Jim's 85 CJ7 rebuild - Page 51 - JeepForum.com
 60Likes
post #751 of 4026 Old 01-09-2011, 05:56 AM
BioTex
1979 CJ7
Hey Jim,
I've been following the thread, and love your work (play). Since the thread is getting quite long, I didn't want to go back and see if you already have sliders made. I have a set of shrockworks sliders, and they were $500 plus shipping.
Seems to me you could start on yours next, and then add those to your list of growing orders.
BTW:
I have some money set aside for my tube bender, so you can start on that anytime now...
Keep up the good play, and quit sticking your finger where it doesn't belong please!
Eric
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #752 of 4026 Old 01-09-2011, 06:29 PM Thread Starter
Jim1611
Jim1611's Avatar
Originally Posted by twildt View Post
i agree, i think the most pressure if hit hard will be more towards the frame than the engine side, looks great Jim, take pictures when you go snowboarding in your CJ
Thanks!! I'm getting to where I carry my camera with me almost everywhere I go, I'll be taking plenty of pictures when this is done too.
Originally Posted by BioTex View Post
Hey Jim,
BTW:
Eric
Hi Eric, we do talk allot on here. Guess that's why the thread is so long.
You're reading my mind on the sliders. That's what I plan to work on next. Here's my plan. I want them firmly attached to the frame, not welded either so that means either drilling through the frame and intsalling crush sleeves or making some kind of mount like a reciever hitch would use.
This stuff is going to be heavy duty too since my roll cage tie in for the front bar will be mounted to this too. I also think I need to make some kind of removeable step, the Jeep is pretty high, I'll be 50 next year. You get the picture.
Friday I was thinking of what I need to schedule time for on the cnc and one of the things will be the bender parts. I plan to make several sets so I have them ready.
Thanks for the finger advice too, which I will take!!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #753 of 4026 Old 01-09-2011, 06:41 PM
243
1978 FSJ Cherokee
Jim, I am pretty sure Fatman built sliders using receivers mounted to the frame. I have not found nerf bars that are not priced out of sight so I may build sliders with a built in step running below the rails.
Dave's 78 Build
243 is offline
post #754 of 4026 Old 01-09-2011, 08:11 PM
Davidnex
1979 CJ5
Jim, roughed in receiver for step a while back, (got idea somewhere on JF)might incorporate into sliders
79 CJ 5 Frame up Build
http://www.jeepforum.com/forum/f8/79-cj-5-frame-up-1092681/
Davidnex is offline
post #755 of 4026 Old 01-09-2011, 08:41 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
OK. What were they called in the old KungFu tv series? Master and Grasshopper or something? You guys I'll refer to as Master (like it's obvious) and I'll be Butterfly here...
My wife will need a step to get up and I thought about incorporating it into a nerf bar setup. Also, I don't want to go right out and crush my new shiney tub...
I've been thinking about drawing up a combined slider with a step up- either sprung hinged or electric retract... I know- overkill but all the options are wide open.
So, little Butterfly (at 52 years of age) still looking for a better combo than exists right now, is sitting and watching...
Master Po: Close your eyes. What do you hear?
Young Caine: I hear the water, I hear the birds.
Po: Do you hear your own heartbeat?
Master Po: Did you slip on that step again?
Po: No master, it was so well engineered I found harmony by using it to get in!:
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #756 of 4026 Old 01-09-2011, 09:04 PM
Skerr
50!!! SO WHAT! BIG DEAL!! What's 50?? You Old Fart!
This is a cool idea and good detail. I wonder, though, if it will bounce around, knocking, making rattling sounds on the trail? I've never seen a reciever that didn't if it didn't have enough weight on it, like a boat.
Another Old Fart!! I'm feeling good these days!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #757 of 4026 Old 01-10-2011, 04:12 AM
243
1978 FSJ Cherokee
Easy fix, weld a nut on top or bottom and install a bolt to keep it from rattling!
Dave's 78 Build
243 is offline
post #758 of 4026 Old 01-10-2011, 07:01 AM Thread Starter
Jim1611
Jim1611's Avatar
He did Dave, now that you mention it. He also made a set of steps that fit in a reciever too. I like the idea. Thanks.
[quote=Davidnex;10757997]Jim, roughed in receiver for step a while back, (got idea somewhere on JF)might incorporate into slidersQUOTE]
Thanks David. I had seen yours a while back and liked the idea.
