Jim's new hybrid Scrambler build- tons of questions coming! - Page 42 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jim's new hybrid Scrambler build- tons of questions coming!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-28-2010, 06:39 PM   #616
243
1983 CJ7
WOW!!!
I need to look at signatures and get out of the CJ forum once in a while, this is a super-cool build Jim
You can't sit at the big boy table if you are gonna whine like a girl...M
243 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2010, 01:23 AM   #617
hookedupinc
holy crap! Sir.... I envy you...
"Aw, jis taws a D-sisty aNNa SEE-fortene in air, an-U kin hit da mudHO wit me and Bubby dis weakin."
http://www.jeepforum.com/forum/f12/project-jevy-984905/
hookedupinc is offline   Reply With Quote Quick reply to this message
Unread 11-29-2010, 10:43 AM   #618
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Originally Posted by 243 View Post
WOW!!!
Thanks, Dave! It looks like we started a couple months apart on our projects but you're going to finish before me! Add to that the work on your daughter's truck and you seem to be Super Dad!
I'm going to be working slowly for a while now as I have done not a bad solo black op on our bank account!
I have been wondering, lately, if there is any job that can be done that doesn't cost too much? Hmmm...
jeepsterjc is offline   Reply With Quote Quick reply to this message
Unread 11-29-2010, 11:17 AM   #619
KeysPirate
Jim,
O, I thought that was WHITE BEACH SAND!!!! My BAD!!!!
KeysPirate is offline   Reply With Quote Quick reply to this message
Unread 11-29-2010, 02:04 PM   #620
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Originally Posted by KeysPirate View Post
Jim,
touche
Unread 11-29-2010, 02:08 PM   #621
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Thanks! All the bling is done now so it is back to being responsible and doing build jobs that will take loads of time and little cash... for months!
Unread 11-29-2010, 07:24 PM   #622
243
1983 CJ7
Sanding, sanding and more sanding
Unread 11-29-2010, 08:34 PM   #623
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I figure maybe rear caliper brackets should be cheap. Here is what I'm looking at. With my pinion angle set my rear drum back plate bracket is also angled:
It isn't this steep. More like 11 degrees back. To get my caliper bleed nipple oriented vertically I have this sorted out so far:
The camera doesn't show the shape well, so here is the drawing:
I'm using 3 bolts instead of two to hold the caliper bracket to the axle. The bracket will be 3/8 plate. The bracket will position the caliper over the rotor at 10 o'clock or so with the nipple perfectly vertical. Those will be big back brakes!
Now, cutting, drilling, more cutting then finishing x 2!
Unread 11-30-2010, 02:09 AM   #624
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
1992 XJ Cherokee
I have been playing with a new free piece of software that i found on the JD2 website. It is a 37 meg download and written for the Windows OS. I use Linux exclusively and decided to try it out in Wine- Wine Is Not an Emulator. This is a program that allows Win software to run natively in Linux. The results are awesome. The program functions well and will be very handy to utilize!
YouTube - jd2 bender software in linux.mpeg
The program gives a nice rendered version of the design, bend points to mark off on the tube or pipe and will run fine in my garage computer.
Originally Posted by Dogman View Post
And now I can say "thank you"
Ditto, I'll have to check that out!
Hi Jim. I'm looking forward to starting on the cage and fenders. They really aren't in the schedule yet but are going to get pushed up as I can do them during the snow and cold- all indoors. I'm using 1.9 HSS steel and was thinking about getting the correct dies, but maybe for a few other sizes "stepping down" the 1.9s for other smaller tubes and pipes.
What dies do you use (are there some real common regularly used ones) and are you stepping any down to use with smaller tubing?
The most common dies are 1.75" and 1.5". If I remember correct the most popular radius for the 1.75" is the 5.5" and the 1.5" is the 4.5" radius, also get them in 180 degrees. Those are the two dies I have and my next purchase will probably be a 1.25" or 1" for some dash work. I've also been thinking about getting a square die (or two), 3/4" and 1", good for baskets and stuff like that.
EDIT: Whoops...didn't realize it had been so long! Build is looking good.
Not sure if you've seen this build but I think you'll like it.
http://www.jeepstercommandoclub.com/...php?f=9&t=4209
Need a server? Buy this one!
COTM - October 2012!
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline   Reply With Quote Quick reply to this message
Unread 11-30-2010, 10:44 AM   #625
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Jeepster Commando Club of America • Login
Thanks ChiliPalmer. I appreciate your input. Die purchases have been pushed back a month so I won't even be ordering them till the new year. If you have a chance to use the software I'd like to know how it worked out. If the numbers are accurate it sure will make for efficient and speedy work = no wasted time or material.
Jim
Unread 11-30-2010, 01:34 PM   #626
TJLover99
WOW. I just read through the entire thread and I am blown away. Great work dude.
If it were easy, everyone would do it
TJLover99 is offline   Reply With Quote Quick reply to this message
Unread 11-30-2010, 07:24 PM   #627
shamrock111
holy crap! awesome build keep up the great work
shamrock111 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2010, 02:51 PM   #628
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Wow, I had to sign up for the forum but the Commando build was nice. Looks like Mile Marker lockers with those familiar looking rims. Also- he used twin sticks... nice! Thanks for the link. Jeepsters and Commandos are so cool.
Unread 12-01-2010, 03:03 PM   #629
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Thanks
Every day a little more!
Unread 12-01-2010, 04:41 PM   #630
ChiliPalmer
1992 XJ Cherokee
I agree about Jeepsters and Commandos, I had one for a while but never did anything with it and finally sold it to a guy in Colorado.
Keep up the good work. Looking forward to the end.
hybrid scrambler , scrambler tj frame
