Jr's '74 CJ5 (304v8), Another Project. - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jr's '74 CJ5 (304v8), Another Project.
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 05-11-2013, 09:55 PM   #16
bradleybrb
1975 CJ5
Looks like Jr. has an awesome Jeep! I never knew they came with dual tanks! I have heard that drums are just as good as disc. I swapped mine because I never could keep them adjusted right when Iwas younger. Probably didn't know what I was doing! Always made for an exciting stop! I can't wait too see what you two do with this thing!
bradleybrb is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 09:19 AM   #17
Pathkiller
1974 CJ5
Dual tanks weren't a factory option. A previous owner has just added a 55-70 under seat tank as a secondary tank. Pretty easy to do using factory parts.
74 CJ5
Pathkiller is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 09:29 AM   #18
Rollbar
1984 CJ8
I didn't think so but wasn't sure.
Thanks,
P.S. Do you have pics of your '74 restore ?
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 05-12-2013, 01:30 PM   #19
Pathkiller
1974 CJ5
Some pics of mine here: http://www.jeepforum.com/forum/f8/gr...lives-1346865/
More of a resto-mod than a pure restoration. Upgraded a few things in the interest of safety and reliability. Like power steering, power brakes, front disks (complete knuckle-out swap from a 78 CJ5), 3 point seat belts, etc.
74 CJ5
Unread 06-24-2013, 03:37 PM   #20
Rollbar
1984 CJ8
Jr's Jeep (304) has points for the dizzy and I'm going to mention to him about changing it out for electronic (although I wouldn't mind it).
Without going to the HEI, will a newer, say 1980 dizzy work and will he have to take the cam gear off the old one (I've heard horror stories about the dizzy gear eating up the cam gear on some HEi's-that is why I would recommend to him just get a factory replacement and do the cap etc upgrade)
Thanks,
Jim
P.S. He is about ready to start tearing into it.
Unread 07-17-2013, 05:25 PM   #21
Rollbar
1984 CJ8
Well we installed some flat fenders and more is coming.
Unread 07-17-2013, 05:28 PM   #22
Rollbar
1984 CJ8
Jr also cut the front bumper off.
Question, he wants to go full width axles and we are looking at two Waggys for the price of $400.00 complete (except one is missing just the motor, the other has a 360).
Is there a kit for this that will work on his '74 CJ5.
Thanks,
Jim
Unread 07-18-2013, 11:32 PM   #23
Rollbar
1984 CJ8
OK, did a compression test (WOT) on Jr's 304 and we need some help here w/the results.
Results Drivers Side Front to Back (no smoke from this side):
122-clean plug
122-clean plug
125-plug a little fouled
105-clean plug
Results Passenger Side front to Back (big time smoke from this side):
116-clean plug
125-clean plug
115-plug fouled big time
125-clean plug
Seems like the passenger side cylinder is the one that's doing all the smoking.
He is running a Autolite 65 plug and we want to try a hotter plug but not sure what number to run. I called O'Reilly and the guy suggested a Autolite 866.
We would like to try the hotter plug so he can drive it to the pressure wash station before we do a valve job.
Any thoughts?
Thanks,
Jim
Unread 07-19-2013, 12:30 AM   #24
Rollbar
1984 CJ8
Wet test on cylinders in question. All plugs in on both tests except the cylinder in question. WOT.
122-clean plug
122-clean plug
105-clean plug - Added some WD-40 and the cylinder went up to 110lbs.
116-clean plug
125-clean plug
115-plug fouled big time - Added some WD-40 and the cylinder went up to 124lbs.
125-clean plug
Unread 07-19-2013, 03:29 PM   #25
Rollbar
1984 CJ8
OLD NUMBERS
122-clean plug
122-clean plug
105-clean plug
116-clean plug
125-clean plug
125-clean plug
That plug came w/the Jeep.
I installed new plug wires and Autolite 65 plugs.
Still smokes out of the right bank.
I let it idle for a while to maybe burn the oil oil out of the cylinder (maybe 10min). Then I drove it around the 3 acres and it kept smoking.
I then stopped and help the throttle @ about 1500 rpm and punched it a few times. Big time smoke and also when I took my foor off the accellerator pedal I did see some smoke (not much but visible in the daylight) coming out.
Here are the new compression numbers with ALL the plugs out/WOT/engine cold.
NEW NUMBERS
Drivers side front to rear:
118
125
126
105
Passenger side front to rear:
119/120
122
100
130
Unread 07-19-2013, 03:35 PM   #26
Rollbar
1984 CJ8
Jr's Jeep is a 3spd/304 and I have a question.
Question, if he pulls a 360 that has a auto behind it, can he take the pressure plate (where the clutch rides/motor turns the tranny) off the 304 and bolt it to the 360 or does he have to get one for a 360?
Question, will the same work for a 401?
Also, will his bell housing will bolt up to the 360 and the 401?
Thanks,
Jim
Unread 07-19-2013, 03:45 PM   #27
401YJ
Amc Motors are externally balanced so you will need to find a pressure plate for a 360. Externally all of the amc blocks are the same so the bell housing is interchangeable from the 304 up to the 401.
401YJ is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 03:49 PM   #28
Rollbar
1984 CJ8
Thank you. Would I also need a new H-Balancer or can I use the one that came w/the engine/AUTO trans?
Unread 07-19-2013, 03:53 PM   #29
401YJ
As long as you keep the H-balancer with the correct engine. Got to have a 304 flexplate/pressure plate and a 304 H-balancer on a 304 engine. Same with a 360 and 401. The same H-balancer can be used for a stick or automatic.
Unread 07-19-2013, 03:56 PM   #30
Rollbar
1984 CJ8
Thank you so much.
I will let him know about getting a PPlate/FlexPlate.
