Jim's new hybrid Scrambler build- tons of questions coming! - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jim's new hybrid Scrambler build- tons of questions coming!
Savvy Billet LED Tail LightsFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Jeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 02-21-2010, 08:56 PM   #16
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Canada loses to USA Olympic Hockey tonight- OK, back to the Jeep build...
jeepsterjc is offline   Reply With Quote Quick reply to this message
Unread 02-21-2010, 09:55 PM   #17
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Where do I get prices for cut down axle shafts for Dana 60s? Are they wicked expensive and how common are narrowed axles?
Unread 02-21-2010, 10:04 PM   #18
teamgreen666
we will see that in the finals, u don`t think we will knock Germany out. Good luck u will need it. Anyways can`t wait too see more should be a good build..
teamgreen666 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2010, 10:04 PM   #19
Hussler
1992 XJ Cherokee
Are you using stock tj arms or longarms?
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline   Reply With Quote Quick reply to this message
Unread 02-21-2010, 10:10 PM   #20
MisterO
crawling this!
def gonna be fun
MisterO is offline   Reply With Quote Quick reply to this message
Unread 02-22-2010, 08:37 AM   #21
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Ironman4x4 sells solid steel arms for a great price. These arms will allow me to scoot my axles around 4 inches or so.
The mount points are located for standard length arms.
Also, I'm only looking for an inch or two of lift. I'll open up the wheel wells and raise the fenders for wheel fit.
Unread 02-22-2010, 08:42 AM   #22
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i cant wait to see this. those Aqualu tubs are sweeeeeet.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 02-22-2010, 08:44 AM   #23
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Do you have any more info on these control arms?
I looked around their site and could not find them.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 02-22-2010, 10:02 AM   #24
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Sure- here you go:
IronMan 4X4 Fabrication
These things will be about as stout as they come.
Unread 02-22-2010, 10:13 AM   #25
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Still trying to figure out what axles to use. I was going to go with a Ford 8.8 rear with disks, a 4.10 and lsd...
But... the massive Dana 60 has caught my attention. No reason in particular, but I would like this to be my one special project to enjoy and be a little different than the rest around here.
Also, I'm going to have this as a daily driver. Ground clearance had never been an issue for my YJ. I know the Scrambler will be longer and thus prone to tagging the odd lump, but I can always raise it more it I want to, later. Those arms will give tons of room for adjustment.
Unread 02-22-2010, 10:26 AM   #26
Aggie99
I think I would go ahead and do the 60's, but I would up the tire size to 35's rather than 33's. My reasoning on this is that it is much easier to do the axles up front and never have to worry about upgrading them if you make other changes later on. Plus you should be pushing more torque to the axles running a 327, than those of us who are running a stock 4.0.
1999 TJ Sahara - RC 2.5" Suspension Lift with 2.2 shocks and 1.5" Body Lift, 33" Extreme MT's on Crager Soft 8's, Teraflex Oil Pan Skid, Poison Spyder Rockers, Poison Spyder Full Roll Cage, Cobra 75 SWXT with 3' Firestik, Homebrew Hand throttle, Homebrew Quick Discos, Dana 30 with a Lockrite, Dana 44, Winch.
Aggie99 is offline   Reply With Quote Quick reply to this message
Unread 02-22-2010, 10:33 AM   #27
Wheelin98TJ
JEEP FREAK
Sure- here you go:
Its nice they have 4" of adjustment.
The poly bushings on both ends leave a little to be desired though. A flex joint on at least one end would be nice.
Unread 02-22-2010, 12:51 PM   #28
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
A Johnny Joint?
Here you go... I'll spring for these ones.
Unread 02-22-2010, 01:40 PM   #29
Wheelin98TJ
JEEP FREAK
A Johnny Joint?
Yep, those are worth the extra cost.
Unread 02-22-2010, 02:20 PM   #30
LGriffith
If your going to run 60's than why not just run 37's-40's? It would be pointless to do 60's and 33's...
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote Quick reply to this message
hybrid scrambler , scrambler tj frame
