Originally Posted by EricsGreen98Tj
Jim since you clean/de-paint things better than anyone I've ever seen, do you have any ideas on how to clean/de-rust the inside of a frame? I've just ordered the Chassis Saver and a Monsta-liner kit off egag and need some ideas....I was thinking of blasting the spots where there are access holes but IDK about the rest of the inside....Thoughts?? Your ideas are GREATLY appreciated, Thanks-Eric-
There is no single best answer as too many variables exist. Opinions vary from cutting open the frame- yeah right, to pound out all of the scale, to pouring in neutralizers.
One thing that I spent a bit of time on was searching out long-term metal sealer rust stopper. There is a thread here where some of us contributed our findings. I settled on a home-brew version of WaxOyl.
One more:
Why not just make your own "waxoyl"?
Here's the recipe for "home brew":
1 pound paraffin wax (use some toilet sealing rings at about $1 each)
2 liters of turpintine or diesel fuel
1 liter of non detergent oil
put the mixture in YOUR crock pot (not the wife's), make small batches, and simmer unitl wax has melted or until the gentle smell of petrolium products alerts the neighbors.
Brush on or use a sprayer. WEAR GOGGLES
Of course a clean vehicle makes this process much more effective. As does having access to a lift, if you have to crawl under there, expect to get extremely dirty.
Really apply it in every nook, allow to drip, as the turpentine evaporates the mixture will thicken and hold.
This is from:
A good rust remedy for Eric
The whole thread is a good read.
