Jr's '74 CJ5 (304v8), Another Project. - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jr's '74 CJ5 (304v8), Another Project.
Ruffstuff XJ Unirail Channel Reinforcement....The Original 3/8" Ruffstuff Diff Cover!Gibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-28-2013, 09:21 AM   #46
Rollbar
1984 CJ8
Here is the DS we are going to use.
A long time ago I bought a 360/TF-999 w/this DS out of a CJ5 that was a DDriver, and the guy's dad owned a tranny shop. So my bet is that it will work.
We do have a few Cardon joints out of some J-10's but that might not work.
We have a drive-line shop here in town and we will take it to balance etc.
Also, w/Jr's cross member, it has two spacers on each side between the frame/cross member (factory), so if needed to make the DS straight in-line we can just add a spacer.
Stay tuned-Jim
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 08-28-2013, 03:54 PM   #47
Rollbar
1984 CJ8
Here is the plug to close the hole in the shifters other port.
I put some RTV on the threads then tightened it up but not to much. Then sealed the outside w/RTV.
Operated the shifter and no problems.
Unread 08-30-2013, 05:07 PM   #48
Rollbar
1984 CJ8
Jr and I are making some spacers to drop the cross member so the Tcase will work w/his '74 setup.
We used an old skyjacker Tcase drop bracket.
Cutting and drilling new holes etc.
Unread 08-30-2013, 08:50 PM   #49
Rollbar
1984 CJ8
Well the drivetrain is finished.
We had to cut the '74's tranny mount bracket so the Dana 300's yoke would not hit it.
Dana 300 installed and rear drive shaft ready.
Unread 08-30-2013, 08:50 PM   #50
Rollbar
1984 CJ8
Unread 08-30-2013, 09:00 PM   #51
Rollbar
1984 CJ8
For got to show the spacers we made and their location.
We were going to put a sleeve in the spacer where the bolt would go through the hole but we forgot. We used case hardened bolts and blue lock-tite.
Unread 08-30-2013, 09:44 PM   #52
243
1978 FSJ Cherokee
I certainly hope it works out for ya
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 08-30-2013, 09:49 PM   #53
Rollbar
1984 CJ8
Ya, me to-it should but we are open to suggestions.
A guy had this setup in his CJ5 (AMC 360/TF-999/Dana 300) and he tore it down to rebuild and couldn't finish cause .....
He use to drive it all over so we will see if it works out w/this drive shaft.
Unread 08-30-2013, 09:57 PM   #54
Rollbar
1984 CJ8
Question-is the tranny stabilizer mount (left) supposed to be tight or left a little loose ?
I can't remember.
Thanks,
Jim
Unread 09-02-2013, 01:59 PM   #55
Rollbar
1984 CJ8
Well we pulled the valve covers and intake off Jr's 360 to install a Edelbrock 4bbl intake and carb. Engine looks very clean for a 1985 w/140k on it.
Unread 09-02-2013, 04:52 PM   #56
Rollbar
1984 CJ8
Ok, Jr's Edelbrock intake and valve covers are on.
Unread 09-02-2013, 08:25 PM   #57
Rollbar
1984 CJ8
Ok headers mocked up and my old Holley carb sitting on the intake. Now on to wiring and fluids & the drive shafts.
Unread 09-04-2013, 01:01 PM   #58
Rollbar
1984 CJ8
My son installed headers and on the drivers side the fuel line is right under the header.
I do need to move it but is there a spring/heat dissipation) I can buy to slide over the fuel line ?
Reason I ask is when I bought a set from Inline-Tube for my build it had one on the fuel line.
You maybe able to see it on the frame rail. It also has a hump that went over the clutch linkage etc.
Thanks,
Jim
Unread 09-04-2013, 01:46 PM   #59
cjdave60
Hi i am whole cj whole cj ownership
I am looking for all kinds of engine transmission and steering parts if anyone knows where to find these please help, i can be more specific if that helps but just looking to be steered towards the right parts houses in general
cjdave60 is offline   Reply With Quote Quick reply to this message
Unread 09-04-2013, 03:00 PM   #60
Rollbar
1984 CJ8
Go to the For Sale section and I think I put the:
T-18
D-20
Ramsey PTO & winch on there for sale. If not then that is what I have for sale, all factory original.