Jim I think you're being a bit modest. I think from the work you're doing on your current build and what you've done in the past, I watched your videos , you're an old hand at this stuff.
What would be nice in a step would be something that would move out of the way when it hit something solid then resume it's postion.
Wish I were the grasshopper, then I wouldn't need the step.
Hey Scott at 50 we're some of the older guys on here. I feel as good as I did when I was 20 andddddddddd much wiser . Not all that comes with age is bad. Besides as high as these lifted CJ's are everyone needs a step, although the younger guys won't admit it.
Dave's idea to fix the rattle is what I'd do.
My build thread
Jim1611 is offline
post #759 of 4026 Old 01-10-2011, 08:25 AM
Davidnex
1979 CJ5
Quote: This is a cool idea and good detail. I wonder, though, if it will bounce around, knocking, making rattling sounds on the trail? I've never seen a receiver that didn't if it didn't have enough weight on it, like a boat.
To stop the rattle and create a tight fit, weld some beads on tube then grind them down, fit, grind, fit. Worked on previous project.
Davidnex is offline
post #760 of 4026 Old 01-10-2011, 08:55 AM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I think I'll build something permanent for a nerf/step and skip a tub mounted slider.
Probably hinged down step that manually retracts and uses a hefty torsion coil spring to keep it up when not being stood on.
To stop it from bouncing while on washboard or constantly irregular choppy terrain I'll just use a lock pin and spring ring to get locked up.
Thanks for the brainstorming here!
Also- don't for forget to have a functioning winch and gear before you go out to test your brand new rig. You should see the rear corner of my YJ where the tree ran into me from behind while I was roaring around in the scrub trying to climb back onto the logging road!
post #761 of 4026 Old 01-10-2011, 03:24 PM
Skerr
Great ideas! Either method would work.
...Also- don't for forget to have a functioning winch and gear before you go out to test your brand new rig. You should see the rear corner of my YJ where the tree ran into me from behind while I was roaring around in the scrub trying to climb back onto the logging road!
OUCH!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #762 of 4026 Old 01-10-2011, 03:25 PM Thread Starter
Jim1611
Jim1611's Avatar
I'm with you on not mounting to the tub. I like the looks of sliders made thay way but it looks like another place to introduce rust later on, and I've had enough of that suff.
I've got one of the old Warn 8724 that a guy gave me, needs rebuilding. That's what I plan to use. To be so rooted down it has always amazed me how quick they can move and get ya.
My build thread
Jim1611 is offline
post #763 of 4026 Old 01-10-2011, 03:37 PM
SonicR1
Trees moving??? I've had more problems with the road disappearing below me!!! The winch save me from that!!!
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #764 of 4026 Old 01-10-2011, 03:46 PM Thread Starter
Jim1611
Jim1611's Avatar
In your line of work Bill I figured you'd have heard that excuss before.
Guy I have a question about sliders. I see them made where they either bolt right to the tub or attach to the frame and have a square tube under the tub. Both have dom bent and welded to them that protrude past the outside edges of the tub. Most of what I see the tubes are welded on at an angle pointing up. Why is this? Why could they not just be welded on at a 90 degree angle to the side of the tub. To me that would make a better step and give just as good of protection.
Ideas???
My build thread
Jim1611 is offline
post #765 of 4026 Old 01-10-2011, 03:53 PM
CACooper
Ideas???
Wouldn't they be more prone to getting hung up on something at 90*?
Thread Link:
Originally Posted by Nuthin
...I have tentatively decided I actually enjoy this Cooper-person. Deal with it.
Originally Posted by -Zona-
For some reason I keep underestimating you.
CACooper is offline
AMC 360 Rebuild gmshades Jeep CJ Forum 29 08-14-2015 12:44 PM
Rebuild 258 or 4.0 HO? 1979CJ7newguy Jeep CJ Forum 6 09-29-2011 11:04 PM
Jim's cj5 build up patchy_400 Jeep CJ Forum 10 11-24-2010 02:07 PM
Carter BBD rebuild: Does it matter which rebuild kit I use? Ken4444 Jeep CJ Forum 2 06-14-2010 11:01 AM
CJ tub rebuild paraman72 Jeep CJ Forum 5 06-07-2005 10:06 PM
