05-11-2010, 10:16 PM
#286
Originally Posted by BadJeep2006
Projects looking good. I see we are dealing with the same problem on our D60s. The short tube on the drivers side. I am on the Cast right now, but think I am going to use that pirate thread and cut down the cast a little and weld to the tube.
Good Job!!
Joe
Hi Joe, why not weld to the cast? I know some people don't want to but welding to cast can be done reliably. What size of tires are you using? What does worry me is the placement of the lower left arm bracket... One more month ought to do it...
05-13-2010, 10:56 AM
#287
Here is one of the longest threads I've come across. This fellow has a bigger budget than I have by far, but he has is running 37s with short arms. It looks good. Now- to figure out what coils he is using.
http://www.jeepforum.com/forum/f22/s...ml#post8328096
05-13-2010, 11:40 AM
#288
He's running AEV coils I believe.
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S, Lightforce 240's, OME 2.5", 34" Toyo MT's, OEM Snorkel
1987 YJ Laredo
05-13-2010, 12:22 PM
#289
Thanks. Is there a generic or MOOG that would compare to these? Coils at $360 before shipping is pretty wicked...
Anyone know?
https://secure.aev-conversions.com/s...ct_Code=NTH210
05-13-2010, 02:47 PM
#290
Im not sure about the generic for those but I run the 3.5" AEVs and love the ride and performance they offer. I know its a bit steep but the quality is definately there
05-13-2010, 03:00 PM
#291
OK, thanks. Looks like I'm getting close to a purchase for the new Scrambler coils.
05-13-2010, 04:01 PM
#292
Sent off a question about vehicle weight and loading to aev-conversions.com. As my Scrambler is longer/heavier by a bit maybe 4" rears and 3" fronts...
05-13-2010, 04:11 PM
#293
MAIL Crawler.
buy 4 of the same height spring, also buy a pair of 1" spring spacers. when you get the suspension done, put the spacers on the end [fr/rr] that needs it. who knows, you might need them on one side [pass/dr] or the other.
I would take a pair of JJ innards off of someone's hands... PM me.
05-14-2010, 09:51 AM
#294
Here's their answer:
"Sounds like an interesting project. Your Jeep is going to be so much different than anything we've ever put springs on that I can't be sure what would work best. However, taking a guess at your wheelbase and total weight I'd say our 3" TJ Unlimited springs should work very well."
So- The AEV coils and maybe a couple of spacers for leveling as mentioned on spyder6's thread will do it.
05-14-2010, 10:14 AM
#295
Originally Posted by mudb8
lol, yer safe with the 95!... 99-03 superduties are the turds
Hello again mudb8,
My Currie control arms and brackets will be here today or Tuesday so it's time to get the coils sitting on top of the D60 and Sterling!!
It looks like from what I've read and you have also said- OME or AEVs coils will be pretty good choices for the smoothest DDriving. Is there anything more I need to know about these two?
Do you know anyone with unused F&R 3" OME or AEV coils?
A fellow at AEV said to go with their 3" TJ F&R coils...
I won't be shopping for shocks for a while but I what would you suggest for trackbars- especially the front that can clear the D60 housing?
Thanks for your help, Jim
05-14-2010, 11:05 AM
#296
05-14-2010, 11:29 AM
#297
I think the rep at AEV might be on to something when he says to use TJ Unlimited coils, because they also run an extended wheelbase.
1987 YJ Laredo
05-14-2010, 11:54 AM
#298
I didn't know TJs came in an extended length model?
05-14-2010, 12:01 PM
#299
noooooooooooooooooooooooo.....I guess you are stuck with their pricing because I can only imagine what shipping costs for those big boys would be. Start checking craigslist
05-14-2010, 01:21 PM
#300
You might know them as LJ's.
This is an LJ belonging to "Polecat":
1987 YJ Laredo
