Justa 68 CJ5 - JeepForum.com
post #1 of 67 Old 02-19-2014, 10:01 PM Thread Starter
Texsun
Justa 68 CJ5
Figured I would say hello here Long story short, this was a craigslist find! The guy I purchased this from was having a tough battle with cancer God Bless him and his family! I must say that I am proud to own this, and look forward to many trips! Best part is that it fit in the garage and the wife did not get mad!
The good stuff!
1968 CJ5
283 V8 with TBI
SM 420 tranny
DANA 300 Twin Stick with 4:1
Wheelbase stretched 4"
Dana 44s from a SCOUT with 4.88s and Detroits, chromolly
Final Crawl ration 128:1
35x12.50r15 Goodyear Wrangler MTRs "old style"
mounted on Bart Racing Bead Locks
Custom "classic" Bumpers with a warn m8000
Crossover steering linkage with heim joints.
Custom Roll Cage, best top seats, tilt steering etc.
Texsun is offline
post #2 of 67 Old 02-19-2014, 11:46 PM
dg6772
Cool looking rig. Can we get some better pics so we can get a good look at it. ...
Dave in Muskegon using JeepForum
dg6772 is offline
post #3 of 67 Old 02-20-2014, 03:37 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
289 Ford or 283 Chevy???? I'm diggin' the small block whether Ford or Chevy.
"In the end...It's all Hack."
HackFabrication is offline
post #4 of 67 Old 02-20-2014, 07:54 AM Thread Starter
Texsun
The PO said 289, however it takes a PH8 fram filter, which is a ford filter if I am not mistaken. The tranny is a SM420 is that a Chevy or Ford? Sorry for my ignorance, the CJ and chevy/ford motors are a new concept for me! I will get more pictures and everything tonight when I get off work. I was quite surprised that it fired right up this morning, had to make sure before I went to work. Luckily this will be a weekend/fishing/hunting/crawler toy!
The Jeep is covered in a layer of dust, cant wait to pretty er up!
Texsun is offline
post #5 of 67 Old 02-20-2014, 09:30 AM
Tommy R
Tommy R's Avatar
If the distributor is located at the front of the motor, it's a Ford. If it's near the firewall, Chevy. Also, the exhaust ports will be evenly spaced on the Ford small block, whereas the Chevy will have the two center ports on each side close to one another.
Cool rig!
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
post #6 of 67 Old 02-20-2014, 09:38 AM Thread Starter
Texsun
Cool rig!
Thanks for the info buddy, I will take a look and get a few pictures when I get home. I wanna say the distributor is near the firewall.
Texsun is offline
post #7 of 67 Old 02-20-2014, 09:44 AM
dg6772
If that's the case you can find the engine I.d. # on the front of the passenger side head,just below the valve cover. This will tell you size,year and what vehicle it came from. At least up to the mid nineties anyway. Not sure how the newer ones are identified.
dg6772 is offline
post #8 of 67 Old 02-20-2014, 10:12 AM
Tommy R
Tommy R's Avatar
If so, it's definitely not a Ford. And for it to be a Chevy 283 would be a bit of a rarity, although cool.
Like Dave said, I was able to use casting numbers on my block and heads to determine the approximate age and model my engine parts came from. In my case, the heads and block came from very different vehicles so keep that possibility in mind.
Tommy R is offline
post #9 of 67 Old 02-20-2014, 11:27 AM Thread Starter
Texsun
Great info guys, I will deffinently get an answer this evening! I will even get a quick video for everyone, its nice and cammed out the EFI will be awesome crawling!
I have some tube laying around, might make up a quick stinger tonight or this weekend!
Texsun is offline
post #10 of 67 Old 02-20-2014, 12:51 PM
HackFabrication
1976 CJ5
I would wager it's a 283 Chevy. Common swap into the early CJ's and a bolt up to the SM465 trans.
post #11 of 67 Old 02-20-2014, 01:22 PM Thread Starter
Texsun
Right on, I will get everyone an exact answer once I get home. The tranny is the SM420 not sure how different htat is to the SM465. From my quick research, it seems like the SM420 has a lower 1st gear?
Texsun is offline
post #12 of 67 Old 02-20-2014, 06:54 PM Thread Starter
Texsun
More pictures and videos to follow, maybe yall can help me identify the exact motor?
Texsun is offline
post #13 of 67 Old 02-20-2014, 07:20 PM Thread Starter
Texsun
Did some cleaning on the motor some, seeing how it sat up for awhile it was covered in dust! Went out and tested the 4x4 and the twin sticks. Everything works flawlessly, I have a small oil leak coming from the filter. I loosened it up some and re tightened it down, it seems to have stopped. Went up to Dollar General to grab some all purpose cleaner.
Before
After
Also added a few of my little touches "stickers and DoD Decals"
Texsun is offline
post #14 of 67 Old 02-20-2014, 08:24 PM
Tommy R
Tommy R's Avatar
The fact that the distributor is in the rear tells me it's more than likely a Chevy. It's definitely not a Ford. So it's not likely a 289. A Chevy 283 is certainly a possibility....especially if the motor swap was done a long time ago.
Tommy R is offline
post #15 of 67 Old 02-20-2014, 08:36 PM Thread Starter
Texsun
Walked out to the jeep a few minutes ago, and noticed a small pool of oil... Looks like the oil filters as leaking, I was able to twist it by hand so I tightened it up, hopefully that was the only issue!
Texsun is offline
