killing rust? - JeepForum.com
post #1 of 5 Old 01-08-2012, 02:00 PM Thread Starter
b-dog
killing rust?
i have been repairing the rusted out spots on my 85 cj7. basicly at all rollbar bolt points and floor pan. a lot of what i am doing is cutting out what the po tacked over the rusty spots. there is also some surface rust and slight pitting in some spots in the tub. should i wirewheel, clean well and prime? also i see advertised rusty metal primer. is this better?
b-dog is offline
post #2 of 5 Old 01-08-2012, 02:01 PM
Area.3.Fiftyone
IMO: None of that rust converter stuff works.
The only way to get rid of rust is to cut and weld in new metal and pray that it doesn't eventually come back from the other side where you can't protect the newly welded panel.....
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 5 Old 01-08-2012, 02:31 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Well, I wouldn't disagree with Stan the Paint Man, he's got way more experience than I do.
But, I'm currently restoring my tub and I've been using a product called Rust Mort. It's phosphoric acid based and chemically reacts with the rust, turning into a black ferric phosphate, which then can be painted over. I've used it thru-out my tub. It's a clear liquid that you just paint over the rust and let dry.
Almost instantly, it turns the rusted area black. Then, as it dries, it turns a more grayish sheet metal color. Here's a shot of one of my floor pans right after applying the Rust Mort directly over the surface rust. The second pic is after it dried and a light coat of metal glaze was applied.
I can't say how long it will last, but it sure seems to work as advertised, so far.
Matt
Matt1981CJ7 is offline
post #4 of 5 Old 01-08-2012, 02:39 PM
pacmanCJ5
1978 CJ5
I agree 100%, my buddies nicknamed my CJ "Rusty Thunder". Needless to say i have tried alot of that crap and the only way to cure it is with sheet metal and a MIG with some .023 wire in it. make sure to primer all the spots you cover up as well. Mine is looking more like "Patch" now but my floors are solid!
pacmanCJ5 is offline
post #5 of 5 Old 01-08-2012, 02:40 PM
pacmanCJ5
1978 CJ5
Agree with Stan the Paint Man that is!
Exhaust is killing me. Please help. razor2264 Jeep CJ Forum 14 09-30-2011 05:00 AM
CJ7 Killing Me LVCapo Jeep CJ Forum 73 08-25-2011 09:51 PM
Is The Heat Killing Anyone Else? JeepHammer Jeep CJ Forum 52 07-15-2011 06:36 PM
Am I alone?? This is killing me cobbcj7 Jeep CJ Forum 27 05-28-2009 04:06 PM
Something killing Optimas..... ollietonk Jeep CJ Forum 18 11-14-2007 09:36 AM
