Jim's 85 CJ7 rebuild - Page 219 - JeepForum.com
 36Likes
post #3271 of 3969 Old 05-01-2014, 05:15 PM
mvigo
mvigo's Avatar
those sure look like stout "D" ring tabs...
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #3272 of 3969 Old 05-01-2014, 06:16 PM
Skerr
Let me know if you want a helper for the summer. Clay is looking for work before he heads off to college.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3273 of 3969 Old 05-01-2014, 07:19 PM
TKFireman
1980 CJ7
I wish I was closer and could come be an apprentice. Nice work Jim
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #3274 of 3969 Old 05-01-2014, 08:08 PM Thread Starter
Jim1611
Jim1611's Avatar
Thanks Mike
Do you really think he'd want to be stuck in the shop with a grumpy old guy like me?
Seems everyone I'd like to have around is too far away! Thanks
Got my fuel sending unit installed this evening. Also took a little better picture of the baffles.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3275 of 3969 Old 05-01-2014, 10:29 PM
rixcj
rixcj's Avatar
1979 CJ5
Clevis hook mounts??
I'm going to go out on a limb, here...I'd say that the stock is .75" x 1.5" CR flat bar cut to 3.375" long, with a .75" hole. Close??
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #3276 of 3969 Old 05-02-2014, 06:21 AM Thread Starter
Jim1611
Jim1611's Avatar
Rich
They are clevis mounts. They measure 1" x 2" x 4 1/2" with a 1" hole. I got stuck with this material last year after a mistake on an order from Ryerson Steel. I only needed a quote on the stuff but later when I placed an order this material was with it, 50 pcs. They wouldn't take it back so the other day I decided to make some tabs out of them to sell on ebay to folks that are making their own bumpers out of the 2 x 4 tubing. These are made long enough to go all the way through. Since I'm not a vendor here I can't sell through the forum but people find ways around that on their own.
My build thread
Jim1611 is offline
post #3277 of 3969 Old 05-03-2014, 08:54 AM
ASteve
1972 CJ5
Hi Jim,
Is this your ebay page:
http://www.ebay.com/itm/Weld-on-clev...139853&vxp=mtr
Just wondering...
SC
ASteve is offline
post #3278 of 3969 Old 05-03-2014, 09:19 AM Thread Starter
Jim1611
Jim1611's Avatar
Originally Posted by ASteve View Post
Hi Jim,
Just wondering...
SC
Howdy Steve
That's it! Thanks for looking it up. Already sold some of them. I really thought it would take a while for anything to happen so it surprised me when the email notice came in. Need to get some more of this stuff on there too!
My build thread
Jim1611 is offline
post #3279 of 3969 Old 05-17-2014, 03:19 PM Thread Starter
Jim1611
Jim1611's Avatar
I made some more progress on the tank today. I bought some brass roll-over valves and made some weld in flanges for them to screw into.
Then I needed a way to hold my fuel pickup tube and stuff in place so I cut a 3" dia. hole in the center of the top and drilled 8 holes around that for 1/4-20 screws. Made a ring with the same bolt pattern that size and it got welded onto the bottom side of the plate. I plan to make an aluminum top for it that's threaded to take 2 fittings. One supply and one return.
After that stuff was taken care of I welded the top on. I took some more of Rich's advice on how to weld the seams. I couldn't get comfortable enough to do the welds in one hitch so they got welded in 3"-4" intervals. He calls this "back stitch welding", correct me if I named that wrong Rich. You start on one end and weld then stop. Move away from where you stopped, in my case 3"-4" then start again but overlap the last weld. It worked very well for me. Thanks Rich
I'm looking forward to sealing this up and putting air pressure to it to see if it has any leaks. Also I wonder instead of painting this to spray it with U-Pol Gravitex like I did the bottom of the tub.
My build thread
Jim1611 is offline
post #3280 of 3969 Old 05-17-2014, 03:58 PM
Coiz
1979 CJ7
The tank is looking great Jim.
Mike
Coiz is offline
post #3281 of 3969 Old 05-17-2014, 04:39 PM
rixcj
rixcj's Avatar
1979 CJ5
That's the way the pros do it, Jim! Yep...back-step welding is the way to go! And with those cabinet corner fit-ups, you're getting pretty much 100% penetration.
Rich
rixcj is offline
post #3282 of 3969 Old 05-22-2014, 10:05 PM
lucdog
lucdog's Avatar
1980 CJ5
Nice Jim!!!
BG
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3283 of 3969 Old 05-23-2014, 09:28 AM Thread Starter
Jim1611
Jim1611's Avatar
Rich
Originally Posted by lucdog View Post
Nice Jim!!!
BG
Thanks Guys! Hope everyone has a safe and nice weekend
My build thread
Jim1611 is offline
post #3284 of 3969 Old 05-29-2014, 08:14 PM Thread Starter
Jim1611
Jim1611's Avatar
Got things sealed up to test for leaks. After getting it all rigged up I gave it some air and ran it up to 15 psi. My gauge wasn't marked good enough to read under 10. I squirted soapy water on every seam. Found one leak. That's fixed.
I weighed this thing today. Anyone want to take a guess? It included the skid plate too. That gets welded on next. I'll check it again for leaks then it'll just about be done. I also think I'll weld a bolt on one of the front mounting tabs to use for grounding the tank to the frame.
My build thread
Jim1611 is offline
post #3285 of 3969 Old 05-29-2014, 08:48 PM
243
1978 FSJ Cherokee
167.5 lbs
Dave's 78 Build
243 is offline
AMC 360 Rebuild gmshades Jeep CJ Forum 29 08-14-2015 12:44 PM
Rebuild 258 or 4.0 HO? 1979CJ7newguy Jeep CJ Forum 6 09-29-2011 11:04 PM
Jim's cj5 build up patchy_400 Jeep CJ Forum 10 11-24-2010 02:07 PM
Carter BBD rebuild: Does it matter which rebuild kit I use? Ken4444 Jeep CJ Forum 2 06-14-2010 11:01 AM
CJ tub rebuild paraman72 Jeep CJ Forum 5 06-07-2005 10:06 PM
