Just replaced gas tank and now no start - JeepForum.com
post #1 of 7 Old 06-08-2002, 06:31 PM Thread Starter
NMullens
NMullens's Avatar
Post Just replaced gas tank and now no start
I was thinking I mixed some of the lines up off the tank but according to the Hayes manual, it's right. There is no gas getting to the carb. I was looking at the gas lines and one runs from the sending unit to the filter up front where Im assuming it is being sucked by the pump but on the same side of the filter where the sending unit line runs in is a port that runs to the carb. I guess I dont understand how a fuel pump works, how can it suck gas from the tank through the filter then push gas through the same filter to the carb? This is how it was setup when it was running. Im confused. Please help.
Currently Jeepless - Previously owned 1983 SJ, 1979 CJ-7 and 1991 YJ
NMullens is offline
post #2 of 7 Old 06-08-2002, 07:33 PM
buddhasbomb
Lightbulb
couple of thing pop into my bald head.one you may have switched lines anyway(at tank)if you didnt mess with fuel filter you should be okay there.next and I did this ,is there gas in the tank?did you undo the coil wire(or something else)before you started?when you put the sending unit into tank did you kink or knock off the pickup tube?try these(and any other ideas anyone else may have)see what happens.BUDDHA
buddhasbomb is offline
post #3 of 7 Old 06-08-2002, 07:40 PM
cj7traildriver
Post
You have me confused in what yah wrote, Anyway if is set up the same as when you took it apart you should be ok. Carbs with mechanical pumps take awhile to bleed thru so you can crank and crank and crank or better yet get a small thing of gas have a buddy turn it over and pour a bit of gas down the carb this will start the motor and get things pumpen. If that doesn't work then somethen is wrong, either pump isn't pumping, filter plugged, could be a few different things.
Jeep what else matters.
cj7traildriver is offline
post #4 of 7 Old 06-08-2002, 07:40 PM Thread Starter
NMullens
NMullens's Avatar
Post
I really hope I didnt mess up the pick up tube. The tank didnt rattle so I guess its not broken off. I was thinking that I only put about a gallon and a half of gas in the tank and maybe the tube isnt picking up anything that low in the tank. Hopefully thats it. Thanks for your help buddha.
NMullens is offline
post #5 of 7 Old 06-11-2002, 12:45 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by NMullens:
<strong>I really hope I didnt mess up the pick up tube. The tank didnt rattle so I guess its not broken off. I was thinking that I only put about a gallon and a half of gas in the tank and maybe the tube isnt picking up anything that low in the tank. Hopefully thats it. Thanks for your help buddha.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">That is most likely the problem. Put a decent amount in, every tank has it's unusable quantity at the bottom, and 1 1/2 is probably even less than the amount of unusable in a CJ tank, especially if it is oversized.
4wheeler4CJ is offline
post #6 of 7 Old 06-12-2002, 10:25 AM
Jeep Daddy
Jeep Daddy's Avatar
Post
When you replaced the tank, did you also replace the sending unit? The sending unit for the small tank has a shorter pickup than the SU for the larger 20-22 gal tanks.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #7 of 7 Old 06-14-2002, 09:10 AM
dixiediesel
Post
Maybe you swapped the pickup line with the return line.
1976 CJ-5; 304ci, bare bones.
dixiediesel is offline
just replaced volt gauge won't start oop's hold24 Jeep CJ Forum 1 08-27-2009 09:28 AM
Replaced head gasket now wont start thediggler Jeep CJ Forum 2 08-09-2009 08:25 AM
replaced starter and still wont start KRIZB Jeep CJ Forum 7 02-23-2009 02:25 PM
Replaced factory coil with MSD Blaster 2....Jeep won't start!! lxlmongooselxl Jeep CJ Forum 2 06-19-2008 06:41 PM
Replaced fuel tank, now problems... imtheant Jeep CJ Forum 10 08-27-2007 09:26 PM
