Key lock cylinder won't turn to start/run - JeepForum.com
post #1 of 6 Old 10-05-2009, 12:58 PM Thread Starter
mitchmoody
I'm new to the forum and here's my first question. I have a 1984 CJ7, 258, 5 speed with a tilt steering wheel. Yesterday I couldn't move the key from the run position to the lock position although I could turn the engine off. Wtih some luck I did finally get to the locked position and was able to get the key out. Now I can't get to the start position! Do you think replacing the lock cylinder will solve this problem or there something else going on inside the steering column? Thanks for any help.
mitchmoody is offline
post #2 of 6 Old 10-05-2009, 01:28 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I just slap or hit the column and it unlocks the key position, but I can always start or stop the Jeep
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #3 of 6 Old 10-05-2009, 08:36 PM
Bubba Ray
Look for info from John Strenk on this. He did a great pic filled info guide on this.
Bubba Ray is offline
post #4 of 6 Old 10-06-2009, 12:46 AM
OldSkull
1980 CJ7
Originally Posted by mitchmoody View Post
........ Now I can't get to the start position! Do you think replacing the lock cylinder will solve this problem or there something else going on inside the steering column? Thanks for any help.
It may be that the ignition lock rack has broken and is jammed in the column. If you do a search for "motormite 82311" you should find the parts I am talking about. The tilt column has a sort of rack and pinion setup. I have a post on or about 9-26-09.
304 - T176 - D300 - D30 - M20 - 4" Superlift - 35-13.5x15 Krawler T/A's - TJ Flares - Team Rush - MSD 6A - Cavalier Seats
OldSkull is offline
post #5 of 6 Old 10-20-2009, 11:36 AM Thread Starter
mitchmoody
I took the key cylinder out only to find out it was the ignition switch. I didn't realize that the connection was mechanical. Thanks for your advise.
post #6 of 6 Old 10-20-2009, 11:40 AM
bentshackle
1983 CJ7
Yeah there is a rod that runs down to the ign switch. (at least on the non tilt ones)
The whole system is a pain.
Cheers,
BS
bentshackle is offline
78 cj5 cylinder lock pwright1962 Jeep CJ Forum 0 03-17-2009 10:20 AM
lock cylinder ? dalefan388 Jeep CJ Forum 9 01-06-2009 06:34 PM
CJ5 cylinder lock SQF1 Jeep CJ Forum 0 12-05-2006 10:36 AM
ingintion lock cylinder 76 nerdboy0c0 Jeep CJ Forum 3 03-09-2006 11:20 PM
ignition lock cylinder certifiablejeep Jeep CJ Forum 4 05-10-2004 11:54 AM
