Jim's new hybrid Scrambler build- tons of questions coming! - Page 27 - JeepForum.com
 5Likes
post #391 of 1972 Old 07-18-2010, 07:42 PM
cableguy01960
Verry nice, I love the scramblers
cant wait to see it finnished
cableguy01960 is offline
post #392 of 1972 Old 07-18-2010, 07:43 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Originally Posted by 07wurubi View Post
Here is a link to the instructions of a Dana 60 that is being installed in a TJ from the OX site.
http://www.ox-usa.com/ox/LinkClick.a...id=436&mid=813
Hope link works.
Thanks and thanks for the link. Downloading now. That's what I thought I read- through the front diff cover. That may not work for me. Things are going to be real tight down there. Also- I read that something exposed was made of plastic on the mechanism and could break- but I'm not sure.
I do like the idea of a manual locker- not air or electric. We have tons of humidity at times here. Electric doesn't worry me, but I was told the electric lockers couldn't take 39s... Maybe that was just the Elocker- can't remember what Tom at Tom's Diffs was refering to.
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #393 of 1972 Old 07-18-2010, 07:50 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Hope link works.
OK- Just got through the OX manual and it the diff cover doesn't stand out too far the locker should fit and work fine. The OX carrier acts like it is and open diff when unlocked, right?
post #394 of 1972 Old 07-18-2010, 07:57 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Originally Posted by jason m View Post
Dump the dust sheilds, they only trap rocks and junk in there.
I have a round wire brush that was used to clean out smoke traps or a chimeny. I cut it down to just fit into the tube of a 60. On the end of the wire brush is a metal stem or a handle, I attach that end to a hand drill and send it down the axle tube's.
Get new inner axle seals to, with that much mileage on the trucks I bet the seals will leak.
Jason.
Dust shields gone. I'll cut down the wire brushes on one of mine and go for. Thanks.
post #395 of 1972 Old 07-18-2010, 08:01 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Burned out my last grinder with 1 bracket to go ;-(
Well- made a mess of my shop today. Went through 2 1/2 6 inch zip disks and got all but the last bracket of 7 or 8 removed. The Canadian Tire angle grinder bit the dust and no more brushes... Here are some pics of the carnage.
Last bracket-
post #396 of 1972 Old 07-19-2010, 05:28 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Thanks! Me too.
post #397 of 1972 Old 07-19-2010, 05:38 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
OK, I splurged and bought the $59.00 Hitachi angle grinder. Lots of power for such a little guy. Finished removing the last bracket left on the front diff, ground down all of the debris, and flapper wheeled it. Next I'll drag out both diffs for a final sand blasting to clean up the front knuckles that are staying on and to give the same texture to all of the ground down areas.
Some eye candy pics of my progress- two ready-to-build 1 ton axles!! First I'll spin out the garbage in the front axle tubes. Then the new bracketry gets tacked on- the lower front driver side will be a charmer. A bunch of patrs washing in a solvent tub. Seal replacements and back together they both go.
After that a tough industrial grey color for paint. Can anyone suggest a tough paint? Thanks in advance.
post #398 of 1972 Old 07-19-2010, 05:44 PM
KA24DET95
Por15. Powder coat if you really wanna strip it down all the way. Or bedliner
If guns cause crime, all of mine are defective.
KA24DET95 is offline
post #399 of 1972 Old 07-20-2010, 05:48 AM
mschviuz
A friend of mine showed me a trick not long ago when painting. After scuffing them up really good, take a torch and go over the metal and you can actually see water evaporating off the metal. Then take some etching primer to it and finally paint. Pick your poison but rustoleum does pretty good. I wouldn't use bed liner. By the way....looking good!
mschviuz is offline
post #400 of 1972 Old 07-24-2010, 09:04 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I shopping for rustoleum. Thanks.
post #401 of 1972 Old 07-24-2010, 09:15 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Well- I had a part of the day and started grinding the rear brackets to fit the bigger axle tubes. Next, I pulled out the mig and nothing but splatter. Turns out the CO2 valve in the handle had broken... bought it at Liquidation World... Fixed the valve and voila- nice welds.
