Krylon fusion problem - JeepForum.com
post #1 of 30 Old 11-27-2011, 11:18 AM Thread Starter
chopki1
1981 CJ7
Hey guys. I just painted a set of brown sun visors with Krylon fusion satin black to go in my CJ. The problem I have is they have been hanging to dry since yesterday evening and are still very sticky. Its been over 12 hours since i painted them and if i pressed them to the wall they would probably stick for a second or two before falling. They are not tacky as in the paint doesnt smudge when touched they are just sticky like fly paper or something.
I am just wondering if any of you have had this issue. Or if maybe i got a bad can?? My prep was just a simple clean and wipe down with windex. Is it possible the windex chemically reacted with the paint? Thanks for any help or info or a possible solution.
chopki1 is offline
post #2 of 30 Old 11-27-2011, 11:21 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
high humidity maybe? im no paint pro but that could be it.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #3 of 30 Old 11-27-2011, 11:50 AM
gmakra
Could take a couple days I woundnt sweat it.
gmakra is offline
post #4 of 30 Old 11-27-2011, 12:40 PM
bamasteeler
I had same problem trying to paint the black rubber cover over a light that I have mounted to my rear bumper. Days and days and it never dried fully!!
I'd use some thinner or something and remove it and I believe autozone carries a fabric type paint in spray can. Worked great on my dash pad and seat belts.
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #5 of 30 Old 11-27-2011, 01:36 PM Thread Starter
chopki1
1981 CJ7
Thanks for the replies guys. definately dont WANT to strip and repaint I was thinking maybe take a couple coat hangers and make a "rack" to hold them up off of the rack in the oven,set my oven to maybe 100 degrees and set them in there with the door open for a while. They should hold up to the heat right? It gets 100 outside in the summer and they dont melt. LOL it probably will smell the house up a bit but I am single at the moment so thats no big deal. I think thats what i will try and will report back with the results since I'm not the only one who has had this problem. maybe it can help somebody else out.Thanks again guys.
chopki1 is offline
post #6 of 30 Old 11-27-2011, 01:40 PM
skizriz
1978 CJ7
I'd try a hair dryer before I'd stick paint in a good oven. I've used Fusion plenty of time and have never had a problem. It had always been mid summer though. I painted my steering box with Rustolium the other night, and it took two days to dry because of the cold weather, and I still got paint on my hands when I installed it.
skizriz is offline
post #7 of 30 Old 11-27-2011, 02:09 PM Thread Starter
chopki1
1981 CJ7
Did you see the part where i said im single at the moment? Lol no hair dryers here bud I guess I can wait until tomorrow after work and see if they cure by then. Right now they are hanging from a shelf in my laundry room so hopefully they just need some time. I did do some laundry last night and today...maybe the dryer ran the humidity up a notch ot two??
chopki1 is offline
post #8 of 30 Old 11-27-2011, 02:19 PM
skizriz
1978 CJ7
LOL ! You never know about some people these days.
skizriz is offline
post #9 of 30 Old 11-27-2011, 02:23 PM
The_Blacksmith
1993 XJ Cherokee
about the last thing in the world id prep something with is windex. just saying, that could be an issue.
Thanks Chris!
The_Blacksmith is offline
post #10 of 30 Old 11-27-2011, 02:27 PM
Lordwrench
1978 CJ7
Fusion is for painting plastic.
Lordwrench is offline
post #11 of 30 Old 11-27-2011, 02:57 PM
jeepwhore
x2 on both of these points. If it won't cure properly inside your house after two days I'd say something is wrong. I could see that being the case in the garage where it's cooler but your house should be warm enough for it to cure quickly and properly. It's either because of the prep with windex or using the Krylon. Be prepared to strip it off and re-coat it with upholstery paint if you don't see improvement in the next day or so.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #12 of 30 Old 11-27-2011, 03:02 PM Thread Starter
chopki1
1981 CJ7
Sadly... This is true...just not in my case
The reason for just the windex wipedown was it says right on the can "For weathered surfaces-Wipe surface down with ammonia based cleaner". not really sure if windex is "ammonia based" but the bottle I have has ammonia in it. The results look great,nice even coat and seems to be sticking so far as none has come off on my fingers.The only problem is it doesnt seem to be curing. But as mentioned earlier that may just be due to the time of year and possibly excess humidity. I decided to go ahead and try one in the oven since i have another I can use if this one goes up in flames
I just cracked the dial on the oven until the preheating light came on and thats as high as I'm going with the temperature. Also I am keeping a very close eye on it(checked it twice just in the time it took me to type this).Hopefully it wont take more than an hour or so to know if this is going to work. I have never baked CJ sun visors before...any body have a good recipe?
chopki1 is offline
post #13 of 30 Old 11-27-2011, 03:04 PM
ejeeperguy
1982 CJ7
Mine took a week to dry completely.I thought the same thing ;that i would have to redo it. Just leave it alone and work on something else.
ejeeperguy is offline
post #14 of 30 Old 11-27-2011, 03:05 PM Thread Starter
chopki1
1981 CJ7
Yes I realize that but the sun visors are a Vinyl type material not cloth. So I was assuming they were a plastic based material. Am I wrong on that?
A week? wow. Well at least this is not unheard of...now to find something else to work on...shouldn"t be to hard to do on a CJ right?
chopki1 is offline
post #15 of 30 Old 11-27-2011, 03:05 PM
The_Blacksmith
1993 XJ Cherokee
lol I woulda just put them infront of a space heater
Thanks Chris!
arb problem ------ help 2cjs Jeep CJ Forum 9 07-10-2007 03:56 PM
What is this...problem! valkadesh Jeep CJ Forum 11 07-02-2007 04:05 PM
CJ 3B Gas problem Shenandoah Jeep CJ Forum 5 06-25-2007 10:21 AM
t-150 problem cormech Jeep CJ Forum 0 06-01-2006 10:24 PM
Please..anyone...HELP ME with my CJ Problem!! brownrecluse Jeep CJ Forum 21 10-11-2005 08:36 PM
