Key ignition issues - JeepForum.com
post #1 of 7 Old 11-17-2011, 08:43 PM Thread Starter
dvfr750f
Key ignition issues
My key is very difficult to turn. ANy ideas? I am rying to dissasemble the colun to replace the lock cylinder and cant get past this thing!!!! HELP!?
dvfr750f is offline
post #2 of 7 Old 11-17-2011, 09:15 PM
mopar346
More than likely the rack and septor I think it's called. It is the gears behind the key cylinder that moves the actuator rod to the ignition switch. Here is a picture but you can get them in the help section of most parts houses for $12 or so.
http://thejeep.com/shop/HARD+PARTS/S...LT+WHEEL+.html
Careful your character's showing
mopar346 is offline
post #3 of 7 Old 11-17-2011, 09:38 PM
har99
1979 CJ7
Make sure your cover ring around the column isnt putting pressure on the column. Im taking about the ring that covers the extra space on your dash. I know it sounds crazy but mine was pinching down causing my switch to bind! You need a steering wheel puller for the thing in your picture to remove it, unless you re-attach your wheel to it and pull really hard!!!!!!!!!But puller is best!
har99 is offline
post #4 of 7 Old 11-17-2011, 09:43 PM
CJuncky
1981 CJ5
If I remember correctly you will need a puller to get the next piece off the shaft. Look very closely because there may be a keeper ring. if so it will have to be removed before you use a puller.
81 CJ5 258/T18/dana20/ARB locked diffs/33's
80 CJ7 258/auto/d 44 diffs/ 4" lift/rebuild started 80 CJ7 #2 stock(sold)
82 CJ7 stock DD
CJuncky is offline
post #5 of 7 Old 11-17-2011, 09:44 PM
har99
1979 CJ7
If its your rack and sector like mopar346 said, this link right here can help you with that.
http://www.jeepforum.com/forum/f8/he...inder-1258072/
har99 is offline
post #6 of 7 Old 11-17-2011, 09:47 PM
mopar346
Just realized you had a picture, har99 is correct, steering wheel puller is the way to go. Then you are going run into the locking plate and you will need this tool. I have made make shift ones in the past but you can pick one of these up fairly cheap.
http://www.mytoolstore.com/kd/kdsusp04.html
It's about half way down the page. You don't have a tilt column so that should be the extent of the special tools.
mopar346 is offline
post #7 of 7 Old 11-17-2011, 10:02 PM
har99
1979 CJ7
Here is another helpful link I have used in the past, its a step by step ignition teardown with pics.
http://street2mud.com/webfiles/Key%2...t%20Column.pdf
har99 is offline
Electrical issues with ignition???Easy fix? CaliDaze Jeep CJ Forum 5 01-19-2010 07:37 PM
Electrical issues with ignition???Easy fix? CaliDaze Jeep CJ Forum 0 01-18-2010 08:21 PM
ignition issues seedubau Jeep CJ Forum 0 07-11-2009 03:25 PM
Ignition Timing Issues gonzo73 Jeep CJ Forum 7 11-06-2007 06:40 PM
Ignition Issues bdub Jeep CJ Forum 7 08-29-2006 03:47 PM
