Just bought someone esle's Jeep project, have a lift question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Just bought someone esle's Jeep project, have a lift question
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 10-08-2013, 07:21 AM   #1
rhino1
I just bought an 80 CJ7 that a buddy of mine had and had taken it completely apart to rebuild. He broke his neck and while he is up and mobile, he couldn't work on it any longer. He had bought a rough country 4" lift and a 1" body lift. My question is, I shouldn't need the 1" body lift should I? Also, I want to put heavier duty shackles than the factories parts on it, but again, not looking for all the lift. Who makes a good stock height shackle? I just don't want too much gap between the fenders and the tires. I want it to clear the tires and just look clean
rhino1 is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 07:30 AM   #2
Mwildmann
What size tire are you going to be running? Here's a link to a pretty lengthy list of heavy duty shackles for CJs: http://www.discountjeepparts.com/ind...3041&vt_id=149. 4" of lift and a 0" lift shackle should be good for a 33" tire I would think.
Mwildmann is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 07:49 AM   #3
rhino1
33" is all I am looking to run.
Unread 10-08-2013, 07:52 AM   #4
Mwildmann
In that case, I'd say you'd be good with no body lift. Maybe extend the bump stops a little if you have to once it's all together and the springs have settled.
