Jim's 85 CJ7 rebuild - Page 143 - JeepForum.com
 64Likes
post #2131 of 4042 Old 02-09-2012, 04:34 PM
bbc
Now what do you do?
Just sweep that into the driveway?
bbc is offline
post #2132 of 4042 Old 02-09-2012, 05:45 PM Thread Starter
Jim1611
Jim1611's Avatar
Originally Posted by cjdogtoy View Post
looks like bare metal to me, I'm happy to hear how fast it went for you, I was thinking it would take allot longer. be sure to take pics of the tanks it's going into, I would love to hear and see details on the way they do that
I'll see about getting pictures but they may not allow that. Allot of the places I go into won't allow pictures of their operations to be taken but I'll ask. Yep it did go pretty quick, thankfully.
Originally Posted by bbc View Post
Now what do you do?
It's already in the driveway. I thought about saving it but it's been damp here and it really didn't seem worth the time to save it knowing I'd have to spread it out in the shop to let it dry.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #2133 of 4042 Old 02-09-2012, 07:26 PM
lucdog
lucdog's Avatar
1980 CJ5
Take the sand down to the lake. That way when I come over. I can play in the sand, and swim, without getting muddy.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #2134 of 4042 Old 02-09-2012, 07:40 PM
VACJ7
VACJ7's Avatar
Jim, I am amazed at how quickly you blasted the frame! What kind of nozzle do you use? My pot blaster, as someone here described, is like blasting with a sharpie.
Paul
'84 CJ-7 |
VACJ7 is offline
post #2135 of 4042 Old 02-09-2012, 09:10 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
That looks great, Jim! How's your back feeling?
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #2136 of 4042 Old 02-10-2012, 02:54 PM Thread Starter
Jim1611
Jim1611's Avatar
Bill
Don't worry Bill I've got a really big sand pile for you to play in.
Paul
Paul my blaster is a pressure pot. That makes a big difference over the siphon type. Your compressor being able to keep up helps too. Picture is below of the tips I use.
Thanks Jim. It's getting better but I still have a long way to go before I'm back to normal. I'm trying to really be careful with it and that's hard to do!
My build thread
Jim1611 is offline
post #2137 of 4042 Old 02-10-2012, 10:42 PM
rixcj
rixcj's Avatar
1979 CJ5
I'm just another voice saying, "that frame looks great!" Nice work, Jim.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #2138 of 4042 Old 02-11-2012, 08:33 AM
mvigo
mvigo's Avatar
I just might have to move to Perry, MO...nice work once again!
1985 CJ-7, fuel injected 258, 2.5" Rubicon Express Extreme Duty Lift, 1" Body lift, Crabtree Shackle Hangers, T-5, Dana 300 w/ 4:1 Teralow kit, Dana 30, AMC 20 w/1 piece axle, 3.73 's with Detroit Truetrac front and rear, riding on 32x11.5x15" Cooper Discoverer STT mud terrains
mvigo is offline
post #2139 of 4042 Old 02-11-2012, 09:40 AM
twinstickd20
1979 CJ7
looking good Jim
My Build Thread
twinstickd20 is offline
post #2140 of 4042 Old 02-11-2012, 11:52 PM
cjdogtoy
1976 CJ5
was that the h.f. blaster? I saw the way you modified it on Scott's thread, but wasn't sure were you got it.
cjdogtoy is offline
post #2141 of 4042 Old 02-13-2012, 08:16 AM Thread Starter
Jim1611
Jim1611's Avatar
Rich
Thanks Rich.
It's a nice place to live Mike. Let me know when to start looking around! Thanks, I'll be glad to get it with a finish on it.
Originally Posted by twinstickd20 View Post
looking good Jim
Thanks man! I look forward to being able to use it the way you have yours!
Dog I bought that blaster from Northern Tool & Hydraulics. I think H.B. has the same thing too. It's been a good one for the money.
My build thread
Jim1611 is offline
post #2142 of 4042 Old 02-13-2012, 05:17 PM Thread Starter
Jim1611
Jim1611's Avatar
In getting the frame ready for galvanizing I wanted to have all the holes drilled in it that I would need. There are two extra holes that are required for the YJ/CY front shackle hangers and someday I may put YJ springs on this, so the holes will be there if I do.
You can see that the hanger lines up with the two existing holes and has a clearance hole for the rivet. It needs another clearance hole for the 7/16 threaded hole in the bottom of the hanger. Some conversion hangers have you grind the rivet off. I don't do that with my hangers, you just drill the extra hole. Better idea I think.
So we need a place to measure from in order to get the extra hole in the right location. I am measuring from the furthest forward mounting hole.
Here's a fairly accurate way to find the center of that hole. I measured the i.d. of the threaded hole, which was .375, and divide that by 2. Take a drill bit that size, 3/16, and insert it in the hole and slide your square up against it. That does a nice job of making sure the edge of the square is on the center of the hole. Now just scribe a line.
Now you need to find the center of the hole from the edge of the frame so you can mark that where the new hole goes. Just use the same method and slide an adjustable square up against the drill bit. Now move the square in the general location of the new hole and scribe a mark along the end of the scale.
Now you need to measure from the mounting hole on the hanger that I marked the center of on the frame to the new hole. In this case that distance is 2.427. Now scribe a line at that location. You now have both directions marked on the frame. Center punch it and you're ready to drill.
I drilled the final hole 1/2". I stepped that up in three smaller drills, started about 1/8" then 5/16" then the final 1/2" and chamfered the hole to get rid of the sharp edge.
My build thread
Jim1611 is offline
post #2143 of 4042 Old 02-13-2012, 07:09 PM
Skerr
Very neat little trick, Jim. Thanks for sharing it. And you have a very good eye with the center punch too. I couldn't have made it that perfect even with the crosshair!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2144 of 4042 Old 02-13-2012, 07:49 PM
Cyclone
1980 CJ5
Just started following a few builds as I have stared my own in November. Great ideas all throughout and a REALLY good bunch of guys! I recently purchased a sand blaster simular to yours to do my frame and other parts. How did you modify it to get more control on the amount of sand that comes out? Did you replace the nozzle holder to another type?
Cyclone is offline
post #2145 of 4042 Old 02-14-2012, 10:15 AM Thread Starter
Jim1611
Jim1611's Avatar
Thanks Scott. I was wearing my dollar store glasses so I could see the lines better.
Glad you're finding some good info and nice people.
If yours is like mine it should have a valve on the bottom that's where the sand comes out of the tank. That will be adjustable so you can regulate the amount of sand that comes out of the nozzle. I have mine turned down quite a bit to conserve sand but it also works better that way too since the air is really moving faster to make the sand hit the metal. You're not regulating pressure just sand output.
Also when it first starts up it spits and sputters. Give it about 30 seconds and that goes away. Enjoy your build too.
My build thread
Jim1611 is offline
AMC 360 Rebuild gmshades Jeep CJ Forum 29 08-14-2015 12:44 PM
Rebuild 258 or 4.0 HO? 1979CJ7newguy Jeep CJ Forum 6 09-29-2011 11:04 PM
Jim's cj5 build up patchy_400 Jeep CJ Forum 10 11-24-2010 02:07 PM
Carter BBD rebuild: Does it matter which rebuild kit I use? Ken4444 Jeep CJ Forum 2 06-14-2010 11:01 AM
CJ tub rebuild paraman72 Jeep CJ Forum 5 06-07-2005 10:06 PM
