can tell from the VIN data I have, the D44 made it on the CJ somewhere between 050265 and 054173. if someone has a 86 between those two VINs and knows their axle, we could narrow it down even more.
Mr. Boh is offline
post #96 of 224 Old 02-28-2013, 04:09 PM
ecardona10
I caught the tail end of this but for what it's worth, I have an 86 with the Dana 44 and my vin is 113985.
ecardona10 is offline
post #97 of 224 Old 02-28-2013, 11:25 PM
RamblingCJ
Thanks for pointing that out and clarifying up a lot of my puzzlement.
post #98 of 224 Old 02-28-2013, 11:28 PM
RamblingCJ
That's one of the later numbers I've seen. I'm the second owner and the PO said he had to "special" order the jeep because there weren't any available.
post #99 of 224 Old 03-01-2013, 10:25 AM
jeep1000
There was some talk of '85 CJ7s having them, my last five digits are 70289. The PO painted it white with indoor paint so I don't know if I have the plaque. My original color was white. As for my rear end, it's covered in grease and people have told me AMC 20 and some Dana 44. It's a four speed and a 258 I6. Once I replace my rear Diff. Seal ill know if its a 20 or 44
Jonathan
'86 CJ7, I6 258 four speed manual. See ya on the trails!
jeep1000 is offline
post #100 of 224 Old 03-01-2013, 10:49 AM
Renegade82
1982 CJ7
If it's a round cover it's a 20. there's no mistaking it for any other axle. A 44 is more square-ish and a partial protrusion. The 20 is almost a complete half of a sphere.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #101 of 224 Old 03-01-2013, 10:54 AM
jeep1000
That's what I thought. Well, I have a 20. Thanks!
Jonathan
jeep1000 is offline
post #102 of 224 Old 03-01-2013, 01:02 PM
DutchJPR
I have a 86 CJ7, the last 6 digits are 124685.
Original it was a brown metallic 258ci, 5 speed, with D44 and first registered in Germany.
Dutch builds: http://www.jeepforum.com/forum/f8/dutch-build-1231816/
DutchJPR is offline
post #103 of 224 Old 03-01-2013, 09:14 PM
jeepnjeff1002
1982 CJ8
My first CJ was a 1986 CJ7 with the rear dana 44 axle. It had 111457.9 miles (still have the odometer) and the serial part of the VIN is 093929 (still have the VIN plates but no title). I never saw a Last of a Great Breed plaque so I don't know of it had one.
Unfortunately it was so rusted out I had to sacrifice it but many parts are going into my Scrambler, including grill, hood, and a few other accessories.
1982 CJ8 currently being rebuilt. AMC 360 V8, TF727, dana 60, 14 bolt, atlas II, build: http://www.jeepforum.com/forum/f8/jeffs-offroad-cj8-build-1320142/
jeepnjeff1002 is offline
post #104 of 224 Old 03-01-2013, 09:22 PM
letchcore
1983 CJ7
I believe at this point that the there were much more than the last few thousand that got the D44. I see 86 CJ's with D44's as much if not more than AMC 20's.
83' CJ7 "Strokie" Patriot blue, 4.6L, NSG370, D300, 4.56 gears, ARB's, Warn FF kit, OME Springs, 35in Kevlars.
83' CJ8 GM Torch red. 2.5in SkyJacker lift. Very stock.
83' CJ7 Slate Blue Met. 49k miles
04 Wrangler Rubicon. Stock
letchcore is offline
post #105 of 224 Old 05-03-2013, 01:04 PM
ryanlj
My 1986 cj7 has the dana 44, 5 speed, power steering, power brakes, tilt etc. It also has the "Last of a great breed" emblem located above the left speaker. The last 6 numbers of my vin are 143650. Any idea if thats one of the last one's?
ryanlj is offline
Ugg! Rugged Ridge "stock" length shackles actually 3/8" lift 1984Laredo Jeep CJ Forum 16 12-26-2011 04:12 PM
"Last of a Great Breed" wertyu78 Jeep CJ Forum 2 02-03-2010 12:04 PM
Will a 4" trailmaster lift and a 2" body allow for 35" baja claws. yojeep79 Jeep CJ Forum 13 08-19-2009 08:20 PM
JKS "Quick" or "Quicker" disconnects? cincyjeeprs Jeep CJ Forum 0 05-15-2009 09:33 AM
"Green Grease" or Lucas "Red N Tacky #2" Curt Reinhardt Jeep CJ Forum 3 07-16-2008 07:09 AM
