Jim's new hybrid Scrambler build- tons of questions coming! - Page 2 - JeepForum.com
 3Likes
post #16 of 1972 Old 02-21-2010, 08:56 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Canada loses to USA Olympic Hockey tonight- OK, back to the Jeep build...
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #17 of 1972 Old 02-21-2010, 09:55 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Where do I get prices for cut down axle shafts for Dana 60s? Are they wicked expensive and how common are narrowed axles?
post #18 of 1972 Old 02-21-2010, 10:04 PM
teamgreen666
we will see that in the finals, u don`t think we will knock Germany out. Good luck u will need it. Anyways can`t wait too see more should be a good build..
teamgreen666 is offline
post #19 of 1972 Old 02-21-2010, 10:04 PM
Hussler
1992 XJ Cherokee
Are you using stock tj arms or longarms?
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #20 of 1972 Old 02-21-2010, 10:10 PM
MisterO
crawling this!
def gonna be fun
MisterO is offline
post #21 of 1972 Old 02-22-2010, 08:37 AM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Ironman4x4 sells solid steel arms for a great price. These arms will allow me to scoot my axles around 4 inches or so.
The mount points are located for standard length arms.
Also, I'm only looking for an inch or two of lift. I'll open up the wheel wells and raise the fenders for wheel fit.
post #22 of 1972 Old 02-22-2010, 08:42 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
i cant wait to see this. those Aqualu tubs are sweeeeeet.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #23 of 1972 Old 02-22-2010, 08:44 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Do you have any more info on these control arms?
I looked around their site and could not find them.
Wheelin98TJ is offline
post #24 of 1972 Old 02-22-2010, 10:02 AM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Sure- here you go:
IronMan 4X4 Fabrication
These things will be about as stout as they come.
post #25 of 1972 Old 02-22-2010, 10:13 AM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Still trying to figure out what axles to use. I was going to go with a Ford 8.8 rear with disks, a 4.10 and lsd...
But... the massive Dana 60 has caught my attention. No reason in particular, but I would like this to be my one special project to enjoy and be a little different than the rest around here.
Also, I'm going to have this as a daily driver. Ground clearance had never been an issue for my YJ. I know the Scrambler will be longer and thus prone to tagging the odd lump, but I can always raise it more it I want to, later. Those arms will give tons of room for adjustment.
post #26 of 1972 Old 02-22-2010, 10:26 AM
Aggie99
I think I would go ahead and do the 60's, but I would up the tire size to 35's rather than 33's. My reasoning on this is that it is much easier to do the axles up front and never have to worry about upgrading them if you make other changes later on. Plus you should be pushing more torque to the axles running a 327, than those of us who are running a stock 4.0.
1999 TJ Sahara - RC 2.5" Suspension Lift with 2.2 shocks and 1.5" Body Lift, 33" Extreme MT's on Crager Soft 8's, Teraflex Oil Pan Skid, Poison Spyder Rockers, Poison Spyder Full Roll Cage, Cobra 75 SWXT with 3' Firestik, Homebrew Hand throttle, Homebrew Quick Discos, Dana 30 with a Lockrite, Dana 44, Winch.
Aggie99 is offline
post #27 of 1972 Old 02-22-2010, 10:33 AM
Wheelin98TJ
JEEP FREAK
Sure- here you go:
Its nice they have 4" of adjustment.
The poly bushings on both ends leave a little to be desired though. A flex joint on at least one end would be nice.
post #28 of 1972 Old 02-22-2010, 12:51 PM Thread Starter
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
A Johnny Joint?
Here you go... I'll spring for these ones.
post #29 of 1972 Old 02-22-2010, 01:40 PM
Wheelin98TJ
JEEP FREAK
A Johnny Joint?
Yep, those are worth the extra cost.
post #30 of 1972 Old 02-22-2010, 02:20 PM
LGriffith
If your going to run 60's than why not just run 37's-40's? It would be pointless to do 60's and 33's...
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
hybrid scrambler , scrambler tj frame
Questions about 1 tons and V8s ace2001 TJ Wrangler Technical Forum 5 05-27-2009 08:35 AM
Noobie with tons of questions:Suspension/Lifting killamike YJ Wrangler Technical Forum 4 02-25-2005 01:16 PM
New Scrambler Coming Soon!!! SaharaStu TJ Wrangler Technical Forum 9 07-11-2004 07:02 AM
New scrambler...When is it coming just1byte TJ Wrangler Technical Forum 11 05-12-2004 08:59 PM
Tons of 258 Questions - Please help! Zeke YJ Wrangler Technical Forum 9 04-01-2002 02:43 PM
