Jim's new hybrid Scrambler build- tons of questions coming! - Page 51 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jim's new hybrid Scrambler build- tons of questions coming!
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 01-20-2011, 08:42 PM   #751
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I got to the glass bead blasting of the YJ booster mounting bracket then primed the Vette master cylinder and the bracket. You can see the difference in size between the Vette master and the E350 cargo van master cylinder. The E350 reservoir interferes with the hood by at least 1 inch.
edit- not primed in these photos yet... duh
I would rather use the new E350 master and I suppose the best option is to find another shorter reservoir that could replace the tall one...
Rebelracing checked for me and they both have 1 1/8 bores so the Vette should be ok. The Vette reservoir is actually quite large so maybe I won't stew much longer about not using the E30 master- and think- it cost me a whole $14 and free shipping for the little experiment.
The plastic sleeve on the YJ that keeps the works clean in the span from the firewall to the booster fits perfectly on the new booster, too, so I'll use it to seal the firewall up.
I'm thinking about perhaps using this for the rod to pedal attachment:
It is the adjustable chrome rod at:
http://www.jegs.com/i/Tuff+Stuff/908/4750/10002/-1
$43 bucks may do it. What do you think Jim?
jeepsterjc is offline   Reply With Quote Quick reply to this message
Unread 01-20-2011, 09:16 PM   #752
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Spank Me
So have I said my new favorite color is fast becoming chrome??
I've painted up the master cylinder cover and thought I could do better...
This should stand up to the regular friction of yanking the bails on and off to check the fluid. That and chrome is cool... I guess I never got enough bling when I was a kid. Right Ken??
Unread 01-20-2011, 09:18 PM   #753
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
$9.46 with free shipping for the MC cover.
Unread 01-20-2011, 09:35 PM   #754
Jim1611
Jim1611's Avatar
You've really jumped on this brake job Jim. I'm thinking the Vette mc is the way to go. I know it work work fine with my brake calipers and you should have enough reservoir for yours too but I also like the E350.
The Jegs kit looks pretty good. You could spend quite a bit of time making those parts yourself.
I'm going to have to do some more shopping while you're on this roll.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 01-20-2011, 09:52 PM   #755
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
...The Jegs kit looks pretty good. You could spend quite a bit of time making those parts yourself.
That's what I thought, too. The chrome version should resist corrosion a little better than the bare steel one for $4.00 less.
Let me know what you come up with as you put your system together.
I primed and painted the parts Rustoleum Light Grey enamel. It should be easy to keep clean with synthetic brake fluid.
I'm also thinking of using stainless brake line tubing.
Unread 01-20-2011, 10:02 PM   #756
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Here is an example of prices on stainless tubing and fittings.
http://www.inlinetube.com/Street%20R...rod_plumbg.htm
About 2x as much as common steel tubing- but no corrosion down the line...
edit - Scrool down to the last two items listed on the page.
Last edited by jeepsterjc; 01-20-2011 at 10:02 PM.. Reason: edit - Scrool down to the last two items listed on the page.
Unread 01-20-2011, 11:01 PM   #757
Kheeney5
Subscribed. Looking good!
Kheeney5 is offline   Reply With Quote Quick reply to this message
Unread 01-20-2011, 11:10 PM   #758
Imped
Imped's Avatar
You've done a top shelf build thus far. Might as well keep it up.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 01-21-2011, 07:32 AM   #759
Jim1611
Jim1611's Avatar
Just take what you saved on the booster and mc and get the stainless tubing Jim. Remember after this is done you need to start on something else and you won't have time to work on the Scrambler fixing rusty brake lines.
My build thread
Unread 01-21-2011, 10:33 AM   #760
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Stainless it will be.
I'm thinking that as I've never had anything brand new like this before I should dip the whole Scrambler in a vat of Cosmoline.
Either that or just keep it as a garage queen... nope- that won't happen! The problem will be trying not to tear it up too fast.
Unread 01-21-2011, 01:07 PM   #761
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Master/Booster Assembly
I raced home at lunch to snap a pic and assemble the goodies together. Primed and 4 coats of Rustoleum Light Grey. It may not fare well with old DOT 3 brake fluid but i think synthetic DOT 3 behaves better with paint.
So- that $9.46 cover is on the way and then maybe adjustable rod and pedal assembly clean-up. My used pedal assembly arrived in pieces and I don't know where a wavey washer goes...
Anyone have a diagram of a YJ pedal assembly or can point me to an online link? Thanks.
Unread 01-21-2011, 07:03 PM   #762
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
So I had been asking about an assembly diagram for the pedal assembly and now that I don't have a Jeep CJ/YJ to look at... I even have another bunch of questions.
Here they are-
What is the bracket on the top for?
What is the rod on the left side for?
And what is the bracket on the edge of the clutch pedal for?
Thanks everyone for looking and reading this.
Unread 01-21-2011, 07:14 PM   #763
Jim1611
Jim1611's Avatar
The paint job looks very nice Jim. Really I like that MC better than the other, I'm not a big fan of plastic. Keep up the great work.
My build thread
Unread 01-22-2011, 09:15 AM   #764
yellow85cj
Currently in pieces - all of them
yellow85cj is offline   Reply With Quote Quick reply to this message
Unread 01-22-2011, 10:07 AM   #765
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Thanks Jim. I think I'll use the two Industrial Gray shades on the pedal brackets, seat positioning frame/tubing and roll bar, too.
hybrid scrambler , scrambler tj frame
