Jr's '74 CJ5 (304v8), Another Project. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jr's '74 CJ5 (304v8), Another Project.
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineThe Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!
Unread 05-06-2013, 05:00 PM   #1
Rollbar
1984 CJ8
Jr just bought this '74 Jeep. Has a 304 and a 3speed tranny with a PTO and Ramsey's winch running off the PTO.
Not sure yet what tranny is in it or the axle ratio.
Has a gas tank in the rear and a tank under the drivers seat w/a valve to switch tanks (dual tanks).
Sweet Jeep.
image-1778082250.jpg   image-542001866.jpg   image-827849658.jpg   image-1835566992.jpg   image-203077685.jpg
image-1236785740.jpg   image-1744714989.jpg   image-3323829077.jpg   image-2432068138.jpg   image-572533122.jpg
Project CJ8 Build Gallery <----Click
CJ8 Build Thread<---- Click
Rollbar is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 05:34 PM   #2
Rollbar
1984 CJ8
Question, can the drum front brakes be converted to disc or ?
Thanks,
Jim
Unread 05-07-2013, 01:12 AM   #3
jp360cj
1977 CJ7
Sure can. all you need is knuckles out from a disc brake Dana 30.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 08:29 AM   #4
Pathkiller
1974 CJ5
Or keep your current knuckles and do the GM disk brake swap. Tons of info about it on the web.
74 CJ5 complete frame off restoration
Pathkiller is offline   Reply With Quote Quick reply to this message
Unread 05-07-2013, 09:37 AM   #5
Rollbar
1984 CJ8
Wow-Thanks. I'l have to Google and find this out. I think he would be better off w/disc's in the front instead of the 11" drums but keeping the drums so we have original parts.
Thank you,
Jim
Unread 05-07-2013, 02:49 PM   #6
Rollbar
1984 CJ8
Some pics if the PTO linkage and some wanted a pic of the seats.
image-3513125856.jpg   image-3841977463.jpg   image-2963609088.jpg   image-3131172010.jpg   image-1872076580.jpg
image-2063314490.jpg   image-1186328312.jpg   image-2932071110.jpg   image-1751257014.jpg
Unread 05-07-2013, 03:06 PM   #7
Rollbar
1984 CJ8
Question, is that a chain or gear driven PTO off the case. I know the T-case is gear but not sure about the adapter.
Thanks,
Jim
Unread 05-08-2013, 07:40 AM   #8
Pathkiller
1974 CJ5
Thank you,
Jim
The stock big drums work very well as long as they are in good shape and adjusted properly. A lot of people these days have never driven a vehicle with manual brakes though and don't realize you need to pump them, or how to modulate the pedal to keep them from locking up ( old school ABS). They suck if they get wet, though! But the drums can be drilled which helps a lot with the wet braking issue.
Unread 05-08-2013, 07:48 AM   #9
MoC
and spindles, hubs, dust shields, calipers, proportion valve plus all the actual brake parts.
MoC is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 09:17 AM   #10
Rollbar
1984 CJ8
Thanks guys. Ya I have manual brakes on my '84/'86 and I like them, especially when you are on a slope and can't get the motor started etc-that is what I like about them.
I'll have to find a good write up for the drum drilling/how to as we will not get to the conversion right away.
Thanks again,
Jim
Unread 05-08-2013, 09:58 AM   #11
MoC
Hey Jim,
If you find a good write up on the drum drilling post it up. Would be an interesting read.
Thx!
Unread 05-08-2013, 10:02 AM   #12
Rollbar
1984 CJ8
OK and if not then I will make one - I think
Question, do you think (just opinion here) it would be best to turn the drums BEFORE you drill or ?
We really don't need to go disc yet (no mud out in the desert) but I would like to make it as safe for my boy's first Jeep (in case he moves back to Fla/swamp) if you know what I mean.
Thanks,
Jim
Unread 05-08-2013, 11:51 AM   #13
Pathkiller
1974 CJ5
http://www.chtopping.com/CustomRod4/...examples1.html
Unread 05-09-2013, 09:58 PM   #14
Rollbar
1984 CJ8
Thanks for the video.
Unread 05-11-2013, 06:08 PM   #15
Rollbar
1984 CJ8
Seems like Jr's '74 came w/cruise control, not sure.
Also a pic of the engine bay w/all the smog stuff on it and the gas by-pass valve to switch tanks.
Rat nest
Gas by-pass valve to switch tanks. Not sure which way is which.
Working smog pump
