Just Another PCV system question... - JeepForum.com
post #1 of 2 Old 10-20-2011, 08:00 AM Thread Starter
sc72cj5
1972 CJ5
Hey guys,
I recently noticed oil on the top of my air cleaner on my 304. It appears to be coming out of the oil fill cap on the stand pipe? I replaced the PCV valve and it didn't change anything. My TSM says the valve should be hooked up to a vacuum source, but everybody tells me that it usually is just ran into the carb for emission reasons. This has me stumped!
Thanks for any help you guys can throw my way!
Redline for a good time!
sc72cj5 is offline
post #2 of 2 Old 10-20-2011, 12:15 PM
gosupes
Originally Posted by sc72cj5 View Post
Hey guys,
If you have a manifold vacuum source like the base of the carb, you can plug it in there. The PCV is like a slow vacuum leak, drawing air and out of the crankcase that has escaped past the rings. To keep the crankcase from developing too much vacuum, the other port on the valve cover is usually ran to a filtered air source, like a breather or the air cleaner.
This is the PCV in it's simplest form, there are usually other hoses and connections figured in.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
F4 PCV system question SteveMac Jeep CJ Forum 1 05-19-2010 06:47 AM
PCV system question TACAMO Jeep CJ Forum 0 10-12-2009 02:28 AM
fuel system question Boycejer Jeep CJ Forum 7 01-09-2007 07:38 PM
sound system question BLS33 Jeep CJ Forum 4 06-14-2006 04:03 PM
wiper system question jeepzoob Jeep CJ Forum 0 07-01-2003 09:14 PM
