Jim's 85 CJ7 rebuild - Page 228 - JeepForum.com
 36Likes
post #3406 of 3970 Old 08-25-2014, 07:42 PM Thread Starter
Jim1611
Jim1611's Avatar
You Ford guys tell me what you think of this intake on ebay http://www.ebay.com/itm/87-93-95-For...c7362e&vxp=mtr
It's a GT40 from a 99 Ford Explorer.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3407 of 3970 Old 08-26-2014, 05:42 AM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Is that welded in bung for the IAT sensor? Must be, here's a link to a similar mod: http://fullsizebronco.com/forum/showthread.php?t=150122
Actually the stock Mustang intake is okay for a stock engine. There are probably a few FRP Cobra intakes out there for sale too.
http://www.ebay.com/itm/1986-1995-Fo...df016e&vxp=mtr
http://www.ebay.com/itm/87-94-MUSTAN...1f4c34&vxp=mtr
http://www.ebay.com/itm/Explorer-Cob...9ab07a&vxp=mtr
What size injectors, MAF, TB, heads, and cam are you thinking about running?
"In the end...It's all Hack."
HackFabrication is offline
post #3408 of 3970 Old 08-26-2014, 06:24 AM Thread Starter
Jim1611
Jim1611's Avatar
It is a weld in bung. Tig welded they say. I have the stock injectors that came off the engine, it's a 94. My ecm is a 92 and I did that because of what I've read and been told that the 94 and 95 ecm don't work so well if you modify the engine. That being said I may get different injectors since the connections may be different on this harness. I don't have a MAF or TB and might just order something aftermarket there. I have the GT40 3 bar heads. Cam is factory grind but new. Thanks for the links
My build thread
Jim1611 is offline
post #3409 of 3970 Old 08-26-2014, 06:40 PM
REDnBLUES
1977 CJ7
Looks like the intake on my 1995 Lightning.
Sent from my Jeep-phone using JeepForum
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #3410 of 3970 Old 08-26-2014, 06:56 PM
Coiz
1979 CJ7
Injector connectors will be the same no matter the size of flow rating.
That one that Hack listed that comes with the TB, fuel rails, IAC, injectors and everything else looks a little rough but you could easily clean that up. It would be nice to get all that stuff in one shot.
I know you got the same valve covers as I did but did you also change the rockers or keep them stock? You'll also probably need to get the 1" intake spacer so the throttle linkage will clear the higher valve cover.
Mike
Coiz is offline
post #3411 of 3970 Old 08-26-2014, 08:35 PM Thread Starter
Jim1611
Jim1611's Avatar
I had hoped all of that came with the intake too Mike but he's only selling the upper and lower intake. I did change the rockers to an aftermarket roller rocker. They are Scorpion 1.72 ratio and my factory covers were too short. I was figuring on the spacer, I remember you needing to do that too.
My build thread
Jim1611 is offline
post #3412 of 3970 Old 08-27-2014, 04:14 PM Thread Starter
Jim1611
Jim1611's Avatar
The clutch assembly came in today. The bolts lined up between the pressure plate and flywheel and the throw-out bearing fit the clutch fork. I don't have any dowel holes in the flywheel that line up with the pressure plate. I think it would be a good investment in time to set the flywheel up and drill those holes. Might as well be done right.
My build thread
Jim1611 is offline
post #3413 of 3970 Old 08-28-2014, 03:16 AM
HackFabrication
1976 CJ5
I don't think that is necessary. Also might effect the 50oz imbalance necessary for the 5.0L. Besides, might cause additional work if you want to resurface the flywheel at a later time during a clutch replacement.
post #3414 of 3970 Old 08-28-2014, 08:05 AM
lucdog
lucdog's Avatar
1980 CJ5
I agree with this. I don't believe I've ever seen alignment pins on a clutch before.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3415 of 3970 Old 08-28-2014, 08:14 AM
CJ7ROB
Bill
Mine didn't have those either. Jim, might be a good time to change the pilot bearing while your at it too if you haven't already.
CJ7ROB is offline
post #3416 of 3970 Old 08-28-2014, 08:58 AM
Dadamsnv
1977 CJ5
Don't the clutch bolts have a locator shank that acts like a dowel? I have my clutch out right now and seem to remember seeing this
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #3417 of 3970 Old 08-28-2014, 09:02 AM
Dadamsnv
1977 CJ5
Like this but less dramatic
Dadamsnv is offline
post #3418 of 3970 Old 08-28-2014, 09:52 AM Thread Starter
Jim1611
Jim1611's Avatar
Bill
I've seen some Bill. Allot of the shops used to bring flywheels here for resurfacing and I had to take them out.
Got a new one ready to go it
I looked at the ones that Ford racing sells and they're just a straight grade 8 bolt with a lockwasher.
Called the machine shop to double check and they said there was no need for the dowel pins. One less thing I have to do this way. Thanks guys otherwise I'd likely not have called.
My build thread
Jim1611 is offline
post #3419 of 3970 Old 08-29-2014, 06:46 PM Thread Starter
Jim1611
Jim1611's Avatar
I'm not convinced that I have the right clutch fork. When I try to fit it and the throw-out bearing in place it does not feel right. It binds up and won't move very far once it is in place. Any thoughts?
My build thread
Jim1611 is offline
post #3420 of 3970 Old 08-30-2014, 02:23 PM Thread Starter
Jim1611
Jim1611's Avatar
Solved the problem. For one thing it was too long and needed a shorten job done to it.
This area I'm pointing out was too thick. I took about 1/8" off of it and that helped allot.
Scribed the lines 5/8" apart and cut right close to the lines then ground it till it all fit good and beveled the edges for a good weld job.
All welded up, on the back side too.
Welds smoothed out and did a little contouring on the end to give even more clearance between it and the proportioning valve.
Here it will have about 5/16" clearance.
Here there's 1". Problem seems to be solved. Now it needs paint.
My build thread
Jim1611 is offline
AMC 360 Rebuild gmshades Jeep CJ Forum 29 08-14-2015 12:44 PM
Rebuild 258 or 4.0 HO? 1979CJ7newguy Jeep CJ Forum 6 09-29-2011 11:04 PM
Jim's cj5 build up patchy_400 Jeep CJ Forum 10 11-24-2010 02:07 PM
Carter BBD rebuild: Does it matter which rebuild kit I use? Ken4444 Jeep CJ Forum 2 06-14-2010 11:01 AM
CJ tub rebuild paraman72 Jeep CJ Forum 5 06-07-2005 10:06 PM
