Jim's 85 CJ7 rebuild - Page 215 - JeepForum.com
 36Likes
post #3211 of 3969 Old 08-24-2013, 07:53 PM
243
1978 FSJ Cherokee
Looks good Jim
Dave's 78 Build
243 is offline
post #3212 of 3969 Old 09-09-2013, 07:01 PM Thread Starter
Jim1611
Jim1611's Avatar
Taking a little break from work to work on the gas tank, might be a short lived break though! I cut the passenger side end of the tank out this evening and it fits up real nice. Also notice the seams are all cleaned off to bare metal. Hot rolled steel has a surface coating on it that really ought to always be ground off before welding. I don't always do that but in this case it will be done. I want to make sure my welds don't have any impurites in them as best I can and this is one way to do so. Some of you may be wondering why the holes are not cut in for the filler and vent. I'm using a YJ tub and the filler is located on the driver's side. I like it on that side so instead of moving the filler on the YJ tub to match that of a CJ I left it alone.
Here's the fit I want for all the seams. The corners for a V that will be filled with weld. It'll make for a nice looking weld that really won't need any clean up at all and it's much easier to weld than if the ends were allowed to be fluch where all you have is the flat seam.
Here's the end tacked in place and another look at the seam. When I did the tacks I cut the heated, oxidixed end off the wire between each tack. It makes for a better tack that does not have contaminates in it and requires less heat to strike the arc. This is something that ought to be done when welding patch panels in the body too. Try it next time and see how much better the tack weld looks. Also before I weld that solid the metal will be cleaned off with a wire wheel so that I am back down to a clean surface.
I also cleaned the metal on ths inside of the tank. I may weld those seams there too. Not sure about that yet though.
Jim1611 is offline
post #3213 of 3969 Old 09-09-2013, 07:08 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I wish I had this advice before welding up my plasma table water reservoir! I had a pin-hole leak that was a pain to fix... Awesome as always, Jim!
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #3214 of 3969 Old 09-09-2013, 07:15 PM
TKFireman
1980 CJ7
Looks great Jim. Nice work as always
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #3215 of 3969 Old 09-09-2013, 07:25 PM
lucdog
lucdog's Avatar
1980 CJ5
Real nice Jim. I cut that little ball off the wire on my MIG as well, 90% of the time.
I wouldn't weld the inside of the tank, at CAT on the tank line , they don't weld them either.
I think it really depends on how much abuse you think the tank will have. Are you going to use a baffles in the tank?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3216 of 3969 Old 09-09-2013, 07:31 PM
CJ7ROB
Nice work Jim. Do you need to use a sealer on the inside and when welding the last piece how do you make sure no wire passes thru the groove and into the tank?
CJ7ROB is offline
post #3217 of 3969 Old 09-09-2013, 07:43 PM Thread Starter
Jim1611
Jim1611's Avatar
Thanks Jim. I'm hoping not to have any leaks but won't be surprised if I end up with some.
Thanks Tim.
Bill
Thanks Bill. I'll weld the outside first then if that turns out good I likely won't weld the inside fillet. There will be two baffles equally spaced running parralell to the frame. I have some 14 gauge steel that I'll use for them.
Thanks Rob. I'm going to do some checking on the sealer. It seems like a good idea but I'm going to call some of the manufacturers to see what they can tell me first. If the top fits right there won't be a gap for wire to pass through. I'll just have to be extra careful in cutting and fitting it.
Jim1611 is offline
post #3218 of 3969 Old 09-18-2013, 02:52 PM Thread Starter
Jim1611
Jim1611's Avatar
Monday I decided to do the final work on the block before I took it to the machine shop. Thanks to Dave and Bill for giving me the nudge.
I took all of the freeze plugs out and cleaned the gasket surfaces. I also ground off some of the roughness off from the casting process. The engine showed very little signs of wear but when I took the freeze plugs out the water jacket was full of sludge. Enough to have clogged up a radiator. No doubt there'd been overheating problems. This alone made me glad I tore the engine down. Not yet sure whether the block will be bored or not. One cylinder was .004 oversize and after honing that might not work out. The rotating assembly is going to be balanced too. Going to polish the crank and chamfer the oil passage holes in it. They also have the heads and will just be grinding the valves and seats. I checked the deck surfaces with my straigh-tedge and they all looked good.
Jim1611 is offline
post #3219 of 3969 Old 09-18-2013, 03:49 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Our engine rebuilders only use furnaces here to clean out all that old sludge. At the moment, as my 302 is also about to get a going over..., I wish there was a place with a caustic dipping pool to eat all that garbage away. My Explorer 302 came from Georgia, so it has seen lots of humidity and heat, too.
Why not weld the inside seams of your tank? You'll have it open so it's double the insurance, isn't it? Just asking.
post #3220 of 3969 Old 09-18-2013, 04:31 PM Thread Starter
Jim1611
Jim1611's Avatar
They dipp the block here, Jim. I think it's some kind of acid. Been thinking on the tank welds and will likely weld both inside and out, except for the top. It goes on last.
Jim1611 is offline
post #3221 of 3969 Old 09-20-2013, 08:44 PM
Skerr
Wow! That really IS sludgey. Glad you caught that.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3222 of 3969 Old 10-10-2013, 03:02 PM
ScroungerLee
Jim, I read this entire thread and wanted to say thank you for the education. What a great bunch of guys on this thread and on JF in general, I am glad to have found this place.
Lee
ScroungerLee is offline
post #3223 of 3969 Old 10-10-2013, 08:37 PM
Renegade82
1982 CJ7
The tank construction looks great Jim, nice job.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #3224 of 3969 Old 10-11-2013, 05:00 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Jim,
I always learn something when I click on your thread.
Thank you, sir.
Matt
Matt1981CJ7 is offline
post #3225 of 3969 Old 10-11-2013, 07:31 AM
Skerr
Originally Posted by Matt1981CJ7 View Post
Jim,
Thank you, sir.
Matt
YOU learn something when you read the back panel of a cereal box!
Kerrdog
Go Fish! <*////><
Skerr is offline
AMC 360 Rebuild gmshades Jeep CJ Forum 29 08-14-2015 12:44 PM
Rebuild 258 or 4.0 HO? 1979CJ7newguy Jeep CJ Forum 6 09-29-2011 11:04 PM
Jim's cj5 build up patchy_400 Jeep CJ Forum 10 11-24-2010 02:07 PM
Carter BBD rebuild: Does it matter which rebuild kit I use? Ken4444 Jeep CJ Forum 2 06-14-2010 11:01 AM
CJ tub rebuild paraman72 Jeep CJ Forum 5 06-07-2005 10:06 PM
