-   -   Just a little flatty build (http://www.jeepforum.com/forum/f8/just-little-flatty-build-1305998/)
98blacksahara 12-26-2011 04:31 PM
1947 cj2a build, 33's D18/D20 hybrid etc
I recently bought another flatty. A 47 cj2a. Its still sporting the original L-head (which will be staying) a t90 and a d18, for axles its got a 19 spline tapered 2 piece D44 rear and a D27 front from an early 5. It on some 33's which will also be staying.
Here's some pics (also shown is my 51 cj3a resto project)
http://i118.photobucket.com/albums/o...s/DSCN2073.jpg
http://i118.photobucket.com/albums/o...s/DSCN2071.jpg
I am planning on swapping the t90a for the slightly better (lower) geared first of a t90c, which I already have the parts for. For a transfer case I will be using a hybrid d18/d20 set-up for twin sticks that will allow independant use of either axle.
I will be swapping to a later flanged D44 from a cj5 and a disc braked D30 also from a cj5. Both with 5.38 gears and lockers.
I have already completed a saginaw p/s swap. I will also be swapping in Herm the overdrive guy's master cylinder kit to go with my new disc brakes.
Building it for moderate or less trails. Going for reliable, fun little rig!
more pics to come when I get some free time to work on it.
Here is another pic of the 51 with the new panels on the body tub for good measure
http://i118.photobucket.com/albums/o...s/DSCN2122.jpg
I will probably catch alot of flack for my motor choice, but I like the simple little engines, got kind of a soft spot for them. I guess if I was rich, I'd be called eccentric, but I am not rich, so I am just crazy.
98blacksahara 12-26-2011 04:34 PM
Started working on the centered, flanged Dana 44 rear today. Plan is all new bearings, races and seals. And a 5.38 ring and pinion set.
http://i118.photobucket.com/albums/o...s/PICT1658.jpg
http://i118.photobucket.com/albums/o...s/PICT1655.jpg
Of all the places that I have found Mouse nests on/in a jeep, I have never seen one in a brake drum. Pics of the nest after I cleaned it out
http://i118.photobucket.com/albums/o...s/PICT1657.jpg
Axles all taken out, Nice and beefy for a light little Jeep.
http://i118.photobucket.com/albums/o...s/PICT1656.jpg
One last pic of the parts washer I got for christmas. Someone must know about my obsession with old greasy jeeps....
http://i118.photobucket.com/albums/o...s/PICT1659.jpg
Kman1983 12-26-2011 04:58 PM
Very Nice! Glad to see the L head is staying.
98blacksahara 12-26-2011 05:02 PM
Its gotta stay for atleast a little while. Its a great little engine. Not super powerful, but torquey down low. And its super easy to fix. I have always been a fan of the underdog.
All the guy sin my club are busting my balls for keeping it in there. They all think they are skunk me now that my huge wrangler is gone. I can still drive better than most of them though.....
Anyway thanks for the kind words
colojeepguy 12-27-2011 10:53 AM
That is a cool Jeep, and I like your plans for the build!
bigjoe 12-27-2011 11:53 AM
Nice find. Goodluck with her.
weehce 12-27-2011 01:02 PM
Congrats, on your purchase. I own two '52 M38's. Pretty much the same thing as your CJ3A. Just military. Glad to see your sticking with the "go devil". They great little engines, easy to work on. Love flat fenders hope to get one of mine going one of these days soon. Good luck, nice flat fenders!
98blacksahara 12-27-2011 01:25 PM
Thanks everyone. I have always been into flatties, I got the 47 also shown when I was 15. I enjoyed it for a few years, but it started to get rough. I stored it until I had the skills and funds to do it right. But I came into a deal on the cj3a that I could not pass up.
I love the simplicity, the noise/smells (although some of the smells are less than pleasant...) And I can't wait to beat up on some bigger rigs with 33's and a flathead! The thing is so small it fits where others won't and gives me more options for lines!
98blacksahara 12-28-2011 04:05 PM
Got a little more work done i=on the D44 rear today. Ring and pinion installed. Got a good gear pattern. Got the housing primed and cleaned up and primed the brake backing plates. Here's the proof.
http://i118.photobucket.com/albums/o...s/PICT5644.jpg
http://i118.photobucket.com/albums/o...s/PICT5643.jpg
And here is a picture of the shop for good measure.
http://i118.photobucket.com/albums/o...s/PICT5645.jpg
JrTjK 12-28-2011 04:31 PM
glad to see the thread! have fun with it!
are you a member of NEWJO?
98blacksahara 12-28-2011 04:36 PM
Not sure what that is, so I guess not.
Website?
JrTjK 12-28-2011 05:42 PM
http://www.newjo.org/NEWJO/home.html
98blacksahara 12-28-2011 06:38 PM
thanks
98blacksahara 12-28-2011 07:34 PM
Here is the pics of the hybrid D18/D20. Its a D20 housing from a J-truck, 1 1/4 intermediate shaft D18 gearset, with the sliding gear from a Bronco D20.
For anyone interested, the reason for using the J-truck D20, is that the case requires less grinding to fit the larger size of the 2.46 low range gears. Also, The J-truck version of the D20 only has one interlock pill. It will allow the use of each axle independently with no other mods other than a twin stick conversion.
http://i118.photobucket.com/albums/o...s/PICT5647.jpg
http://i118.photobucket.com/albums/o...s/PICT5646.jpg
The substance on the gears is white lithium grease. It works as a good assembly lube, then dissolves when the case comes up to operating temp the first time.
98blacksahara 01-16-2012 08:30 PM
Got the secondary shaft put in, all those little needle bearings are a pain. Unfortunately, that is as far as I got. My rebuild kit did not have the 3 square syncro dogs, or the 2 springs for them. Another call to Novak got them coming.
Heres pics for proof:
All the pieces on the table
http://i118.photobucket.com/albums/o...s/DSCN5906.jpg
installed secondary gearset
http://i118.photobucket.com/albums/o...s/DSCN5907.jpg
More to come when I get more piecey parts
The time now is 05:27 PM.
