Jim's 85 CJ7 rebuild - Page 219 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jim's 85 CJ7 rebuild
Unread 05-01-2014, 06:15 PM   #3271
mvigo
mvigo's Avatar
those sure look like stout "D" ring tabs...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is online now   Reply With Quote Quick reply to this message
Unread 05-01-2014, 07:16 PM   #3272
Skerr
Let me know if you want a helper for the summer. Clay is looking for work before he heads off to college.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 08:19 PM   #3273
TKFireman
1980 CJ7
I wish I was closer and could come be an apprentice. Nice work Jim
"If your gonna be dumb, you gotta be tough"
Build Thread
TKFireman is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 09:08 PM   #3274
Jim1611
Jim1611's Avatar
Thanks Mike
Do you really think he'd want to be stuck in the shop with a grumpy old guy like me?
Seems everyone I'd like to have around is too far away! Thanks
Got my fuel sending unit installed this evening. Also took a little better picture of the baffles.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 11:29 PM   #3275
rixcj
rixcj's Avatar
1979 CJ5
Clevis hook mounts??
I'm going to go out on a limb, here...I'd say that the stock is .75" x 1.5" CR flat bar cut to 3.375" long, with a .75" hole. Close??
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 05-02-2014, 07:21 AM   #3276
Jim1611
Jim1611's Avatar
Rich
They are clevis mounts. They measure 1" x 2" x 4 1/2" with a 1" hole. I got stuck with this material last year after a mistake on an order from Ryerson Steel. I only needed a quote on the stuff but later when I placed an order this material was with it, 50 pcs. They wouldn't take it back so the other day I decided to make some tabs out of them to sell on ebay to folks that are making their own bumpers out of the 2 x 4 tubing. These are made long enough to go all the way through. Since I'm not a vendor here I can't sell through the forum but people find ways around that on their own.
My build thread
Unread 05-03-2014, 09:54 AM   #3277
ASteve
1972 CJ5
Hi Jim,
Is this your ebay page:
http://www.ebay.com/itm/Weld-on-clev...139853&vxp=mtr
Just wondering...
SC
[url]http://www.astevecali.com[/url]
ASteve is offline   Reply With Quote Quick reply to this message
Unread 05-03-2014, 10:19 AM   #3278
Jim1611
Jim1611's Avatar
Originally Posted by ASteve View Post
Hi Jim,
Just wondering...
SC
Howdy Steve
That's it! Thanks for looking it up. Already sold some of them. I really thought it would take a while for anything to happen so it surprised me when the email notice came in. Need to get some more of this stuff on there too!
My build thread
Unread 05-17-2014, 04:19 PM   #3279
Jim1611
Jim1611's Avatar
I made some more progress on the tank today. I bought some brass roll-over valves and made some weld in flanges for them to screw into.
Then I needed a way to hold my fuel pickup tube and stuff in place so I cut a 3" dia. hole in the center of the top and drilled 8 holes around that for 1/4-20 screws. Made a ring with the same bolt pattern that size and it got welded onto the bottom side of the plate. I plan to make an aluminum top for it that's threaded to take 2 fittings. One supply and one return.
After that stuff was taken care of I welded the top on. I took some more of Rich's advice on how to weld the seams. I couldn't get comfortable enough to do the welds in one hitch so they got welded in 3"-4" intervals. He calls this "back stitch welding", correct me if I named that wrong Rich. You start on one end and weld then stop. Move away from where you stopped, in my case 3"-4" then start again but overlap the last weld. It worked very well for me. Thanks Rich
I'm looking forward to sealing this up and putting air pressure to it to see if it has any leaks. Also I wonder instead of painting this to spray it with U-Pol Gravitex like I did the bottom of the tub.
My build thread
Unread 05-17-2014, 04:58 PM   #3280
Coiz
1979 CJ7
The tank is looking great Jim.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 05-17-2014, 05:39 PM   #3281
rixcj
rixcj's Avatar
1979 CJ5
That's the way the pros do it, Jim! Yep...back-step welding is the way to go! And with those cabinet corner fit-ups, you're getting pretty much 100% penetration.
Rich
Unread 05-22-2014, 11:05 PM   #3282
lucdog
lucdog's Avatar
1980 CJ5
Nice Jim!!!
BG
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 05-23-2014, 10:28 AM   #3283
Jim1611
Jim1611's Avatar
Rich
Originally Posted by lucdog View Post
Nice Jim!!!
BG
Thanks Guys! Hope everyone has a safe and nice weekend
My build thread
Unread 05-29-2014, 09:14 PM   #3284
Jim1611
Jim1611's Avatar
Got things sealed up to test for leaks. After getting it all rigged up I gave it some air and ran it up to 15 psi. My gauge wasn't marked good enough to read under 10. I squirted soapy water on every seam. Found one leak. That's fixed.
I weighed this thing today. Anyone want to take a guess? It included the skid plate too. That gets welded on next. I'll check it again for leaks then it'll just about be done. I also think I'll weld a bolt on one of the front mounting tabs to use for grounding the tank to the frame.
My build thread
Unread 05-29-2014, 09:48 PM   #3285
243
1978 FSJ Cherokee
167.5 lbs
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
