JFI fuel injection system, anyone have any info? - JeepForum.com
post #1 of 14 Old 12-05-2008, 11:04 PM Thread Starter
thebeast64
I just got my cj running and all of the other good things like that and now its time for CALIFORNIA smog testing! I have read that this is the first system to qualify under the C.A.R.B. law or something like that for california. but it seems to be running rich because you can see the smog comin out the tail pipe like when a car hasnt warmed up yet....but always. so if anyone knows anything about this system and could help my out with diagrams and things that would be awesome, thanks
thebeast64 is offline
post #2 of 14 Old 12-07-2008, 10:45 AM Thread Starter
thebeast64
Bump! Anyone know anything? Or am I SOL?
post #3 of 14 Old 12-07-2008, 02:26 PM
bleoh
I think that sounds like the Electromotive system they put out. JFI stands for Jeep Fuel Injection. Should have a crank sensor bolted to the front of the crankshaft, wasted spark and a mass air flow sensor to go with the TBI.
If it was running rich you would see black smoke out the tailpipe. If you are seeing more white colored exhaust like when an engine is warming up then I would suspect you have a breach between the coolant system and the combustion chamber, such as a bad head gasket or a cracked/warped head.
There are still dealers out there for Electromotive kits. I even found a local dealer and they still had the trigger wheel, VR sensor and mount available for the 4.2 six (I was thinking of using it with my MegaSquirt fuel injection system). You might even find the user manual on their website, look at the TEC 1 and TEC 2 manuals and see if they look similar.
http://www.electromotive-inc.com/manuals.html
I would love to play around with and old Electromotive system.
HTH, Brian.
bleoh is offline
post #4 of 14 Old 12-07-2008, 03:32 PM
slacker92104
slacker92104's Avatar
If you want, you can take it to a "smog check" station and have it pre-tested. When they ask for your registration, tell them it's not yours. You're thinking about buying it and want it checked. That way it hopefully won't be logged if it fails (I'm not sure that it really matters if it is logged though).
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #5 of 14 Old 12-07-2008, 08:36 PM
UPJ Wheeler
if you have any questions about the kit, electromotive is still in business (as far as I know). I bought a JFI kit on ebay about a year and a half ago (although I may have been a little hasty about the purchase). I havent installed it yet, but when I was going through all of the wiring, I gave them a call and they techs were able to answer all of the questions I had.
They stopped making the JFI kit because there was a lack of consumer interest and good competition.
'79 CJ7, rebuilt 258, HEI, T5 World Class, D300 Low max 4:1, Flat Belly, Narrowed D44 w/ true trac & diff gaurd, Widetrack AMC20 w/ superior shafts, Detroit locker & crane diff cover, 4" skyjacker lift, 2" BL, TJ flares, 35" tires, York OBA, YJ tub conversion, 6 pt. cage, F250 front shock towers
4.0 Head and TBI on the way
UPJ Wheeler is offline
post #6 of 14 Old 12-07-2008, 10:55 PM Thread Starter
thebeast64
Yes! thanks you guys so much, i really havent run it a LONG time, for maybe 20 mins at a time, do you think thats a long enough time for it to not be making the greyish exhaust Also the exhaust dissipates approx 2 ft from the tail pipe....im just wondering if that points to anything as well.... since it was running before they decided to store it, im thinking not a cracked head, but maybe a bad head gasket? would it go bad from just sitting?
post #7 of 14 Old 12-08-2008, 06:53 AM
bleoh
If all you have done is run it for 20 min with no load, and the white-ish colored exhaust dissipates that quick, your engine/exhaust system may not have been fully warmed up yet.
bleoh is offline
post #8 of 14 Old 12-08-2008, 04:36 PM Thread Starter
thebeast64
maybe not, but it does seem to drip at lot of water...more than ususal, is it possible that there is some water that has ended up in the muffler or something like that because it has been sitting for 8 years?
post #9 of 14 Old 12-09-2008, 03:31 PM
slacker92104
Water can collect in the exhaust system. I would run it longer. Make sure everything is fully up to operating temperature. Then take another look.
post #10 of 14 Old 12-09-2008, 05:49 PM Thread Starter
thebeast64
ok i will do that, however on the same note, if i do end up having to change the gasket, im going to just do the 4.0 head swap, but what will this do to my emissions? can i not do this under California emissions?
post #11 of 14 Old 12-10-2008, 07:00 AM
bleoh
I am not sure about the rules in California, but from an air fuel ratio perspective you should be fine with a 4.0 head assuming the injector's flow rate they use is not maxed out currently. This assumes JFI is a MAF system and will adjust for the amount of air you are moving through the engine to keep the fuel correct. Were you able to find documentation for your system from the Electromotive website?
As opposed to a speed density system that uses a MAP sensor along with a VE table. With those small changes can be handled with O2 feedback but you would need to tune the VE table to get maximum results from upgrades to the engine.
bleoh is offline
post #12 of 14 Old 12-10-2008, 08:01 AM Thread Starter
thebeast64
Yes, the JFI is a MAF system, and yes i was able to find documentation, however it states that its not programmable, and that its not supposed to be used with different highlift camshafts.... so does that mean that its not a good match?
post #13 of 14 Old 12-10-2008, 08:03 AM Thread Starter
thebeast64
there is a programmable version but its not california legal! DOH
post #14 of 14 Old 01-11-2009, 09:14 AM
awils10
If you are confidant in programming it buy the programmable prom on ebay. The software is free from electromotive. This alowes fuel delivery and timing to be programmed. Just changing the comprssion ratio will not affect the electromotive system. The only reson I believe they recomend using a mild cam is due to ignition timing differences between cams. Personally I would see what gasses they check for at emmisions and go from there. in Pima AZ they only check for CO and Hydrocarbons making passing ez. other states and counties are different though
awils10 is offline
Fuel Sending Unit and Fuel Injection Question CJman77 Jeep CJ Forum 4 12-21-2009 05:01 PM
Redline Fuel Injection System doeboy99 Jeep CJ Forum 3 04-29-2009 06:31 AM
jfi fuel injection system questions thebeast64 Jeep CJ Forum 7 11-23-2008 09:56 PM
www.affordable-fuel-injection.com/amc-system.htm reedler Jeep CJ Forum 3 01-04-2006 09:28 AM
Any experts on Electromotives Tec II Fuel Injection system?? dali555 Jeep CJ Forum 0 11-03-2004 10:54 AM
