laredo courtesy light bracket broken! - JeepForum.com
post #1 of 8 Old 11-11-2013, 07:16 PM Thread Starter
I6CJ7
The plastic housing is part of the assembly that clips the courtesy lights to the dash, broke... The plastic lense comes off to replace the bulb but the rest seems to be one piece, and i don't see any way to replace the light without clipping the wires, ordering a new one and creating connectors to reattach the wiring.
Is this right? Or am I missing something simple?
I6CJ7 is offline
post #2 of 8 Old 11-11-2013, 09:26 PM
lucdog
lucdog's Avatar
1980 CJ5
I would check some junk yards, CJ's wernt the only Jeeps these lights were used on, My '84 Grand Wagoneer has the same lights. And if the GW did, J trucks probably had the same. ( upgraded models)
Thanks for this thread, I'm stripping the GW before it goes to the scrap yard, didnt even think about the lights.
Are you famiar with how the lights operate.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 8 Old 11-11-2013, 11:09 PM Thread Starter
I6CJ7
Familiar how? I know you turn the headlight switch to activate them. Other than that i can't see how they come apart or can be replaced without cutting them from the harness
I6CJ7 is offline
post #4 of 8 Old 11-12-2013, 05:10 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I thought the bulb should be replaceable like a normal bulb but the harness is one long piece. I'll have to look at mine again.
John Strenk is offline
post #5 of 8 Old 11-12-2013, 06:23 AM Thread Starter
I6CJ7
Yeah, i know the actual bulb is replaceable, you twist the little lense covering and it comes off for access. But somehow I guess the assembly is one piece made into the wiring, which just doesn't make sense.
I6CJ7 is offline
post #6 of 8 Old 11-12-2013, 06:47 AM
lucdog
lucdog's Avatar
1980 CJ5
Familiar with how the electrical part works. The lights have a constant 12 volts positive. When the headlight switch is turned so the lights come on, the switch sends 12 volts negitive to the bulb. I wanted to mention this to insure proper connections if you need to wire in a new light.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #7 of 8 Old 11-12-2013, 06:49 AM
John Strenk
1976 CJ5
It's one long piece as long as the dash with two plugs on one end.
I've separated the harness from behind the dash before.
post #8 of 8 Old 11-12-2013, 12:38 PM
NoNative
Try J&W Auto Wreckers in CA. 800 924-9732 or sales@jwjeep.com. I've bought several hard to find parts from them including what you're looking for. Their prices are fair and they have just about everything. Happy hunting.
Taylor
1986 CJ-7 Laredo, 258, AX15, AC Dana 30/44, Ox Lockers, Howell TBI, DUI, 4.5" RE YJ Springs, 1.25" BL, clocked & twin-sticked Dana 300 with Lomax 4-1, 4.10s, 33s, PB, 8000# winch, YJ Roll Bar, Factory 20 gallon tank.
1984 CJ-7 Renegade, 258, T4, AC, Howell TBI, DUI, 2.5" OME YJ Springs, 3.53, 31s, PB, Warn bumpers & 8000# winch, Factory 20 gallon tank
1984 CJ-7 Renegade, 258, Auto, AC, 3.31s, PB, Factory 20 gallon tank, Bone stock except for 31s
NoNative is offline
