Hi guys,
I've sold off my YJ with the LT1 engine and megasquirted TPI on top to help finance my Scrambler build.I'll start off to answer you first question- "Why TJ Tech Forum?" <edit>Moved now to CJ Forum</edit> Well, the hybrid Scrambler frame I had throttledowncustoms.com build for me is a hybrid with 4 corner coils and control arms- TJ style.
<edit>June 16th/2011- thread moved to CJ forum where the real round headlights live</edit>
I have a Aqualu Scrambler tub being delivered to my home tomorrow for it. With the rolling CJ7 I have my eye on I'll turn it into a CJ7/8 one-off.
Then
Now
I've had the replacement frame setup to take a 20 gal poly YJ tank just rear of the rear axle (CJ7 style) rather than use a deeper Scrambler poly tank between the last two members.
The 8 control arm mounts match TJs. I'll be using ironman4x4fab solid arms. [EDIT] Now Currie double Johnny Jointed [/EDIT]
OK- First really big question. Axles? I want to use Dana 60s front and rear. I have an NP205 Chevy pass drop tcase. I'll look for a Chevy style D60 for the pass side pumpkin.
What are the drawbacks if I just use full width axles? Any thoughts appreciated. [EDIT]Used full width with H2 rims. They have 5.5 inches backspacing)[/EDIT]
Edited Dec 2010 For new readers. The first 10 to 15 pages are me asking lots of questions... and getting very great answers
Then
Now
- Went with 1 Tons- Ford '95 Dana 60 front and Sterling 1 Ton rear. It took months of deliberation to settle on what axles to use. After months of searching I found these two trucks and bought them both. Both 1 tons. : Donor truck and new daily driver
- Picked up a sweet 5.0: Engine- Explorer 5.0 It wasn't this engine- bait and switch but got everything in the end. Good poser pic though, eh?
- Then the carnage began: Let's strip that baby down!
- Had the axles and knew where I was going with tires- BIG!:thumbsup:So off to eBay I went for rims. I took another month or more figuring out if 17s or super cheap 16.5s were the way to go: I went with H2s that would need to get machined out for the larger Ford hubs- mine took a fair bit of work to do compared to others... I bought 17's so I could go with more back-spacing.H2 rims:
- Then the rest was just good old hard work for a while: Axle work Those axles got sandblasted 3 times. Man that was plenty of work!
- I bought Currie brackets. They took some grinding but were easier to use than building my own. I did have to do something different though with the front driver-side myself that turned out nicely.A bit of custom brackets work.
- Then a certified welder and tons and tons of pre-heating then a final third sandblasting: http://www.jeepforum.com/forum/f9/jims-new-hybrid-scrambler-build-tons-questions-coming-976744/index29.html#post9960583
- And more axle work: http://www.jeepforum.com/forum/f9/jims-new-hybrid-scrambler-build-tons-questions-coming-976744/index30.html#post9982530
- I basically spent 3 months through the summer on and off working on the geometry.
- Finally tires!! Woohoo!! 40" Goodyear MTRs with Kevlar
- Then brakes: Jim's brake setup Finally able to see how things fit in the rim.
- Then finally building a vehicle begins: Real building work!! And I get to see if all of my measuring an eye-ball engineering really allowed things to fit without rubbing. NO RUBBING!!
- Poser shots! poser
- Then brake bracket design and mock-up: Brake mock-up still happening.
- Want to use long monotubes in as close to zero lift as possible. Built my own bar-pin mounts and located them outward of the mounting plate on the frame and axle to effectively stretch the possible shock stroke: Shock bar pins.
- Finished the rear brakes- GM 3/4 ton 4x4 front calipers on the rear with E350 Frod cargo van disks: Rear brakes done.
- Finished the front brakes- stock Ford 1 ton calipers and disks: Front brakes done.
- 1 ton power brake capabilities for 40" rubber. Did a ton of shopping and looking around then found some smoking hot deals: Settled on dual diaphram booster and Vette master cylinder using YJ mounting bracket.
- Assembled those hot deals to see what fit: Parts assembled.
- De-greased, bead blasted old bracket, primed and painted everything: Parts together- waiting for chrome MC cover....
Here's where I'm at now- June 16th, 2011:
Building crossmembers and setting the driveline in place: Crossmembers
