Key lock cylinder won't turn to start/run - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Key lock cylinder won't turn to start/run
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 10-05-2009, 12:58 PM   #1
mitchmoody
I'm new to the forum and here's my first question. I have a 1984 CJ7, 258, 5 speed with a tilt steering wheel. Yesterday I couldn't move the key from the run position to the lock position although I could turn the engine off. Wtih some luck I did finally get to the locked position and was able to get the key out. Now I can't get to the start position! Do you think replacing the lock cylinder will solve this problem or there something else going on inside the steering column? Thanks for any help.
mitchmoody is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 01:28 PM   #2
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I just slap or hit the column and it unlocks the key position, but I can always start or stop the Jeep
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 08:36 PM   #3
Bubba Ray
Look for info from John Strenk on this. He did a great pic filled info guide on this.
Bubba Ray is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 12:46 AM   #4
OldSkull
1980 CJ7
Originally Posted by mitchmoody View Post
........ Now I can't get to the start position! Do you think replacing the lock cylinder will solve this problem or there something else going on inside the steering column? Thanks for any help.
It may be that the ignition lock rack has broken and is jammed in the column. If you do a search for "motormite 82311" you should find the parts I am talking about. The tilt column has a sort of rack and pinion setup. I have a post on or about 9-26-09.
304 - T176 - D300 - D30 - M20 - 4" Superlift - 35-13.5x15 Krawler T/A's - TJ Flares - Team Rush - MSD 6A - Cavalier Seats
OldSkull is offline   Reply With Quote Quick reply to this message
Unread 10-20-2009, 11:36 AM   #5
mitchmoody
I took the key cylinder out only to find out it was the ignition switch. I didn't realize that the connection was mechanical. Thanks for your advise.
Unread 10-20-2009, 11:40 AM   #6
bentshackle
1983 CJ7
Yeah there is a rod that runs down to the ign switch. (at least on the non tilt ones)
The whole system is a pain.
Cheers,
BS
bentshackle is offline   Reply With Quote Quick reply to this message
