Laredo rocker trim bolt layout - Page 2 - JeepForum.com
post #16 of 33 Old 02-11-2013, 10:57 AM
CJ7ROB
Also any tricks on getting the old sliders out of the rocker molding channel? A few of mine seem frozen/rusted in there and won't budge. I don't want to mess up the molding, thanks.
CJ7ROB is offline
post #17 of 33 Old 02-11-2013, 11:15 AM
Quailguy
Okay, my 86 has 5 holes, all 1/2" from the bottom edge. Measuring from forward edge of the rear tire fender well, the first three bolts are 5 1/2", 15 3/8", and 25" on center. Remember all measurements are from the fender well, not distance between bolts. The two remaining bolts are measured from the rear edge of the front tire fender well; 2 1/2" and 7 1/4". So to clarify, I measured the first three back to front, the second two front to rear. Make sense?
Quailguy is offline
post #18 of 33 Old 02-11-2013, 11:58 AM
keith460
Jeep. There's Only One
keith460's Avatar
You should actually do it from the firewall or the split between the front fender and firewall, it's a straighter line.
1984 CJ-7 Renegade
keith460 is offline
post #19 of 33 Old 02-11-2013, 02:10 PM
Renegade82
1982 CJ7
Take a piece of stiff copper wire or a thin strip of sheetmetal and bend a 90 degree end on it about a 1/4" in. You may find another object that will work just as well. With it, clean out the track that the bolts slide in. Then spray out the remaining dust with carb or brake cleaner. Then spray the track and bolts with some penetrating oil. Let them soak a bit. Then take a flat punch and tap on the slide part of the bolt in the direction of the slot. They will break free. The alum. trim corrodes to the steel bolt plate. A little heat to the trim from the backside may help. (I assume your repainting these)
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #20 of 33 Old 02-11-2013, 02:28 PM
CJ7ROB
Cool thanks, I'll give that a try. Actually I want to get them powdercoated chrome.
CJ7ROB is offline
post #21 of 33 Old 02-11-2013, 03:44 PM
keith460
keith460's Avatar
The color really isn't a chrome like finish but rather a polished aluminum look that dulls even when sprayed with a clear coat powder. That color powder must be clear coated to prevent it from "graying".
Here's an example of Reflective Chrome powder coat that has not been clear coated but fresh out of the oven.
Looks good when newly applied but will turn a darker shade later.
Are the rocker molding pieces bright aluminum or anodized black? If bright finish, clean them up with some 00 steel wool and then have them powder coated a "ultra clear" coating. It will stay bright for a very long time or indefinitely as long as you don't use any harsh chemicals to clean it with and wax it once in awhile.
1984 CJ-7 Renegade
keith460 is offline
post #22 of 33 Old 02-12-2013, 07:10 AM
CJ7ROB
That trans looks sweet. On my search for rockers with no real scratches or dents I found a passenger side in bright alum. and the driver side in anodized black. They say the driver side ones are hard to find in good shape. Im going to either have them powdercoated or painted silver. Should go well with my metallic blue Jeep.
CJ7ROB is offline
post #23 of 33 Old 02-19-2015, 08:56 PM Thread Starter
auskier
1983 CJ7
I finally got my rocker trim done! I ended up filling and sanding all the dents and powder coating them the same hammertone black as my other trim. Now the BIG question, drill and install or leave them off. Pics of them are below as well as a couple of them with them next to the jeep and scopula without. Sorry for the bad light, to cold to get outside
auskier is offline
post #24 of 33 Old 02-19-2015, 08:59 PM Thread Starter
auskier
1983 CJ7
Posting from iPad , only 1pic will load
auskier is offline
post #25 of 33 Old 02-19-2015, 09:03 PM Thread Starter
auskier
1983 CJ7
Without
auskier is offline
post #26 of 33 Old 02-19-2015, 09:32 PM
Mortgage-payer
1976 CJ7
Originally Posted by BlkCJ7Laredo View Post
I do see someone on eBay is now selling the T bolts at a better price than what was previously offered. He appears to have a lot of the other hardware on CJ's as well even though some of his items marked as "Correct" really aren't exactly like the originals. Also the grille mount rubber he has appears to have poly bushing instead of the "Correct" original rubber.
http://www.ebay.com/itm/New-Jeep-Roc...item2c6bba0216
Most of his stuff looks like it was sourced from McMaster-Carr
I call it a distributor, not a dizzy.
Mortgage-payer is offline
post #27 of 33 Old 02-19-2015, 09:38 PM
only in a jeep cj
Looks good, I personally don't care for the nerf bars and find them a little redundant if running the OEM rockers.
I would run the rocker trim only.
IF your wanting to go stock (or close to it), the Laredo's used black rocker trim and the Renegades used the bright" or silver finish.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #28 of 33 Old 02-20-2015, 04:38 AM
keith460
keith460's Avatar
I always liked the OEM rockers and would install them.
Holes need to be drilled in the body tub and front fender to mount them.
1984 CJ-7 Renegade
keith460 is offline
post #29 of 33 Old 02-20-2015, 08:59 AM Thread Starter
auskier
1983 CJ7
I'm running the nerf bars so I can and so the wife can get in. Functional.
auskier is offline
post #30 of 33 Old 02-20-2015, 12:00 PM
JeepdaddyRC
1983 CJ5
I like the contrast between the gloss black paint on the body and textured black rocker trim and fender flares. Very nice touch!
JeepdaddyRC is offline
