Just drove her home: 1985 CJ-7 - JeepForum.com
post #1 of 52 Old 05-25-2010, 09:14 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
After a long search I'm now a CJ owner! Here's the post I made after first looking at the CJ:
http://www.jeepforum.com/forum/f8/yo...j-7-a-1036735/
I'll post 3 new photos plus re-post the images from the above post. After the photos I'll give the whole story below:
That's all!
1985 CJ7, T5 transmission, 258. I don't even know what the axles and transfer case are, but based on my limited knowledge, the rear pumpkin looks like a Dana 30.
33 x 12.5 x 15 tires. The PO claims it has a 4" lift. The rear bumper sticker indicates it could be a Rough Country lift.
This is my first CJ or Jeep of any kind. After wanting one back in the mid 80's, my parents said I needed a 4 door vehicle. So no CJ, but it's been in the back of my mind for 25 years.
I found this CJ on Craigslist after abour 5 years of on and off searching around. This one is appealing because it's got the 258, the T5, and it's white. The frame is in great shape. The PO had the Jeep for about 13 years and drove it little and no wheeling. THe history before that is basically unknown.
There is some body rust.
After some discussion with the PO, we agreed on $5500, down from the original $6200 price. I'm usually a good sleeper but I literally had some sleepless nights thinking about buying this thing and pondering the good and bad. It is, afterall, a CJ.
I live in the west side of Houston, Texas, and the CJ was located in Baytown, TX, about 50 miles on the other side of Houston.
We arrived at the PO's house and did the deal. He handed over the keys and asked me about what I was going to do with it.
While the Jeep test drove OK, my fear was the 50 mile drive back to the other side of Houston. Luckily (I guess), it 95% of it was down Interstate 10.
I test drove the Jeep earlier and briefly had it up to about 55 MPH and it seemed stable. No death wobble. The steering wasn't loose or flakey, but I did have to work a bit harder to keep it on the road than my Jetta, which drives beautifully. The brakes required some pressure to make a hard stop, but they work well enough to have passed the state safety inspection.
So after making the purchase and saying goodbye, I loaded up a toolbox of general tools, strapped on my seatbelt, and headed home.
Within minutes I was on the freeway in light to moderate traffic. I had her up to 50 and then 55 MPH fairly easily, feeling really happy to have the 5th gear to keep the RPMs down. I was moving along with the slower vehicles just fine, but had no acceleration in 5th gear. I figure the 33" tires and 25 year age might factor in there.
About 1/3 of the way home, I started feeling hot air which seemed odd since the heater core is not connected to the engine. Ultimately I figured out that it was hot air (probably from the exhaust system), coming in the shift boot which was torn. I pushed it down and that helped a little.
The ride was, as you can imagine, bouncy. Houston has no shortage of uneven roads and freeways. Eventually I learned not to extend and lock my arms while holding on the wheel; instead, I kept my arms bent to avoid transferring more motion to my body.
Ultimately the drive home was fine. No problems.
When I rolled into the driveway my youngest son wanted to ride around the block. That's when I realized the headlights wouldn't turn back on and rembered the PO saying that the floor headlight switch was flakey. No problem, it's a CJ. I can fix it.
Anyhow, in the past couple of days (in anticipation of purchasing the CJ) I have been lining up parts for various repair projects: Team Rush parts, shift lever boot, clip/shim to properly attach the shift lever, new valve cover gasket and RTV, plugs, oil, clay bar and cutting glaze compound to work over the chalky paint job, rust converter, and friday I'll have smaller wheels and tires installed. (31x10.5's BFG AT on 15x8 wheels, same style as you see in the photos). The owner threw in a tow bar and a good looking Goodyear 235/75R15 on a white wagon wheel for a spare.
(Anyone want to buy a good set of 33's and wheels in Houston? Plenty of tread left)
The Jeep needs more than that. The fuel gauge doesn't work, headlights are flakey, engine compartment needs a lot of cleanup, engine probably needs to be nuttered, radio doesn't work, factory temp gauge doesn't work, heater core is disconnected, turn indicator lever knob is broken, blinkers are too fast, interior floor painted with black paint, fan control knob missing, probably needs new shocks, and I'm sure there will be dozens more. I was pondering dropping in a more interesting muffler but after the drive home I think I will hold off for later. With a metal floor and nothing else, the exhaust is loud enough.
But even with the problems, the thing is solid; great frame, passed safety inspection, minimal body rust, great seats and top, and drives fine enough to far to be a semi-daily driver for my 7 mile trip to work each day.
