Originally Posted by elkhuntrwinn
Also what is the wire that comes out of the bottom of the intake manifold? Where does it hook up and is it important?
Probably a manifold heater, used to help vaporize the fuel until the engine heated up. Better emissions when cold and faster warm up.
Do I need the EGR valve setup? or can it be bypassed?
Not needed. Used for bringing combustion temps down, again emission related.
Mine is pretty simple. I have the vacuum for the advance and for vapor purge from the charcoal canister, PCV hoses, and the bare minimum for wiring (alt, ignition, temp and pressure senders). I don't have a current picture. The key is taking your time, especially on the wire loom. Don't tape it up until have everything done.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA, 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, trying to keep it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
