Know what plugs into this? - Page 2 - JeepForum.com
post #16 of 43 Old 03-20-2013, 07:12 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by keith460 View Post
That orange and black wire plug into another pigtail plug in the same wire loom that goes back to the taillights. It should be right next to or around the parking brake pedal assembly and not the headlight switch. It is in fact for the dome light on the Hardtop equipped Jeeps.
Keith,
I've only found the male half of the connection that you are showing. It leads to to back of the tub.
I can't find the female side that it connects to. it's a stock unaltered 1981 wiring harness.
I hate electrical crap.
Matt
Matt1981CJ7 is offline
post #17 of 43 Old 03-20-2013, 07:17 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
you can get a light switch with a dome light spade connector on it, or install a separate Dome Light Switch..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #18 of 43 Old 03-20-2013, 07:21 PM
Matt1981CJ7
1981 CJ7
Are you saying I may not have the proper light switch, since my CJ didn't originally have a hardtop?
Matt
post #19 of 43 Old 03-20-2013, 07:27 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
Matt
I would imagine not many CJ's came with that style light switch, mostly Cherokee's, wagoneers, etc.. trucks.. most of the utility vehicles (CJ, YJ, etc) came with door pins.. and they work fine, except when you just want to turn on the inside lites without opening your door (if you have one).. you could probably get a Cherokee switch and adapt it easily.. basically lights, courtesy (gauges and so forth), and dome (interior).. same outputs except their switch has that ground switch contact in the click position when you turn the knob all the way.. as far as why its located where it is, rather than up near the lamp switch, its female counter part goes to the door pins.. but to put it to a different light switch, we're only talking inches..
frhrwa is offline
post #20 of 43 Old 03-20-2013, 07:33 PM
fourbtgait
1930 MK Patriot
My 1983 CJ7 with factory hardtop/doors, inside under dash and hardtop courtesy lights work off the dash headlight switch, no door pins.
fourbtgait is offline
post #21 of 43 Old 03-20-2013, 07:39 PM
Matt1981CJ7
1981 CJ7
I have the under-dash lights, with dimmer, which I believe was part of the optional "convenience package".
My wiring harness has the dome light connection wired to the back of the tub, with plugs on each end, but it's not connected to anything under the dash.
Ugh...
Matt
post #22 of 43 Old 03-20-2013, 07:42 PM
lucdog
lucdog's Avatar
1980 CJ5
Matt
I don't that would be the case. My '78 with a hard top doesn't have a dome light. It does have the under dash lights. I'm thinking its the same switch, and has the 2 added wires somewhere. If there not present you could tap into the under dash light wiring. Remember, the under dash lights have a constant 12 volts postive, the ground gets activated by the switch.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #23 of 43 Old 03-20-2013, 07:48 PM
Matt1981CJ7
1981 CJ7
Bill,
I'm at a loss. My wiring harness has all the necessary connections for the dome light, but nothing to connect to.
Matt
post #24 of 43 Old 03-20-2013, 08:03 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
Bill,
Matt
from reading the above posts, you could just pick up one of their type light switch, wire to it.. or.... you can put in door pins, actually, make that and/or.. did you get the FSM?
frhrwa is offline
post #25 of 43 Old 03-20-2013, 08:12 PM
lucdog
lucdog's Avatar
1980 CJ5
I have a strong feeling the switch is the same one. The dome and under dash lights work off the same switch. The dome light doesn't come on any other way. Matt has the under dash. I have a feeling the harness plugs In With the existing lights, I check tomorrow. If there's a seperate harness I take it out, and you can have it. I sold the Jeep, sans plow and hard top.
This one.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #26 of 43 Old 03-20-2013, 08:27 PM
Matt1981CJ7
1981 CJ7
Thanks Bill,
iI's not a big deal, but I would like to get the dome light working. It's one of the last things on my list...
Matt.
post #27 of 43 Old 03-20-2013, 08:55 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
Matt, my dome light comes on when I open my door, left or right, and I put a mercury switch on the back hatch to turn them on also.. haven't looked into the light switch contact to see if my switch has the connection.. easy enough to check, in fact, I just replaced it, so I have the old one on the bench.. I'll see if there is a ground contact turning it all the way in one or the other direction..
frhrwa is offline
post #28 of 43 Old 03-20-2013, 09:00 PM
Matt1981CJ7
1981 CJ7
There is no door contact switch on my CJ.
But, thanks.
Matt
post #29 of 43 Old 03-20-2013, 09:07 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
But, thanks.
Matt
go down to your local pic-a-part, take your small crescent and a screwdriver, some are held on with a nut, some have a screw, take a couple.. they'll probably charge you 50cents each if anything.. drill, install, hook the wire up that you have hanging there, you can test it by touching it to ground.. one will have 12volts through the light bulbs.. the other is looking for a ground.. look at the drawing, the black lead is the one I used..
frhrwa is offline
post #30 of 43 Old 03-20-2013, 09:10 PM
fourbtgait
1930 MK Patriot
Works good for hard doors, but soft or no doors with a bikini top.....
