Quantcast Knocking after warm up - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Knocking after warm up
Old 04-20-2008, 06:46 PM   #1
RobP
Hello, My 83 CJ7 has started knocking after it warms up. Did it today for the first time.
Problem: Knocking after 20 miles or so or after warmed up.
Sounds like a rod knock. Not burning oil, I recently did a resoration and had the engine on a stand. Replaced valve seals, rear main seal, valve cover.
NEED YOUR HELP!!! I want to nip this right away.... I do not see any physical signs of trouble from the outside of the engine. Oil pressure seems to be good (I call 47 to 51 good)
Rob
Any suggestions?????????????????
RobP is offline   Reply With Quote
Old 04-24-2008, 08:14 PM   #2
RobP
still need help
need helpdkj;laffffffffffffffffffffffffffffffffffffffff ffffffffffffffd
Old 04-24-2008, 10:24 PM   #3
Duble-it
Drain one quart of oil from your engine then replace that quart withh tranny fluid (this will add detergents to your Engine) then run your engine for 30 min or so. If it is a stuck part causing the knock, ie: a lifter, this process will help it become unstuck. This is where i'd start before pulling my engine apart. Good Luck
1986 CJ-7 that doesn't like to sit in the driveway.
LATE FOR WORK, EARLY FOR JEEPIN'
Duble-it is offline   Reply With Quote
Old 04-24-2008, 10:27 PM   #4
Duble-it
After you try that if it works change your oil before 200 miles or so. You don't want to go too long with tranny fluid in your engine.
Old 04-25-2008, 11:16 AM   #5
cwajciec
If it is a rod knock you might want to try Lucas oil Stabilizer to help quiet the sound. If this works, it will only be a matter of time before you need to replace rod bearings though. If you keep using Lucas it might be a long time before you need to rebuild.
cwajciec is offline   Reply With Quote
Old 04-25-2008, 11:54 AM   #6
biozombie
Originally Posted by RobP View Post
... Oil pressure seems to be good (I call 47 to 51 good)
Rob
What is the pressure while hot & knocking ?? Did you mess with the lower end at all while you had it on a stand. The DSPO of mine for some reason decided to swap out the rod bearings on a reground crank with standard size instead of undersize bearings... started knocking once warm.
biozombie is offline   Reply With Quote
Old 04-27-2008, 07:16 AM   #7
RobP
knock knock
Thank you all for your replies.
I'll get to it!
rob
Glock Forum
