Jim's 85 CJ7 rebuild - Page 153 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jim's 85 CJ7 rebuild
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! All Bilstein shocks & struts - Lowest Prices Ever and 1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 05-05-2012, 02:33 PM   #2281
Jim1611
Jim1611's Avatar
I decided to move the rear shock mounts from the U-bolt plate that's under the spring to mounting them on the axle itself. They seem to catch allot of things hanging down under the spring like that so it seems like a good idea to move them.
I started out making some simple brackets. I could have bought them somewhere but that would have meant not getting them done today. So they're homemade.
Had to do a little fitting to get the driver's side to fit right since there's a step in the tube where Currie welds a brace for the center section out onto the axle tube itself. That all went pretty easy.
Got them both welded on solid. I set them on there so the bottom of the bracket won't be any lower than the bottom of the axle tube. Now it needs to be sandblasted and painted. Get is all put back together and that will wrap this part of the project up.
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 05:03 PM   #2282
Skerr
Jiminy Jim!! I'd like to see an oil stain, or something. I think that axle is plastic! Looking good my Friend.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 05:46 PM   #2283
lucdog
lucdog's Avatar
1980 CJ5
All of the pictures come from me. I E-mail them to Jim so he has something to post. Jim is too busy working on Crabtree tool parts he just doesn't have time. Sorry to let the cat out of the bag Jim.
Jim, on the Detroit in the rear, I think it depends on how the jeep will be used most, and how often on slick ( snow and ice ) hard roads. As you probably know, with the Detroit a steady speed around corners is the key. Applying the accelerator or backing off it would lock things together.
I have 2 trutracs, one in the rear of a full sized GMC Jimmy, and one in the front of the "pretty" trail jeep. If strength of the trutracs is a concern, I wouldn't worry about it breaking. It's 1 tough unit.
More later, time for supper at the Firehouse.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 06:09 PM   #2284
SonicR1
Man, that just makes me want to weld up the truss for my 8.8... been so busy, I haven't been able to practice welding since the last time I PM'd you...
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 05-05-2012, 11:02 PM   #2285
Grewe02
Guns > Swords
Grewe02's Avatar
1980 CJ5
Originally Posted by Jim1611 View Post
it seems there's more stress on the rear than the front.
Know how I know you know what you know? (Say that eleven-teen times fast)
Think of it from a physics / engineering point of view: Is it easier to PULL a rope, or PUSH a rope? Also why a train pulls its cargo instead of pushing it. Plenty of life size examples to go around
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2012, 06:56 PM   #2286
Jim1611
Jim1611's Avatar
Let you in on a secret...it aint never had oil in it. Thanks.
Bill
Bill I've been meaning to thank you for all the pictures. It's what friends are for!
No doubt you've tried the True Tracs out so I'll take your word for it.
Hi Bill. I hear you on the busy part. You need to get that done though in time for another trip with Mike Vigo though.
We know what we know because we know and if we're wrong we just fix it.
Good way of explaining it my friend.
My build thread
Unread 05-09-2012, 03:24 PM   #2287
Jim1611
Jim1611's Avatar
Got the Detroit True Trac in today. This is going in the front end. I'll leave the Detroit Locker in the rear. Front one is for Ford 9" 31 splines just like the rear. One less thing to buy!
My build thread
Unread 05-09-2012, 03:34 PM   #2288
Coiz
1979 CJ7
What? You didn't machine it yourself?
Just kidding. The Detroit/True Trac combination is going to serve you well. What ratio are you running again?
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 05-09-2012, 03:38 PM   #2289
lucdog
lucdog's Avatar
1980 CJ5
One step closer to a roller, I've never set up a 9" . Do you set the pinion up with shims or a crush sleeve? And the pinion bearings the same way with shims.
That trutrac looks a lot different than a GM 10 bolt or a Dana 30.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 05-09-2012, 03:47 PM   #2290
Jim1611
Jim1611's Avatar
You know Mike I thought about making lockers, really. I've read that these are not MADE IN THE USA anymore. That really frost me if it's true. I'm running 4:11s. Might be a little low for 32" tires but I'm sure the nest set of skins will be bigger.
Bill
I'll be equipped for that rollover Bill.
You do shim the pinion except it's shimmed a little different than most. The shims are in between the pinion flange and the housing so that part is much easier. I still have a cruch sleeve though.
It looks different than the pictures in Simmit too but the invoice says True Trac.
My build thread
Unread 05-09-2012, 06:45 PM   #2291
mvigo
mvigo's Avatar
[QUOTE=Jim1611;13542868]One less thing to buy!
Amen to that!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline   Reply With Quote Quick reply to this message
Unread 05-09-2012, 08:20 PM   #2292
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
That's a Detroit Locker, right? My True Track in the last Jeep sure didn't look like that!
jeepsterjc is online now   Reply With Quote Quick reply to this message
Unread 05-09-2012, 08:34 PM   #2293
lucdog
lucdog's Avatar
1980 CJ5
I would say it is. A quick Google search showed a lot of photos, most of them said the photo was not the same as a actual part.
I did find one picture. That's the one Jim has.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
Unread 05-11-2012, 05:08 PM   #2294
Jim1611
Jim1611's Avatar
In regard to the locker or TrueTrac. Here's a picture of both. The Detroit Locker is installed with the gears and the TrueTrac is closest. The locker is made much stronger from what I see and that's always been the case, not to detract from the TrueTrac though. Anyway here's what they look like.
Also while I was already fairly dirty from my hard, laborious, strenuous and dedicated days work. Did I miss anything? Well sandblasting is a dirty job so since it's the end of the day I took care of that chore on the 9" housing. Hope to get it primed tomorrow.
My build thread
Unread 05-11-2012, 06:07 PM   #2295
Skerr
My sandblasting NEVER looks that good!
Kerrdog
Go Fish! <*////><
