Jim's new hybrid Scrambler build- tons of questions coming! - Page 4 - JeepForum.com
 5Likes
post #46 of 1972 Old 02-22-2010, 08:31 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Originally Posted by mcg311TJ View Post
Really, 3/4 Ton? Why not go to 1 Ton axles?
Honestly, I don't know what to look for- really. I hadn't looked past just using a cherokee hp dana30 for the front and a ford 8.8 in back... Maybe I should just stick with what I know, but there sure is a "cool thing" about putting something a little different together.
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #47 of 1972 Old 02-22-2010, 08:31 PM
BrandNew
Originally Posted by jeepsterjc View Post
I just didn't think I'ld need the lift to merit the need for longarms.
go with their short arms then. they are just as beefy
Selling your tire carrier?! send me a PM i want it
BrandNew is offline
post #48 of 1972 Old 02-22-2010, 08:39 PM
marylandjeeper
you want to do something unique? put unimog 404 portal axles under there. no lift with 37s. that would be awesome.
Originally Posted by provelogear
Everything we sell is US Chinese made! I'm Chinese so it is Made in the USA by a China Man! HAHAHAHAH!
Originally Posted by IKate
It's not "made BY chinese" that's the issue, it's "Made in China" that's the problem - now you behave yourself.
marylandjeeper is offline
post #49 of 1972 Old 02-22-2010, 08:55 PM
mcg311TJ
Portals are cool..... 406's would be better
Op, Maybe try to find a 78 or 79 F250 or 350 with 60's. there 1 tons. Or since you like to spend money , check out the Currie rockjock 60's
mcg311TJ is offline
post #50 of 1972 Old 02-22-2010, 09:13 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Slow down there sport. I'm ONLY splurging on the frame and tub. Everything else is comparatively minor. I own a couple of 327s and one 350 already. I have the 700R4 already and 5 tcases to chose from... I know it'll be a while before I'm done, but the big tickets are mostly done, now.
The trouble is just axles. Mostly because I don't know enough yet...
Thanks That's just what I had to find out- 78 or 79 F250s are what I'm looking for now.
post #51 of 1972 Old 02-22-2010, 09:27 PM
NCUNLIMITED
Is it done yet? I wanna see this finished, HURRY UP ALREADY
NCUNLIMITED is offline
post #52 of 1972 Old 02-22-2010, 09:30 PM
warrior99
He hasn't even decided what to do yet!! Just try to forget about this awesome build and come back later when it's done.
.________
/_l___\___\__
l__|___OlllllllO)
[z] . [z]--O-[z]
warrior99 is offline
post #53 of 1972 Old 02-22-2010, 09:31 PM
NCUNLIMITED
OK I'll check back tomorrow
post #54 of 1972 Old 02-23-2010, 09:38 AM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
No kidding! As soon as I get a pair of axles I'll be back into heavey production. Narrowing, new axles shafts, brackets... This is where the fun is.
I hate shopping. It is too easy to throw in the towel and just buy something mostly done already- ready to bolt in. I don't want to do it that way, nor can I afford it. I have few possibilities on Dana 60s though and need to follow them through.
post #55 of 1972 Old 02-23-2010, 09:51 AM
mcg311TJ
Don't forget about the Ford 9" axles or doing a hybrid D60/ 14 bolt combo.
mcg311TJ is offline
post #56 of 1972 Old 02-23-2010, 09:52 AM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I saw that on TV a while ago- the 60-9 setup, or sounding kind of hinky- the 69.
post #57 of 1972 Old 02-23-2010, 09:57 AM
mcg311TJ
I saw that on TV a while ago- the 69 setup,
Not what I was talking about, But still a good option How much do you know about 1 tons? There could be some links that I could send your way to help out if need be...
mcg311TJ is offline
post #58 of 1972 Old 02-23-2010, 09:58 AM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Well, they are big... I know diddly. What are you thinking about?
post #59 of 1972 Old 02-23-2010, 10:23 AM
mcg311TJ
I'm thinking about a D60/14 bolt combo for myself.( shaved or flipped ) But this is your rig so, here's a few threads to read through. These are TJ's and running all sorts of axles, Tires, and tranny combo's. But you can learn a lot and get a few ideas along the way. Make sure you look through the whole 1st post top and bottom. Tons of info.
Link Below.....
Ultimate TJ Build Ups and Swaps thread - Pirate4x4.Com Bulletin Board
mcg311TJ is offline
post #60 of 1972 Old 02-23-2010, 12:08 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Link Below.....
OK- That is exactly what I've found this morning. I called up a friend then dropped by. He has a NEW front Dana 60 4.56 in box with brakes right from GM. Been sitting in a corner for years.
And a corporate 14 bolt for the rear for no charge but the gears are wrong.
hybrid scrambler , scrambler tj frame
Questions about 1 tons and V8s ace2001 TJ Wrangler Technical Forum 5 05-27-2009 07:35 AM
Noobie with tons of questions:Suspension/Lifting killamike YJ Wrangler Technical Forum 4 02-25-2005 12:16 PM
New Scrambler Coming Soon!!! SaharaStu TJ Wrangler Technical Forum 9 07-11-2004 06:02 AM
New scrambler...When is it coming just1byte TJ Wrangler Technical Forum 11 05-12-2004 07:59 PM
Tons of 258 Questions - Please help! Zeke YJ Wrangler Technical Forum 9 04-01-2002 01:43 PM