That's all for now. I will be sure to document all my work with plenty of photos.
Ken4444 is offline
post #2 of 52 Old 05-25-2010, 09:17 PM
pspradlin2
1983 CJ7
nice jeep. looks pretty free of rust. i wish mine was the clean when i got it home.
pspradlin2 is offline
post #3 of 52 Old 05-25-2010, 09:22 PM
243
1978 FSJ Cherokee
That is a nice looking Jeep, and I am glad you found it so now you can get out of the "chick car"
Hey, I can say that because I had to drive two myself in the name of marriage.
Have fun and hopefully I will get mine finished soon and head down to Houston to meet up with you, Calvin, TRex and KickinProp.
Dave's 78 Build
243 is online now
post #4 of 52 Old 05-25-2010, 09:26 PM
Skerr
Congratulations! Glad you had a safe drive. Now get to work!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5 of 52 Old 05-25-2010, 09:27 PM
FOGHORNCJ7
man im glad you pulled the trigger on the jeep ... its a nice one to get ...looks pretty free of rust ... that a plus ... i had like 12 rust holes in mine when i fired brought it home ..... congrats on the new ride!
FOGHORNCJ7 is offline
post #6 of 52 Old 05-25-2010, 09:29 PM
crzdmnky
1978 CJ5
The front Axle is a dana 30, the rear axle is a AMC 20. You have a T5 Transmission, so therefore you have a Dana 300 Transfercase. It looks more like a 2.5" lift to me. Good looking jeep, the easiest and cheapest upgrade you can do to it right now is take that light bar off of it. It will increase your gas mileage, and cut down on a lot of wind noise. lol
But great buy, looks like a solid CJ, hope you take lots of pics of the things your doing to it, and post them up.
crzdmnky is offline
post #7 of 52 Old 05-25-2010, 09:40 PM
Trapshooter
Ken4444...Congrats on the new CJ!!! That's a nice looking rig. You and your son will have tons of enjoyment building your CJ.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #8 of 52 Old 05-25-2010, 09:46 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Congrats man.. Mod time
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #9 of 52 Old 05-25-2010, 09:53 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Thanks! It will be interesting to see if my kids can drive the CJ as their first vehicle or not. Still have a decade before we get to that.
Ken4444 is offline
post #10 of 52 Old 05-26-2010, 01:10 AM
nedmoore
nedmoore's Avatar
1982 CJ7
Good job Ken.. That drive from Baytown to Houston can be pretty rough, esp. will all of the 18 wheelers!
nedmoore is offline
post #11 of 52 Old 05-26-2010, 02:35 AM
MadBull41
1980 CJ7
Nice looking CJ.
I'm interested in rims and tires. How much?
MadBull41 is offline
post #12 of 52 Old 05-26-2010, 04:16 AM
Exposed
Exposed's Avatar
1981 CJ5
Ken, where are your located???? I am out here in Katy.... Nice score.... Jeeps are alot of fun and good place to spend your money.....
Calvin
81 CJ5, Ford 331 EFI, AX15, D-300, Dana 44 (Detroit Locker)....
When there are more people voting for a living than working for a living,
We are DONE as a Country!!!!!!
Newly Acquired 2014 Grand Cherokee Summit
Exposed is offline
post #13 of 52 Old 05-26-2010, 05:21 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
No doubt! I had several pass me and it was extra work to keep the Jeep in my lane.
Ken4444 is offline
post #14 of 52 Old 05-26-2010, 05:25 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by MadBull41 View Post
Nice looking CJ.
I sent a private message.
Ken4444 is offline
post #15 of 52 Old 05-26-2010, 05:27 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Thanks! I'm near Wilcrest and Westheimer.
Ken4444 is offline
CJ5 rebuild ALMOST done - drove for 1st time - a little mishap DuggerCJ Jeep CJ Forum 8 09-20-2009 09:00 PM
just drove my cj7 with the sway bar hooked up lineguyj82 Jeep CJ Forum 3 06-05-2009 07:19 PM
Pulled dads cj out today and drove her around .. *pix* Luke4554 Jeep CJ Forum 8 04-21-2008 02:19 PM
Home Sweet Home 350ci Jeep CJ Forum 0 08-08-2007 06:33 AM
Test drove the CJ7; a few questions... IwannaCJ7 Jeep CJ Forum 0 10-14-2002 06:52 AM