Started with the rear and only had interference with the original brake union/breather block with the upper control arm/track bar mount. I'll have to weld it shut, drill in another and tap it.
The big rear Ford Sterling clears everything- the fuel tank (that I have relocated) and the track bar mount on the frame- great stuff.
The front end is mocked up a bit and it is doeable but is going to be a bear.
I did a bit of trig to ruff-in the pinion angle to use a CV rear drive shaft. I don't know if you can see the pinion pointing up on the rear end.
The front axle looks like with some careful planning it will clear the trackbar mount on the frame and the front driveshaft will miss the frame and lower control arm frame mount.
Got a throat infection and may take Sunday off...
post #402 of 1972 Old 07-25-2010, 08:31 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Time to find 4 coils
I've got the suspension setup mostly sorted out and have questions about what coil characteristics. First some pics:
This is the front end at full stuff. I only have 3 "inches up-travel from my desired ride height. The trackbar mount clears the diff and the driveshaft does not interfeer with the frame/lower control arm mount.
Here is the rear-end with desired ride height. I have 9 inches between the rear coil buckets.
Here is the Sterling up to 6 inches (actually frame down...love the hoist) between the buckets. The trackbar mount clears my forward fuel tank crossmember so the rear can compress much much higher if I want.
The clearance at my "normal" ride height between the front-end coil buckets is 15 inches and bumpstop at 12 inches. What coil should I look at for the front I wonder??
The rear coil must compress to a "normal" loaded-ride-height to 9 inches. What coils for it I wonder?
I'll look around for a TJ to measure, but right now don't have access to find out what is normally seen for clearances and fit.
Thanks everyone for any ideas. Bring 'em on!
post #403 of 1972 Old 07-25-2010, 08:46 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I'm heading for something like (but less in $$$) this:
Pirate4x4.Com Bulletin Board - View Single Post - ROKMEN LJ Build
It is on 40" Goodyear MTRs
post #404 of 1972 Old 07-25-2010, 10:59 PM
07wurubi
07wurubi's Avatar
That thing is sweet looking.
Mike Fox
My Jeep:
00 Wrangler Sport 4.0L NV3550
4" RC LA
Bilstein 5100 shocks all around
axles (30,8.8) with 4.88 gears ARB F/R
SYE and CV rear driveshaft from Drivelines NW
Currie HD steering (Thanks Savvy, Awesome customer service)
Savvy LED tail lights (Thanks again Savvy)
GY MT/R Kevlar 35x12.50x15 on 15x10 American Racing
Bestop soft top with tinted windows
Smitty front and rear bumpers w/rear tire carrier
Smitty XRC8 winch w/synthetic rope
Smitty rear corners and rock sliders with step
Genrite aluminum 6" tube fenders front/rear
Dodge Durango steering box with Pure Jeep skid and M.O.R.E. steering brace
07wurubi is offline
post #405 of 1972 Old 07-26-2010, 09:27 AM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Just got dualtjs' MOOG coil spring spreadsheet
I emailed dualtjs last night asking for his spreadsheet again. Seems my filing system isn't as great as I thought it was...
Already waiting in my email this am. Thanks dualtjs. The spreadsheet is awesome.
hybrid scrambler , scrambler tj frame
Questions about 1 tons and V8s ace2001 TJ Wrangler Technical Forum 5 05-27-2009 07:35 AM
Noobie with tons of questions:Suspension/Lifting killamike YJ Wrangler Technical Forum 4 02-25-2005 12:16 PM
New Scrambler Coming Soon!!! SaharaStu TJ Wrangler Technical Forum 9 07-11-2004 06:02 AM
New scrambler...When is it coming just1byte TJ Wrangler Technical Forum 11 05-12-2004 07:59 PM
Tons of 258 Questions - Please help! Zeke YJ Wrangler Technical Forum 9 04-01-2002 01:43 PM
