Jump Seats? - JeepForum.com
post #1 of 49 Old 07-07-2009, 09:09 AM Thread Starter
green cj 78
1978 CJ7
Jump Seats?
Just playing with the idea of putting in FJ40 jump seats in the rear instead of the fold and tumble. Seems to me that they seem a little more user friendly when hauling other stuff. Thoughts?
78 CJ7
5.3 Vortec, T18, Dana 20, AMC 20, Dana 30
97 XJ 2wd POS.
green cj 78 is offline
post #2 of 49 Old 07-07-2009, 09:58 AM
JoonHoss
2011 JK Wrangler
1. you'll sit up pretty high (higher than the roll bar)
2. unless you change the rollbar, you'll have no protection in them whatsoever
I do think it's a cool idea, but not overly safe. why not just use a fold/tumble rear?
just my
Hoss
"three gallons of low lead; two hot dogs and a strawberry soda..."
JoonHoss is offline
post #3 of 49 Old 07-07-2009, 10:25 AM Thread Starter
green cj 78
1978 CJ7
Everyone has a fold and tumble. I think that having something different would be a change.
78 CJ7
97 XJ 2wd POS.
post #4 of 49 Old 07-11-2009, 08:50 AM
AlaskanCJ
1984 CJ8
I have seen those used as seats after the wheel well on a Scrambler. That was plus the typical fold and tumble seat. I agree on it being a little dangerous for the passengers. In fact, it might put their head at just the right height to constantly get clunked into the roll bar.
I think everyone has the typical tumble seat since it is the most practical solution for the vehicle...period.
AlaskanCJ is offline
post #5 of 49 Old 07-11-2009, 10:13 AM
poppatello
Make yourself a box or mount and put the jump seats on that! I like that idea myself. Still different but it would be safe! Check this one out and you'll understand what I mean...
http://www.jeepforum.com/forum/f8/bestop-bench-seat-813926/
I'm a big fan of different, check out my motto down below.
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #6 of 49 Old 07-11-2009, 11:09 AM
jscherb
I put FJ40 jump seats behind the fold-and-tumble in my Scrambler so I can seat six:
There are lap belts for both seats as well.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #7 of 49 Old 07-11-2009, 11:16 AM
poppatello
yes, but he can't or I should say shouldn't mount them to the rear wheel well on a Cj 5! That is just too high. Your seats are level just like the rear fold and tumble seats and that is safe.
Paved Roads
post #8 of 49 Old 07-11-2009, 11:45 AM
floridajpr
2015 JK Wrangler
If you look at the pictures closely, the added fold down seats are at about the same height as the top of the wheel wells in the jeep. That is a bit higher than the butt area of the OEM fold down rear seat.
I do agree that seats should never be mounted to the rear wheel wells.
floridajpr is offline
post #9 of 49 Old 07-11-2009, 12:07 PM
jscherb
CJ-8's built for export were available with longitudinally mounted folding seats that sat above the wheel wells. The CJ-8 wheel wells, however, are lower than the CJ-5/7 wheel wells, which means if you really wanted to put jump seats in the back of a 5/7, I suppose you could modify the tops of the wheel wells to be lower, there is clearance above the tires for some lowering of the tops of the wells. Doesn't seem worth the effort though.
jscherb is offline
post #10 of 49 Old 10-31-2009, 04:49 PM
Green_tj
I'm getting ready to do this in my TJ. i gotta checkmy local pick'n'pull but i will post pics when im done
1997 Jeep TJ- New Black tint black best top, 2" bb, RE disconnects, cobra bt radio, bada** custom stinger, and rocker lights, Sold
1992 Jeep YJ- reverse shackle kit, Baja off road lights, Warn winch, Trunk tool box, Swaybar disconnects. More to come!
Green_tj is offline
post #11 of 49 Old 11-02-2009, 08:25 AM
twmattox
Another source for jump seats that work well are the late '70s model Ford Supercab trucks. I picked up 2 sets for $40... They bolt directly to the floor and work extremely well...
twmattox is offline
post #12 of 49 Old 01-17-2010, 07:24 PM
SailorJerry
So has anybody actually done this to a TJ? I think it would be super cool
SailorJerry is offline
post #13 of 49 Old 01-18-2010, 07:20 AM
jeepskate
Apparently jump seats were available on export late model YJ's...just found this pic on my server on Friday after I thought I'd lost in a hard drive crash:
I believe what you run into is that there isn't enough headroom for an average size adult and I also believe it's illegal for street use in the US. Not something you're likely to get stopped for, but a passenger getting injured or killed in one if you got into an accident would probably place all liability squarely on you if it were proven that they would've fared better in a proper forward facing seat.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #14 of 49 Old 01-18-2010, 07:25 AM
Mark4883
This thread is back from the dead! I'm glad, I always thought this was an awesome idea as well. How about turning the fold and tumble around so it faces the rear, has anyone done that?
Mark4883 is offline
post #15 of 49 Old 01-18-2010, 08:38 AM
Military Jeeper
1979 CJ5
I think running a back seat sideways would be a bit dangerous in a rollover depending on the height of your passenger. Just my opinion. The CJ-8 doesn't look too bad, but that TJ looks down right scary.
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Hydroboost | HAD Shafts | 35 Toyo MT's|
Military Jeeper is offline
Jump seats in a CJ7 CompGuru Jeep CJ Forum 7 10-09-2012 09:57 PM
would you jump on this CJ-7 psbeaman Jeep CJ Forum 10 06-17-2009 07:40 AM
anybody ever seen rear jump seats in a cj7? keithf Jeep CJ Forum 6 01-02-2009 11:51 AM
T 150 1st gear jump... ziv Jeep CJ Forum 6 12-11-2007 06:05 PM
Jump Start Mishap Blue83CJ7 Jeep CJ Forum 8 10-14-2007 09:48 PM
